path: root/net
2015-05-05dm: net: rtc: Support using driver model for rtc in sntpSimon Glass
When setting the date, support driver model RTC also. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-05-05dm: rtc: Rename to_tm() to rtc_to_tm() and add error codeSimon Glass
Rename this function so that it is clear that it is provided by the RTC. Also return an error when it cannot function as expected. This is unlikely to occur since it works for dates since 1752 and many RTCs do not support such old dates. Still it is better to be accurate. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Heiko Schocher <hs@denx.de>
2015-04-18dm: net: Use existing Ethernet init for driver modelSimon Glass
At present even with driver model is used there is still much manual init of related devices: PHY, environment and board init. Until these requirements are dealt with in another way we need to keep them around. Break out the init portion of the legacy eth_initialize() into a separate function and call it from both the legacy and driver model eth_initialize() functions. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-04-18net: Fix compile errors when SNTP enabled and not DATEJoe Hershberger
When SNTP is enabled and DATE is not, to_tm() is not built in. It could be defined when TIMESTAMP is defined, so check for that. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: Convert protocol structures to use explicit sizesSergey Temerkhanov
Convert uchar/ushort to u8/u16 respectively. Signed-off-by: Radha Mohan Chintakuntla <rchintakuntla@cavium.com> Signed-off-by: Sergey Temerkhanov <s.temerkhanov@gmail.com> Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: Fix incorrect DHCP/BOOTP packets on 64-bit systemsSergey Temerkhanov
This commit fixes incorrect DHCP/BOOTP packet layout caused by 'ulong' type size difference on 64 and 32-bit architectures. It also renames NetReadLong()/NetCopyLong() to net_read_u32/net_copy_u32() accordingly. Signed-off-by: Radha Mohan Chintakuntla <rchintakuntla@cavium.com> Signed-off-by: Sergey Temerkhanov <s.temerkhanov@gmail.com> Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Fix checkpatch.pl failures in net.cJoe Hershberger
Finish eliminating CamelCase from net.c and other failures Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Fix checkpatch.pl failures in eth.cJoe Hershberger
There were still a few failures in net/eth.c, especially in the legacy part of the code. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Fix checkpatch.pl failures in linklocalJoe Hershberger
A few new rules in checkpatch.pl since linklocal.c was added. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Clean up cmd_net variables and functionsJoe Hershberger
Make a thorough pass through all variables and function names contained within common/cmd_net.c and remove CamelCase and improve naming. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Clean up netconsole variables and functionsJoe Hershberger
Make a thorough pass through all variables and function names contained within netconsole.c and remove CamelCase and improve naming. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Clean up DNS variables and functionsJoe Hershberger
Make a thorough pass through all variables and function names contained within dns.c and remove CamelCase and improve naming. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Clean up CDP variables and functionsJoe Hershberger
Make a thorough pass through all variables and function names contained within cdp.c and remove CamelCase and improve naming. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Clean up ping variables and functionsJoe Hershberger
Make a thorough pass through all variables and function names contained within ping.c and remove CamelCase and improve naming. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Clean up SNTP variables and functionsJoe Hershberger
Make a thorough pass through all variables and function names contained within sntp.c and remove CamelCase and improve naming. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Clean up RARP variables and functionsJoe Hershberger
Make a thorough pass through all variables and function names contained within rarp.c and remove CamelCase and improve naming. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Clean up NFS variables and functionsJoe Hershberger
Make a thorough pass through all variables and function names contained within nfs.c and remove CamelCase and improve naming. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Clean up DHCP variables and functionsJoe Hershberger
Make a thorough pass through all variables and function names contained within bootp.c and remove CamelCase and improve naming. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Clean up ARP variables and functionsJoe Hershberger
Make a thorough pass through all variables and function names contained within arp and remove CamelCase and improve naming. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Clean up TFTP variables and functionsJoe Hershberger
Make a thorough pass through all variables and function names contained within tftp and remove CamelCase and improve naming. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Fix var naming net <-> eth driversJoe Hershberger
Update the naming convention used in the network stack functions and variables that Ethernet drivers use to interact with it. This cleans up the temporary hacks that were added to this interface along with the DM support. This patch has a few remaining checkpatch.pl failures that would be out of the scope of this patch to fix (drivers that are in gross violation of checkpatch.pl). Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Cleanup internal packet buffer namesJoe Hershberger
This patch cleans up the names of internal packet buffer names that are used within the network stack and the functions that use them. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2015-04-18net: cosmetic: Name ethaddr variables consistentlyJoe Hershberger
Use "_ethaddr" at the end of variables and drop CamelCase. Make constant values actually 'const'. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Fixup var names for DHCP stringsJoe Hershberger
Remove CamelCase variable naming. Move the definition to the same compilation unit as the primary use. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Fixup var names related to boot fileJoe Hershberger
The variables around the bootfile were inconsistent and used CamelCase. Update them to make the code more readable. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Change IPaddr_t to struct in_addrJoe Hershberger
This patch is simply clean-up to make the IPv4 type that is used match what Linux uses. It also attempts to move all variables that are IP addresses use good naming instead of CamelCase. No functional change. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18dm: eth: Provide a way for drivers to manage packet buffersJoe Hershberger
Some drivers need a chance to manage their receive buffers after the packet has been handled by the network stack. Add an operation that will allow the driver to be called in that case. Reported-by: Simon Glass <sjg@chromium.org> Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> Tested-on: pcduino3
2015-04-18net: Improve error handlingJoe Hershberger
Take a pass at plumbing errors through to the users of the network stack Currently only the start() function errors will be returned from NetLoop(). recv() tends not to have errors, so that is likely not worth adding. send() certainly can return errors, but this patch does not attempt to plumb them yet. halt() is not expected to error. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-04-18dm: eth: Add support for ethprime env varJoe Hershberger
The ethprime env var is used to indicate the starting device if none is specified in ethact. Also support aliases specified in the ethprime var. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-04-18dm: eth: Add support for aliasesJoe Hershberger
Allow network devices to be referred to as "eth0" instead of "eth@12345678" when specified in ethact. Add tests to verify this behavior. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-04-18dm: eth: Pass the packet pointer as a parameter to recvJoe Hershberger
Stop forcing drivers to call net_process_received_packet() - formerly called NetReceive(). Now the uclass will handle calling the driver for each packet until the driver errors or has nothing to return. The uclass will then pass the good packets off to the network stack by calling net_process_received_packet(). Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2015-04-18net: Clean up network stack names used in DM driversJoe Hershberger
Take the opportunity to enforce better names on newly written or retrofitted Ethernet drivers. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-04-18dm: eth: Add basic driver model support to Ethernet stackJoe Hershberger
First just add support for MAC drivers. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-04-18net: Access mapped physmem in net functionsJoe Hershberger
Previously the net functions would access memory assuming physmem did not need to be mapped. In sandbox, that's not the case. Now we map the physmem specified by the user in loadaddr to the buffer that represents that space. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-04-18net: Make netretry actually do somethingJoe Hershberger
netretry previously would only retry in one specific case (your MAC address is not set) and no other. This is basically useless. In the DM implementation for eth it turns this into a completely useless case since an un-configured MAC address results in not even entering the NetLoop. The behavior is now changed to retry any failed command (rotating through the eth adapters if ethrotate != no). It also defaulted to retry forever. It is now changed to default to not retry Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-04-18net: Remove the bd* parameter from net stack functionsJoe Hershberger
This value is not used by the network stack and is available in the global data, so stop passing it around. For the one legacy function that still expects it (init op on old Ethernet drivers) pass in the global pointer version directly to avoid changing that interface. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reported-by: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org> (Trival fix to remove an unneeded variable declaration in 4xx_enet.c)
2015-04-18net: Use int instead of u8 for boolean flagJoe Hershberger
On some archs masking the parameter is inefficient, so don't use u8. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reported-by: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-04-18net: Change return codes from net/eth.c to use errorno constantsJoe Hershberger
Many functions returned -1 previously. Change them to return appropriate error codes. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reported-by: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-04-18net: Refactor in preparation for driver modelJoe Hershberger
Move some things around and organize things so that the driver model implementation will fit in more easily. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-04-18net: Rename helper function to be more clearJoe Hershberger
Make it clear that the helper is checking the addr, not setting it. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-04-18net: Provide a function to get the current MAC addressJoe Hershberger
The current implementation exposes the eth_device struct to code that needs to access the MAC address. Add a wrapper function for this to abstract away the pointer for this operation. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-02-12net: Use new checksum functionsSimon Glass
Drop the old checksum functions in favour of the new ones. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-01-23net: Add a separate file for IP checksummingSimon Glass
Move the checksum code out into its own file so it can be used elsewhere. Also use a new version which supports a length which is not a multiple of 2 and add a new function to add two checksums. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-12-08net: bootp: as CONFIG_BOOTP_SERVERIP is defined, keep bootfile not changedWu, Josh
Currenly when CONFIG_BOOTP_SERVERIP is defined, the SERVERIP is not changed when receive the BOOTP packet. But BOOTFILE is changed via BOOTP packet. As we will load the BOOTFILE from SERVERIP, if the BOOTFILE is modified by bootp packet but SERVERIP is not, that is not make sense. This patch make SERVERIP and BOOTFILE be consistent. If we define the CONFIG_BOOTP_SERVERIP, then SERVERIP and BOOTFILE will not changed by BOOTP packet. Only IP address is changed. Signed-off-by: Josh Wu <josh.wu@atmel.com>
2014-10-25eth: make eth_address_set staticJeroen Hofstee
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
2014-10-22net: Display the size when tftpboot finishesSimon Glass
If we know the file size, display it after loading the file. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-10-10SPDX License cleanup for LiMon imported filesWolfgang Denk
A number of network related files were imported from the LiMon project; these contain a somewhat unclear license statement: Copyright 1994 - 2000 Neil Russell. (See License) I analyzed the source code of LiMon v1.4.2 which was used for this import. It does not contain any "License" file, but the top level directory contains a file "COPYING", which turns out to be GPL v2 of June 1991. So it is legitimate to conclude that the LiMon derived files are also to be released under GPLv2. Mark them as such. Signed-off-by: Wolfgang Denk <wd@denx.de>
2014-09-24kconfig: add blank Kconfig filesMasahiro Yamada
This would be useful to start moving various config options. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2014-09-16net: dns: fix for DNS queries sent to the wrong MAC addressGerhard Sittig
When a DNS query is sent out, the ethernet packet can get directed to the MAC address of a server that was communicated to before. This is wrong when the previously stored MAC address corresponds to a different server's IP address, i.e. when the IP address of the previous and the current communication are different. The error can get reproduced by running a sequence of e.g. a TFTP download and a DNS query, where the TFTP and DNS servers reside on individual machines. The fix is to clear the server's MAC address that might be left from a previous operation, and to fetch the peer's MAC address in a new ARP lookup, before the DNS query is sent. This is the approach taken in other network services, like 8e52533d1095 ("net: tftpsrv: Get correct client MAC address"). Reported-by: Dirk Zimoch <dirk.zimoch@psi.ch> Signed-off-by: Gerhard Sittig <gsi@denx.de>
2014-08-21net: More BOOTP retry timeout improvementsThierry Reding
It's not unusual for DHCP servers to take a couple hundred milliseconds to respond to DHCP discover messages. One possible reason for the delay can be that the server checks (typically using an ARP request) that the IP it's about to hand out isn't in use yet. To make matters worse, some servers may also queue up requests and process them sequentially, which can cause excessively long delays if clients retry too fast. Commit f59be6e850b3 ("net: BOOTP retry timeout improvements") shortened the retry timeouts significantly, but the BOOTP/DHCP implementation in U-Boot doesn't handle that well because it will ignore incoming replies to earlier requests. In one particular setup this increases the time it takes to obtain a DHCP lease from 630 ms to 8313 ms. This commit attempts to fix this in two ways. First it increases the initial retry timeout from 10 ms to 250 ms to give DHCP servers some more time to respond. At the same time a cache of outstanding DHCP request IDs is kept so that the implementation will know to continue transactions even after a retransmission of the DISCOVER message. The maximum retry timeout is also increased from 1 second to 2 seconds. An ID cache of size 4 will keep DHCP requests around for 8 seconds (once the maximum retry timeout has been reached) before dropping them. This should give servers plenty of time to respond. If it ever turns out that this isn't enough, the size of the cache can easily be increased. With this commit the DHCP lease on the above-mentioned setup still takes longer (1230 ms) than originally, but that's an acceptable compromise to improve DHCP lease acquisition time for a broader range of setups. To make it easier to benchmark DHCP in the future, this commit also adds the time it took to obtain a lease to the final "DHCP client bound to address x.x.x.x" message. Tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
