path: root/net/tftp.c
2013-11-22net: tftpsrv: Get correct client MAC addressAndrew Ruder
NetServerEther was not being cleared in the tftp server code, so the destination MAC address would be whatever the last destination MAC address was. Scenario: U-Boot: dhcp tftpsrv Host: Send device WRQ Device: Responds with ACK to dhcp server mac address with host ip address By clearing NetServerEther, we force a lookup of the host MAC address to go with the associated host IP. Signed-off-by: Andrew Ruder <andrew.ruder@elecsyscorp.com>
2013-11-22net: tftp: Make sure timeout will not effect wrap offsetrockly
When the block 0 store to the memory of client and timeout at this moment. Because of no ACK packet, the server will send block 0 again, if this client reconnect to the server at this time, TftpBlockWrapOffset will become larger than it should be. Signed-off-by: Rockly <rocklygnome@gmail.com> Patch: 264417
2013-06-24net/tftp: sparse fixesKim Phillips
tftp.c:464:17: warning: cast to restricted __be16 tftp.c:552:29: warning: cast to restricted __be16 tftp.c:640:33: warning: cast to restricted __be16 tftp.c:642:25: warning: cast to restricted __be16 Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Cc: Joe Hershberger <joe.hershberger@gmail.com>
2012-12-15net: Add tftp speed indicationSimon Glass
This prints a tftp speed indication after the download completes. This is the 3.6 MiB/s indicator below. Tegra2 (SeaBoard) # tftp ... Using asx0 device TFTP from server 172.22.72.144; our IP address is 172.22.73.81 Filename '/tftpboot/uImage-user-seaboard-1'. Load address: 0x408000 Loading: ################################################# 3.6 MiB/s done Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2012-07-11net: tftp: fix type of block arg to store_blockJayachandran Chandrasekharan Nair
The block argument for store_block can be -1 when the tftp sequence number rolls over (i.e TftpBlock == 0), so the first argument to store_block has to be of type 'int' instead of 'unsigned'. In our environment (gcc 4.4.5 mips toolchain), this causes incorrect 'offset' to be generated for storing the block, and the tftp block with number 0 will be written elsewhere, resulting in a bad block in the downloaded file and a memory corruption. Signed-off-by: Jayachandran Chandrasekharan Nair <jayachandranc@netlogicmicro.com>
2012-05-23net: Refactor to separate the UDP handler from the ARP handlerJoe Hershberger
Call a built-in dummy if none is registered... don't require protocols to register a handler (eliminating dummies) NetConsole now uses the ARP handler when waiting on arp (instead of needing a #define hack in arp.c) Clear handlers at the end of net loop Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2012-05-23net: Refactor to protect access to the NetState variableJoe Hershberger
Changes to NetState now go through an accessor function called net_set_state() Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-05-23net: cosmetic: Un-typedef IP_tJoe Hershberger
Rename IP header related things to IP_UDP. The existing definition of IP_t includes UDP header, so name it to accurately describe the structure. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-05-15net: cosmetic: tftp.* checkpatch complianceJoe Hershberger
2012-05-15net: Remove volatile from net APIJoe Hershberger
2011-12-06net: Make sure IPaddr_t is 32 bits in sizeMatthias Weisser
When building u-boot as 64 bit application (e.g. sandbox) ulong might be 64 bits in size. This breaks network code as IPaddr_t is 64 bytes in size then and an IPv4 address is 32 bits in size. This patch makes sure that IPaddr_t is always 32 bits in size. Also some warnings introduced by this patch are fixed. Signed-off-by: Matthias Weisser <weisserm@arcor.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-27net: Add more #ifdefs for tftpput to reduce code sizeSimon Glass
If CONFIG_CMD_TFTPPUT is not enabled, we want minimal code size impact on the tftp code. This introduces a few more #ifdefs. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-27net: Make net_transfer() a static functionSimon Glass
This should be a static function so it can be inlined. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-27net: Hide more code behind CONFIG_CMD_TFTPPUTSimon Glass
This commit reduces code size a little by making the ICMP handler only available to tftpput. This is reasonable since it is the only user at present (ping just uses the normal handler). Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-26net: tftpput: implement tftp logicSimon Glass
This adds logic to tftp.c to implement the tftp 'put' command, and updates the README. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-26net: tftpput: Support selecting get/put for tftpSimon Glass
TftpStart should support starting either a get or a put. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-26net: tftpput: Factor out start, restart and next block functionsSimon Glass
This code is required for tftpput, so move it into separate functions. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-26net: tftpput: move common code into separate functionsSimon Glass
We want to show block markers on completion of get and put, so move this common code into separate functions. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-05net: drop !NET_MULTI codeMike Frysinger
This is long over due. All but two net drivers have been converted, but those have now been dropped. The only thing left to do is actually delete all references to NET_MULTI and code that is compiled when that is not defined. So here we scrub the core code. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-05-19net/tftp.c: fix typoLuca Ceresoli
Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2011-05-19TFTP: net/tftp.c: add server mode receiveLuca Ceresoli
2011-05-19TFTP: rename STATE_RRQ to STATE_SEND_RRQLuca Ceresoli
With the upcoming TFTP server implementation, requests can be either outgoing or incoming, so avoid ambiguities. Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2011-05-19TFTP: replace "server" with "remote" in local variable namesLuca Ceresoli
With the upcoming TFTP server implementation, the remote node can be either a client or a server, so avoid ambiguities. Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2011-05-19net/tftp.c: cosmetic: do not initialise statics to 0 or NULLLuca Ceresoli
This removes the following checkpatch issue: - ERROR: do not initialise statics to 0 or NULL Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de>
2011-05-19net/tftp.c: cosmetic: fix indentationLuca Ceresoli
This removes the following checkpatch issue: - WARNING: suspect code indent for conditional statements Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de>
2011-05-19net/tftp.c: cosmetic: trailing statements should be on next lineLuca Ceresoli
This removes the following checkpatch issue: - ERROR: trailing statements should be on next line Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de>
2011-05-19net/tftp.c: cosmetic: fix brace issuesLuca Ceresoli
This removes the following checkpatch issues: - WARNING: braces {} are not necessary for single statement blocks - WARNING: braces {} are not necessary for any arm of this statement Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de>
2011-05-19net/tftp.c: cosmetic: do not use assignment in if conditionLuca Ceresoli
This removes the following checkpatch issue: - ERROR: do not use assignment in if condition. There is one such error left: ERROR: do not use assignment in if condition #239: FILE: tftp.c:239: + if (!ProhibitMcast + && (Bitmap = malloc(Mapsize)) + && eth_get_dev()->mcast) { which would require an additional nested if to be fixed, resulting in longer and less readable code. Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de>
2011-05-19net/tftp.c: cosmetic: fix pointer syntax issuesLuca Ceresoli
This removes the following checkpatch issues: - ERROR: "foo * bar" should be "foo *bar" - ERROR: "(foo*)" should be "(foo *)" Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de>
2011-05-19net/tftp.c: cosmetic: fix whitespace issuesLuca Ceresoli
This removes the following checkpatch issues: - ERROR: space prohibited before that close parenthesis ')' - ERROR: space required after that ';' (ctx:BxV) - ERROR: space required after that ',' (ctx:VxV) - ERROR: space required after that ';' (ctx:VxV) - ERROR: spaces required around that '<<=' (ctx:VxV) - ERROR: spaces required around that '<' (ctx:VxV) - ERROR: spaces required around that '=' (ctx:VxV) - ERROR: spaces required around that '+=' (ctx:VxV) - ERROR: spaces required around that '=' (ctx:VxW) - WARNING: please, no spaces at the start of a line - WARNING: space prohibited between function name and open parenthesis '(' Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de>
2011-05-19net/tftp.c: cosmetic: fix lines over 80 charactersLuca Ceresoli
2011-05-12NET: pass source IP address to packet handlersLuca Ceresoli
This is needed for the upcoming TFTP server implementation. This also simplifies PingHandler() and fixes rxhand_f documentation. Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2010-03-21TFTP: allow for adjustable retransmission timoutWolfgang Denk
So far, TFTP negotiated a fixed retransmission timeout of 5 seconds. In some cases (busy networks, slow TFTP servers) this caused very slow transfers. A new environment variable "tftptimeout" allows to set this timeout. Lowering this value may make downloads succeed faster in networks with high packet loss rates or with unreliable TFTP servers. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Ben Warren <biggerbadderben@gmail.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-12-13Add error codes/handling for TFTP-serverRemy Bohmer
Signed-off-by: Remy Bohmer <linux@bohmer.net> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-12-13net: pull CONFIG checks out of source and into makefileMike Frysinger
Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-08-25Add Transfer Size Option to tftpRobin Getz
Optionally add RFC 2349 "Transfer Size Option", so we can minimize the time spent sending data over the UART (now print a single line during a tftp transfer). - If turned on (CONFIG_TFTP_TSIZE), U-Boot asks for the size of the file. - if receives the file size, a single line (50 chars) are printed. one hash mark == 2% of the file downloaded. - if it doesn't receive the file size (the server doesn't support RFC 2349, prints standard hash marks (one mark for each UDP frame). Signed-off-by: Robin Getz <rgetz@blackfin.uclinux.org> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-08-25tftp: get the tftp block size from config file and from the environmentAlessandro Rubini
Increasing the block size is useful if CONFIG_IP_DEFRAG is used. Howerver, the last fragments in a burst may overflow the receiving ethernet, so the default is left at 1468, with thre new CONFIG_TFTP_BLOCKSIZE for config files. Further, "tftpblocksize" can be set in the environment. Signed-off-by: Alessandro Rubini <rubini@gnudd.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-08-10net/tftp.c: fix warning: pointer targets differ in signednessWolfgang Denk
tftp.c:294: warning: pointer targets in passing argument 1 of 'strlen' differ in signedness This was only visible for the utx8245 board which seems to have DEBUG enabled. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-08-07minor debug cleanups in ./netRobin Getz
Minor ./net cleanups - no functional changes - change #ifdef DEBUG printf(); #endif to just debug() - changed __FUNCTION__ to __func__ - got rid of extra whitespace between function and opening brace - removed unnecessary braces on if statements gcc dead code elimination should make this functionally/size equivalent when DEBUG is not defined. (confirmed on Blackfin, with gcc 4.3.3). Signed-off-by: Robin Getz <rgetz@blackfin.uclinux.org> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-03-20convert print_IPaddr() to %pI4Mike Frysinger
Now that our printf functions support the %pI4 modifier like the kernel, let's drop the inflexible print_IPaddr() function and covert over to the %pI4 modifier. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com>
2008-12-04net: Fix TftpStart() ip:filename bugPeter Tyser
The TftpStart() function modifies the 'BootFile' string when 'BootFile' contains both an IP address and filename (eg 1.2.3.4:/path/file). This causes subsequent calls to TftpStart to incorrectly parse the TFTP filename and server IP address to use. For example: => tftp 0x100000 10.52.0.62:/home/ptyser/non_existant Speed: 100, half duplex Using eTSEC1 device TFTP from server 10.52.0.62; our IP address is 10.52.253.79 ^^^^^^^^^^ CORRECT Filename '/home/ptyser/non_existant'. ^^^^^^^^^^^^^^^^^^^^^^^^^ CORRECT Load address: 0x100000 Loading: * TFTP error: 'File not found' (1) Starting again eTSEC2: No link. Speed: 100, half duplex Using eTSEC1 device TFTP from server 10.52.0.33; our IP address is 10.52.253.79 ^^^^^^^^^^ WRONG Filename '10.52.0.62'. ^^^^^^^^^^ WRONG Load address: 0x100000 Loading: * TFTP error: 'File not found' (1) Starting again TftpStart() was modified to not modify the 'BootFile' string. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-10-18net: Make TFTP server timeout configurableBartlomiej Sieka
There are two aspects of a TFTP transfer involving timeouts: 1. timeout waiting for initial server reply after sending RRQ 2. timeouts while transferring actual data from the server Since the upcoming auto-update feature attempts a TFTP download during each boot, it is undesirable to have a long delay when the TFTP server is not available. Thus, this commit makes the server timeout (1.) configurable by two global variables: TftpRRQTimeoutMSecs TftpRRQTimeoutCountMax TftpRRQTimeoutMSecs overrides default timeout when trying to connect to a TFTP server, TftpRRQTimeoutCountMax overrides default number of connection retries. The total delay when trying to download a file from a non-existing TFTP server is TftpRRQTimeoutMSecs x TftpRRQTimeoutCountMax milliseconds. Timeouts during file transfers (2.) are unaffected. Signed-off-by: Rafal Czubak <rcz@semihalf.com> Signed-off-by: Bartlomiej Sieka <tur@semihalf.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-10-18net: express the first argument to NetSetTimeout() in millisecondsBartlomiej Sieka
Enforce millisecond semantics of the first argument to NetSetTimeout() -- the change is transparent for well-behaving boards (CFG_HZ == 1000 and get_timer() countiing in milliseconds). Rationale for this patch is to enable millisecond granularity for network-related timeouts, which is needed for the upcoming automatic software update feature. Summary of changes: - do not scale the first argument to NetSetTimeout() by CFG_HZ - change timeout values used in the networking code to milliseconds Signed-off-by: Rafal Czubak <rcz@semihalf.com> Signed-off-by: Bartlomiej Sieka <tur@semihalf.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-09-02Don't tftp to unknown flashJochen Friedrich
If a board has a variable number of flash banks, there are empty entries in flash_info[] and CFG_DIRECT_FLASH_TFTP is set, tftp boot fails with "Outside available Flash". This patch skips flash banks with unknown flash ids. Signed-off-by: Jochen Friedrich <jochen@scram.de> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-07-09Fix printf errors.Andrew Klossner
The compiler will help find mismatches between printf formats and arguments if you let it. This patch adds the necessary attributes to declarations in include/common.h, then begins to correct the resulting compiler warnings. Some of these were bugs, e.g., "$d" instead of "%d" and incorrect arguments. Others were just annoying, like int-long mismatches on a system where both are 32 bits. It's worth fixing the annoying errors to catch the real ones. Signed-off-by: Andrew Klossner <andrew@cesa.opbu.xerox.com>
2008-02-14TFTP: fix search of ':' in BootFileJean-Christophe PLAGNIOL-VILLARD
2008-02-05TFTP: add host ip addr supportJean-Christophe PLAGNIOL-VILLARD
allow to use a different server as set in serverip add CONFIG_TFTP_FILE_NAME_MAX_LEN to configure the file name length if not defined the max length will be at 128 Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2007-11-18Fix warning differ in signedness in net/net.c and net/nfs.cJean-Christophe PLAGNIOL-VILLARD
2007-08-31Fix TFTP OACK code for short packets.Wolfgang Denk
The old code had a loop limit overflow bug which caused a semi- infinite loop for small packets, because in "i<len-8", "i" was signed, but "len" was unsigned, and "len-8" became a huge number for small values of "len". This is a workaround which replaces broken commit 8f1bc284. Signed-off-by: Wolfgang Denk <wd@denx.de>
