This commits update the support of sntp to use
the framework udp. This change allows to remove
all the reference to sntp in the main network
file net/net.c.
Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com>
Move this header out of the common header.
When setting the date, support driver model RTC also.
Rename this function so that it is clear that it is provided by the RTC.
Also return an error when it cannot function as expected. This is unlikely
to occur since it works for dates since 1752 and many RTCs do not support
such old dates. Still it is better to be accurate.
Acked-by: Heiko Schocher <hs@denx.de>
When SNTP is enabled and DATE is not, to_tm() is not built in. It could
be defined when TIMESTAMP is defined, so check for that.
Finish eliminating CamelCase from net.c and other failures
Make a thorough pass through all variables and function names contained
within sntp.c and remove CamelCase and improve naming.
This patch cleans up the names of internal packet buffer names that are
used within the network stack and the functions that use them.
Use "_ethaddr" at the end of variables and drop CamelCase.
Make constant values actually 'const'.
This patch is simply clean-up to make the IPv4 type that is used match
what Linux uses. It also attempts to move all variables that are IP
addresses use good naming instead of CamelCase. No functional change.
Call a built-in dummy if none is registered... don't require
protocols to register a handler (eliminating dummies)
NetConsole now uses the ARP handler when waiting on arp
(instead of needing a #define hack in arp.c)
Clear handlers at the end of net loop
Changes to NetState now go through an accessor function called
net_set_state()
Rename IP header related things to IP_UDP. The existing definition
of IP_t includes UDP header, so name it to accurately describe the
structure.
This is needed for the upcoming TFTP server implementation.
This also simplifies PingHandler() and fixes rxhand_f documentation.
Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it>
Acked-by: Detlev Zundel <dzu@denx.de>
Minor ./net cleanups - no functional changes
- change #ifdef DEBUG printf(); #endif to just debug()
- changed __FUNCTION__ to __func__
- got rid of extra whitespace between function and opening brace
- removed unnecessary braces on if statements
gcc dead code elimination should make this functionally/size equivalent
when DEBUG is not defined. (confirmed on Blackfin, with gcc 4.3.3).
Signed-off-by: Robin Getz <rgetz@blackfin.uclinux.org>
Enforce millisecond semantics of the first argument to NetSetTimeout() --
the change is transparent for well-behaving boards (CFG_HZ == 1000 and
get_timer() countiing in milliseconds).
Rationale for this patch is to enable millisecond granularity for
network-related timeouts, which is needed for the upcoming automatic
software update feature.
Summary of changes:
- do not scale the first argument to NetSetTimeout() by CFG_HZ
- change timeout values used in the networking code to milliseconds
Signed-off-by: Rafal Czubak <rcz@semihalf.com>
Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
This is a compatibility step that allows both the older form
and the new form to co-exist for a while until the older can
be removed entirely.
All transformations are of the form:
Before:
#if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT)
After:
#if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT) || defined(CONFIG_CMD_AUTOSCRIPT)
enable SNTP support in some boards.
add SNTP support and expand time server and time offset fields of
DHCP support. See doc/README.SNTP
* Patch by Steven Scholz, 13 Dec 2004:
Fix bug in at91rm920 ethernet driver
