Move this function over to the new header file. Also rename it to have an
env_ prefix like the other functions.
Adds a class for MDIO MUXes, which control access to a series of
downstream child MDIOs.
MDIO MUX drivers are required to implement a select function used to switch
between child buses.
MUX children are registered as MDIO buses and they can be used just like
regular MDIOs.
Signed-off-by: Alex Marginean <alexm.osslist@gmail.com>
Adds UCLASS_MDIO DM class supporting MDIO buses that are probed as
stand-alone devices. Useful in particular for systems that support
DM_ETH and have a stand-alone MDIO hardware block shared by multiple
Ethernet interfaces.
Convert CONFIG_TFTP_BLOCKSIZE to Kconfig, update defconfigs,
headers and whitelist.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Cc: Christian Gmeiner <christian.gmeiner@gmail.com>
Convert CONFIG_IP_DEFRAG to Kconfig, update defconfigs, headers
and whitelist. This patch is a follow-up on a patch by Christian
Gmeiner with the added config/header/whitelist updates.
Reported-by: Christian Gmeiner <christian.gmeiner@gmail.com>
Add the standard Ethernet device tree bindings (imported from v5.0 of
the Linux kernel) and implement support for reading the MAC address for
Ethernet devices in the Ethernet uclass. If the "mac-address" property
exists, the MAC address will be parsed from that. If that property does
not exist, the "local-mac-address" property will be tried as fallback.
MAC addresses from device tree take precedence over the ones stored in
a network interface card's ROM.
Reviewed-by: Grygorii Strashko <grygorii.strashko@ti.com>
Signed-off-by: Thierry Reding <treding@nvidia.com>
In order for the device to use the proper MAC address, which can have
been configured in the environment prior to the device being registered,
ensure that the MAC address is written after the device has been probed.
For devices that are registered before the network stack is initialized,
this is already done during eth_initialize(). If the Ethernet device is
on a bus that is not initialized on early boot, such as PCI, the device
is not available at the time eth_initialize() is called, so we need the
MAC address programming to also happen after probe.
This fixes the automatic lmb initialization and reservation for boards
with more than one DRAM bank.
This fixes the CVE-2018-18439 and -18440 fixes that only allowed to load
files into the firs DRAM bank from fs and via tftp.
Found-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
Tested-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
As a follow-up, change the name of the newly introduced function
'lmb_get_unreserved_size' to 'lmb_get_free_size', which is more
appropriate.
[trini: Fix test/lib/lmb.c]
No mainline board enables CONFIG_MCAST_TFTP and there have been
compilation issues with the code for some time. Additionally, it has a
potential buffer underrun issue (reported as a side note in
CVE-2018-18439).
Remove the multicast TFTP code but keep the driver API for the future
addition of IPv6.
Cc: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
Signed-off-by: Chris Packham <judge.packham@gmail.com>
ether_crc was added to the core net code in commit 53a5c424bf86
("multicast tftp: RFC2090") so that other drivers could use it. However
the only current user of it is tsec.c so move it there.
When dealing with two ethernet ports and having "netretry" set
to "once", it could occur that the connection (e.g. an ARP
request) failed, hence the status of the netloop was
"NETLOOP_FAIL". Due to the setting of "netretry", the network
logic would then switch to the other network interface,
assigning "ret" with the return value of "net_start_again()".
If this call succeeded we would return 0 (i.e. success) to
the caller when in reality the network action failed.
Signed-off-by: Thomas RIENOESSL <thomas.rienoessl@bachmann.info>
Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
This fixes CVE-2018-18439 ("insufficient boundary checks in network
image boot") by using lmb to check for a valid range to store
received blocks.
[trini: Always build lib/lmb.o on LMB and lib/fdtdec.o on OF_LIBFDT]
Make it possible to add TCP versions of the same, while reusing
IP portions. This patch should not change any behavior.
Signed-off-by: Duncan Hare <DH@Synoia.com>
Peter originally sent a fix, but it breaks a number of other things.
This addresses the original reported issue in a different way.
That report was:
> U-Boot has 1 common buffer to send Ethernet frames, pointed to by
> net_tx_packet. When sending to an IP address without knowing the MAC
> address, U-Boot makes an ARP request (using the arp_tx_packet buffer)
> to find out the MAC address of the IP addressr. When a matching ARP
> reply is received, U-Boot continues sending the frame stored in the
> net_tx_packet buffer.
> However, in the mean time, if U-Boot needs to send out any network
> packets (e.g. replying ping packets or ARP requests for its own IP
> address etc.), it will use the net_tx_packet buffer to prepare the
> new packet. Thus this buffer is no longer the original packet meant
> to be transmitted after the ARP reply. The original packet will be
> lost.
This instead uses the ARP tx buffer to send async replies in the case
where we are actively waiting for an ARP reply.
Reported-by: Tran Tien Dat <peter.trantiendat@gmail.com>
Tested-by: Bin Meng <bmeng.cn@gmail.com>
This single-sources the state of the ARP.
When a USB ethernet device is halted, the device driver is removed. When
this happens the uclass private memory is freed and uclass_priv is set to
NULL. This causes a data abort when uclass_priv->state is then set to
ETH_STATE_PASSIVE.
Fix it by checking if uclass_priv is NULL before setting uclass_priv->state
Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
The same basic parsing was implemented in tftp and nfs, so add a helper
function to do the work once.
Instead of depending on a env callback for bootfile, read it explicitly.
We do this because the bootfile can be specified on the command line and
if it is, we will overwrite the internal variable. If a netboot_common()
is called again with no bootfile parameter, we want to use the one in
the environment.
Rather than crashing, check the src ptr and set dst to empty string.
With net autoload, we check the prerequisites for the initial command,
but the greater prerequisites when autoloading are not checked.
If we would attempt to autoload, check those prerequisites too.
If we are not expecting a serverip from the server, then don't worry
about it not being set, but don't attempt to load if it isn't.
For net_boot_common, we allow the serverip to be specified as part of
the boot file name. For net commands that require serverip, include that
source as a valid specification of serverip.
Reviewed-by: Alexander Graf <agraf@suse.de>
nfs was only printing basic info about the transfer in the case of a
DEBUG build. Print the same level of detail as tftp always.
The check for sending to the gateway was not using the correct variable
for comparison, so it was reporting that packets are sent to the gateway
when they were not.
Reported-by: Coverity (CID: 152888)
With driver model, we were not checking if the state of the device was
marked as active before calling the halt function. Check that the device
is probed and also marked as active. This avoids the case where we were
calling halt on the first device in net_init() and the driver would
operate on bogus data structures causing problems. In this case, the
priv was all 0, so halt() would close STDIN.
Currently we can choose between 2 different types of behavior for the
serverip variable:
1) Always overwrite it with the DHCP server IP address (default)
2) Ignore what the DHCP server says (CONFIG_BOOTP_SERVERIP)
This patch adds a 3rd option:
3) Use serverip from DHCP if no serverip is given
(CONFIG_BOOTP_PREFER_SERVERIP)
With this new option, we can have the default case that a boot file gets
loaded from the DHCP provided TFTP server work while allowing users to
specify their own serverip variable to explicitly use a different tftp
server.
We can call commands like dhcp and bootp without arguments or with
explicit command line arguments that really should tell the code where
to look for files instead.
Unfortunately, the current code simply overwrites command line arguments
in the dhcp case with dhcp values.
This patch allows the code to preserve the command line values if they
were set on the command line. That way the semantics are slightly more
intuitive.
The reason this patch does that by introducing a new variable is that we
can not rely on net_boot_file_name[0] being unset, as today it's
completely legal to call "dhcp" and afterwards run "tftp" and expect the
latter to repeat the same query as before. I would prefer not to break
that behavior in case anyone relies on it.
Add a new command 'wol': Wait for an incoming Wake-on-LAN packet or
time out if no WoL packed is received.
If the WoL packet contains a password, it is saved in the environment
variable 'wolpassword' using the etherwake format (dot or colon
separated decimals).
Intended use case: a networked device should boot an alternate image.
It's attached to a network on a client site, modifying the DHCP server
configuration or setup of a tftp server is not allowed.
After power on the device waits a few seconds for a WoL packet. If a
packet is received, the device boots the alternate image. Otherwise
it boots the default image.
This method is a simple way to interact with a system via network even
if only the MAC address is known. Tools to send WoL packets are
available on all common platforms.
Some Ethernet drivers seem to pad the incoming packet. The additional
padding bytes might be recognized as Wake-on-LAN password bytes.
By default enabled in pengwyn_defconfig.
Signed-off-by: Lothar Felten <lothar.felten@gmail.com>
When building without FASTBOOT_FLASH we don't include the intermediate
update callback to keep the client alive, so ensure we don't try setting
it here.
Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
That can happen if duplicate UDP packet arrived, and that's not uncommon.
Anyway, we ignore packets with rpc_id lower than last we sent for other
requests, so it makes sense to do that for read request as well.
Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com>
Global variable "net_state" is used in net_loop() state-machine.
But it happens that some times the net_loop() can be called
multiple times in the same call stack. For example when the
netconsole is enabled and we print the message while some other
net protocol is in action. Netconsole will overwrite the "net_state"
and that will break the logic for earlier started protocol.
To protect the state save and restore "net_state" variable each
time when we enter and exit net_loop().
Signed-off-by: Leonid Iziumtsev <leonid.iziumtsev@se.atlascopco.com>
On devices that have their first network interface provided by a FPGA,
the initialization of further interfaces will fail if the FPGA is not
yet programmed. This leads to problems during factory setup when the
data is supposed to be loaded over secondary netowork interfaces.
To avoid this, use the uclass_{first,next}_device_check functions to
initialize as many ethernet devices as possible.
Signed-off-by: Mario Six <mario.six@gdsys.cc>
Make sure that TX packets are always cache-aligned.
Merge UDP fastboot support from AOSP:
https://android.googlesource.com/platform/external/u-boot/+/android-o-mr1-iot-preview-8
Signed-off-by: Alex Deymo <deymo@google.com>
Signed-off-by: Jocelyn Bohr <bohr@google.com>
When the following configuration is set
# CONFIG_CMD_DHCP is not set
CONFIG_CMD_BOOTP=y
CONFIG_BOOTP_NTPSERVER=y
The following compile error is observed
error: used struct type value where scalar is required
if (net_ntp_server)
Resolve this by checking net_ntp_server.s_addr instead.
As part of the main conversion a few files were missed. These files had
additional whitespace after the '*' and before the SPDX tag and my
previous regex was too strict. This time I did a grep for all SPDX tags
and then filtered out anything that matched the correct styles.
Fixes: 83d290c56fab ("SPDX: Convert all of our single license tags to Linux Kernel style")
Reported-by: Heinrich Schuchardt <xypron.debian@gmx.de>
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
We have a large number of places where while we historically referenced
gd in the code we no longer do, as well as cases where the code added
that line "just in case" during development and never dropped it.
No commands are necessary to have a network stack.
Reviewed-by: Duncan Hare <dh@synoia.com>
Options that controlled the tftp and bootp commands depended on their
commands, but lived in the net menu.
Move them so they are in a consistent location.
Reviewed-by: Chris Packham <judge.packham@gmail.com>
Previously, CMD_NET was an alias for 2 commands (bootp and tftpboot) and
they we not able to be disabled. Separate out those 2 commands and move
CMD_NET up to the menu level, which more accurately represents the code.
In order that we can use eth_env_* even when CONFIG_NET isn't set, move
these functions to environment code from net code.
This fixes failures such as:
board/ti/am335x/built-in.o: In function `board_late_init':
board/ti/am335x/board.c:752: undefined reference to `eth_env_set_enetaddr'
u-boot/board/ti/am335x/board.c:766: undefined reference to `eth_env_set_enetaddr'
which caters for use cases such as:
commit f411b5cca48f ("board: am335x: Always set eth/eth1addr environment
variable")
when Ethernet is required in Linux, but not U-Boot.
In the efi_loader main loop we call eth_rx() occasionally. This rx function
might end up calling into devices that haven't been initialized yet,
potentially resulting in a lot of transfer timeouts.
Instead, let's make sure the ethernet device is actually initialized before
reading from or writing to it.
The "net_try_count" counter starts from "1".
And the "retrycnt" contains requested amount of retries.
With current logic, that means that the actual retry amount
will be one time less then what we set in "netretry" env.
For example setting "netretry" to "once" will make "retrycnt"
equal "1", so no retries will be triggered at all.
Fix the logic by changing the statement of "if" condition.
Enable networking command only when NET is enabled.
And remove selecting NET for CMD_NET
CONFIG_BOOTP_BOOTPATH
CONFIG_BOOTP_DNS
CONFIG_BOOTP_GATEWAY
CONFIG_BOOTP_HOSTNAME
CONFIG_BOOTP_PXE
CONFIG_BOOTP_SUBNETMASK
CONFIG_CMDLINE_EDITING
CONFIG_AUTO_COMPLETE
CONFIG_SYS_LONGHELP
CONFIG_SUPPORT_RAW_INITRD
CONFIG_ENV_VARS_UBOOT_CONFIG
[trini: Re-run the migration]
config_fallbacks.h had some logic to automatically select
LIB_RAND if RANDOM_UUID or CMD_UUID were set if LIB_HW_RAND wasn't
already selected. By migrating LIB_HW_RAND to Kconfig, we can
remove this check from config_fallbacks.h and put it into Kconfig
Reviewed-by: Lukasz Majewski <lukma@denx.de>
[trini: Turn into a choice, add NET_RANDOM_ETHADDR]
This change allows the "MAY_FAIL" DHCP option to still attempt to
contact a DHCP server on each adapter and only give up once each
adapter has failed once. To get the existing behavior, set the
already-existing ethrotate=no variable.
Cc: Keng Soon Cheah <keng.soon.cheah@ni.com>
Cc: Chen Yee Chew <chen.yee.chew@ni.com>
Nothing from this header is used there, so remove it.
