path: root/net/wol.c
2019-08-11env: Drop environment.h header file where not neededSimon Glass
This header file is now only used by files that access internal environment features. Drop it from various places where it is not needed. Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2019-08-11env: Move env_set() to env.hSimon Glass
Move env_set() over to the new header file. Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2018-07-02net: Add new wol command - Wake on LANLothar Felten
Add a new command 'wol': Wait for an incoming Wake-on-LAN packet or time out if no WoL packed is received. If the WoL packet contains a password, it is saved in the environment variable 'wolpassword' using the etherwake format (dot or colon separated decimals). Intended use case: a networked device should boot an alternate image. It's attached to a network on a client site, modifying the DHCP server configuration or setup of a tftp server is not allowed. After power on the device waits a few seconds for a WoL packet. If a packet is received, the device boots the alternate image. Otherwise it boots the default image. This method is a simple way to interact with a system via network even if only the MAC address is known. Tools to send WoL packets are available on all common platforms. Some Ethernet drivers seem to pad the incoming packet. The additional padding bytes might be recognized as Wake-on-LAN password bytes. By default enabled in pengwyn_defconfig. Signed-off-by: Lothar Felten <lothar.felten@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
