path: root/net/tftp.h
2015-09-07net: tftp: Move tftp.h file from ./net to ./include/netLukasz Majewski
This change gives the ability to reuse the <tftp.h> header file by other subsystems (like e.g. dfu). Without this change compilation error emerges for the legacy update.c file. Signed-off-by: Lukasz Majewski <l.majewski@majess.pl> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-04-18net: cosmetic: Clean up TFTP variables and functionsJoe Hershberger
Make a thorough pass through all variables and function names contained within tftp and remove CamelCase and improve naming. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2012-11-04net/: sparse fixesKim Phillips
bootp.c:44:14: warning: symbol 'dhcp_state' was not declared. Should it be static? bootp.c:45:15: warning: symbol 'dhcp_leasetime' was not declared. Should it be static? bootp.c:46:10: warning: symbol 'NetDHCPServerIP' was not declared. Should it be static? arp.c:30:17: warning: symbol 'NetArpWaitReplyIP' was not declared. Should it be static? arp.c:37:16: warning: symbol 'NetArpTxPacket' was not declared. Should it be static? arp.c:38:17: warning: symbol 'NetArpPacketBuf' was not declared. Should it be static? atheros.c:33:19: warning: symbol 'AR8021_driver' was not declared. Should it be static? net.c:183:7: warning: symbol 'PktBuf' was not declared. Should it be static? net.c:159:21: warning: symbol 'net_state' was not declared. Should it be static? ping.c:73:6: warning: symbol 'ping_start' was not declared. Should it be static? ping.c:82:13: warning: symbol 'ping_receive' was not declared. Should it be static? tftp.c:53:7: warning: symbol 'TftpRRQTimeoutMSecs' was not declared. Should it be static? tftp.c:54:5: warning: symbol 'TftpRRQTimeoutCountMax' was not declared. Should it be static? eth.c:125:19: warning: symbol 'eth_current' was not declared. Should it be static? Note: in the ping.c fix, commit a36b12f95a29647a06b5459198684fc142482020 "net: Move PING out of net.c" mistakenly carried the ifdef CMD_PING clause from when it was necessary to avoid warnings when it was embedded in net.c. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2012-05-15net: cosmetic: tftp.* checkpatch complianceJoe Hershberger
2011-10-26net: tftpput: Support selecting get/put for tftpSimon Glass
TftpStart should support starting either a get or a put. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-05-19TFTP: net/tftp.c: add server mode receiveLuca Ceresoli
Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2000-12-28Initial revisionwdenk
