path: root/net/rarp.c
2012-05-23net: Allow filtering on debug traces in the net subsystemJoe Hershberger
Add several levels of DEBUG prints so that you can limit the noise to the severety of your problem. DEBUG_LL_STATE = Link local state machine changes DEBUG_DEV_PKT = Packets or info directed to the device DEBUG_NET_PKT = Packets on info on the network at large DEBUG_INT_STATE = Internal network state changes Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-05-23net: Refactor packet length computationsJoe Hershberger
Save the length when it is computed instead of forgetting it and subtracting pointers to figure it out again. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-05-23net: cosmetic: Un-typedef ARP_tJoe Hershberger
Remove typedef and lower-case letters Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-05-23net: cosmetic: Un-typedef IP_tJoe Hershberger
Rename IP header related things to IP_UDP. The existing definition of IP_t includes UDP header, so name it to accurately describe the structure. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-05-23net: Move RARP receive logic out of net.cJoe Hershberger
Separate this functionality out of the net.c behemoth Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-05-15net: cosmetic: rarp.* checkpatch complianceJoe Hershberger
2012-05-15net: Remove volatile from net APIJoe Hershberger
2011-10-27net: Export auto_load, use it in rarpSimon Glass
The rarp code includes another instance of the auto_load logic, so call what is now net_auto_load() instead. This also fixes an incorrect call to TftpStart() which was never seen since apparently no boards enable rarp. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-05-12NET: pass source IP address to packet handlersLuca Ceresoli
This is needed for the upcoming TFTP server implementation. This also simplifies PingHandler() and fixes rxhand_f documentation. Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2009-12-13net: pull CONFIG checks out of source and into makefileMike Frysinger
Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-08-07minor debug cleanups in ./netRobin Getz
Minor ./net cleanups - no functional changes - change #ifdef DEBUG printf(); #endif to just debug() - changed __FUNCTION__ to __func__ - got rid of extra whitespace between function and opening brace - removed unnecessary braces on if statements gcc dead code elimination should make this functionally/size equivalent when DEBUG is not defined. (confirmed on Blackfin, with gcc 4.3.3). Signed-off-by: Robin Getz <rgetz@blackfin.uclinux.org> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-10-18net: express the first argument to NetSetTimeout() in millisecondsBartlomiej Sieka
Enforce millisecond semantics of the first argument to NetSetTimeout() -- the change is transparent for well-behaving boards (CFG_HZ == 1000 and get_timer() countiing in milliseconds). Rationale for this patch is to enable millisecond granularity for network-related timeouts, which is needed for the upcoming automatic software update feature. Summary of changes: - do not scale the first argument to NetSetTimeout() by CFG_HZ - change timeout values used in the networking code to milliseconds Signed-off-by: Rafal Czubak <rcz@semihalf.com> Signed-off-by: Bartlomiej Sieka <tur@semihalf.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2007-11-18Fix warning differ in signedness in net/net.c and net/nfs.cJean-Christophe PLAGNIOL-VILLARD
2007-07-10net/: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-09net/: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04net/: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2004-04-15Patches by Pantelis Antoniou, 30 Mar 2004:wdenk
add networking support for VLANs (802.1q), and CDP (Cisco Discovery Protocol)
2004-03-23* Patches by Thomas Viehweger, 16 Mar 2004:wdenk
- show PCI clock frequency on MPC8260 systems - add FCC_PSMR_RMII flag for HiP7 processors - in do_jffs2_fsload(), take load address from load_addr if not set explicit, update load_addr otherwise - replaced printf by putc/puts when no formatting is needed (smaller code size, faster execution)
2004-03-14* Patch by Travis Sawyer, 01 Mar 2004:wdenk
Ocotea: - Add IBM PPC440GX Ref Platform support (Ocotea) Original code by Paul Reynolds <PaulReynolds@lhsolutions.com> Adapted to U-Boot and 440GX port 440gx_enet.c: - Add gracious handling of all Ethernet Pin Selections for 440GX - Add RGMII selection for Cicada CIS8201 Gigabit PHY ppc440.h: - Add needed bit definitions - Fix formatting * Patch by Carl Riechers, 1 Mar 2004: Add PPC440GX prbdv0 divider to fix memory clock calculation. * Patch by Stephan Linz, 27 Feb 2004 - avoid problems for targets without NFS download support
2004-03-13* Patch by Rune Torgersen, 27 Feb 2004:wdenk
- Added LBA48 support (CONFIG_LBA48 & CFG_64BIT_LBA) - Added support for 64bit printing in vsprintf (CFG_64BIT_VSPRINTF) - Added support for 64bit strtoul (CFG_64BIT_STRTOUL) * Patch by Masami Komiya, 27 Feb 2004: Fix rarpboot: add autoload by NFS * Patch by Dan Eisenhut, 26 Feb 2004: fix flash_write return value in saveenv * Patch by Stephan Linz, 11 Dec 2003 expand config.mk to avoid trigraph warnings on NIOS * Rename "BMS2003" board into "HMI10"
2003-05-31* Patch by Marc Singer, 29 May 2003:LABEL_2003_05_31_2115wdenk
Fixed rarp boot method for IA32 and other little-endian CPUs. * Patch by Marc Singer, 28 May 2003: Added port I/O commands. * Patch by Matthew McClintock, 28 May 2003 - cpu/mpc824x/start.S: fix relocation code when booting from RAM - minor patches for utx8245 * Patch by Daniel Engström, 28 May 2003: x86 update * Patch by Dave Ellis, 9 May 2003 + 27 May 2003: add nand flash support to SXNI855T configuration fix/extend nand flash support: - fix 'nand erase' command so does not erase bad blocks - fix 'nand write' command so does not write to bad blocks - fix nand_probe() so handles no flash detected properly - add doc/README.nand - add .jffs2 and .oob options to nand read/write - add 'nand bad' command to list bad blocks - add 'clean' option to 'nand erase' to write JFFS2 clean markers - make NAND read/write faster * Patch by Rune Torgersen, 23 May 2003: Update for MPC8266ADS board
