path: root/net/rarp.c
2015-04-18net: cosmetic: Fix checkpatch.pl failures in net.cJoe Hershberger
Finish eliminating CamelCase from net.c and other failures Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Clean up RARP variables and functionsJoe Hershberger
Make a thorough pass through all variables and function names contained within rarp.c and remove CamelCase and improve naming. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Cleanup internal packet buffer namesJoe Hershberger
This patch cleans up the names of internal packet buffer names that are used within the network stack and the functions that use them. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2015-04-18net: cosmetic: Name ethaddr variables consistentlyJoe Hershberger
Use "_ethaddr" at the end of variables and drop CamelCase. Make constant values actually 'const'. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Change IPaddr_t to struct in_addrJoe Hershberger
This patch is simply clean-up to make the IPv4 type that is used match what Linux uses. It also attempts to move all variables that are IP addresses use good naming instead of CamelCase. No functional change. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2012-05-23net: Allow filtering on debug traces in the net subsystemJoe Hershberger
Add several levels of DEBUG prints so that you can limit the noise to the severety of your problem. DEBUG_LL_STATE = Link local state machine changes DEBUG_DEV_PKT = Packets or info directed to the device DEBUG_NET_PKT = Packets on info on the network at large DEBUG_INT_STATE = Internal network state changes Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-05-23net: Refactor packet length computationsJoe Hershberger
Save the length when it is computed instead of forgetting it and subtracting pointers to figure it out again. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-05-23net: cosmetic: Un-typedef ARP_tJoe Hershberger
Remove typedef and lower-case letters Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-05-23net: cosmetic: Un-typedef IP_tJoe Hershberger
Rename IP header related things to IP_UDP. The existing definition of IP_t includes UDP header, so name it to accurately describe the structure. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-05-23net: Move RARP receive logic out of net.cJoe Hershberger
Separate this functionality out of the net.c behemoth Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-05-15net: cosmetic: rarp.* checkpatch complianceJoe Hershberger
2012-05-15net: Remove volatile from net APIJoe Hershberger
2011-10-27net: Export auto_load, use it in rarpSimon Glass
The rarp code includes another instance of the auto_load logic, so call what is now net_auto_load() instead. This also fixes an incorrect call to TftpStart() which was never seen since apparently no boards enable rarp. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-05-12NET: pass source IP address to packet handlersLuca Ceresoli
This is needed for the upcoming TFTP server implementation. This also simplifies PingHandler() and fixes rxhand_f documentation. Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2009-12-13net: pull CONFIG checks out of source and into makefileMike Frysinger
Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-08-07minor debug cleanups in ./netRobin Getz
Minor ./net cleanups - no functional changes - change #ifdef DEBUG printf(); #endif to just debug() - changed __FUNCTION__ to __func__ - got rid of extra whitespace between function and opening brace - removed unnecessary braces on if statements gcc dead code elimination should make this functionally/size equivalent when DEBUG is not defined. (confirmed on Blackfin, with gcc 4.3.3). Signed-off-by: Robin Getz <rgetz@blackfin.uclinux.org> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-10-18net: express the first argument to NetSetTimeout() in millisecondsBartlomiej Sieka
Enforce millisecond semantics of the first argument to NetSetTimeout() -- the change is transparent for well-behaving boards (CFG_HZ == 1000 and get_timer() countiing in milliseconds). Rationale for this patch is to enable millisecond granularity for network-related timeouts, which is needed for the upcoming automatic software update feature. Summary of changes: - do not scale the first argument to NetSetTimeout() by CFG_HZ - change timeout values used in the networking code to milliseconds Signed-off-by: Rafal Czubak <rcz@semihalf.com> Signed-off-by: Bartlomiej Sieka <tur@semihalf.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2007-11-18Fix warning differ in signedness in net/net.c and net/nfs.cJean-Christophe PLAGNIOL-VILLARD
2007-07-10net/: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-09net/: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04net/: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2004-04-15Patches by Pantelis Antoniou, 30 Mar 2004:wdenk
add networking support for VLANs (802.1q), and CDP (Cisco Discovery Protocol)
2004-03-23* Patches by Thomas Viehweger, 16 Mar 2004:wdenk
- show PCI clock frequency on MPC8260 systems - add FCC_PSMR_RMII flag for HiP7 processors - in do_jffs2_fsload(), take load address from load_addr if not set explicit, update load_addr otherwise - replaced printf by putc/puts when no formatting is needed (smaller code size, faster execution)
2004-03-14* Patch by Travis Sawyer, 01 Mar 2004:wdenk
Ocotea: - Add IBM PPC440GX Ref Platform support (Ocotea) Original code by Paul Reynolds <PaulReynolds@lhsolutions.com> Adapted to U-Boot and 440GX port 440gx_enet.c: - Add gracious handling of all Ethernet Pin Selections for 440GX - Add RGMII selection for Cicada CIS8201 Gigabit PHY ppc440.h: - Add needed bit definitions - Fix formatting * Patch by Carl Riechers, 1 Mar 2004: Add PPC440GX prbdv0 divider to fix memory clock calculation. * Patch by Stephan Linz, 27 Feb 2004 - avoid problems for targets without NFS download support
2004-03-13* Patch by Rune Torgersen, 27 Feb 2004:wdenk
- Added LBA48 support (CONFIG_LBA48 & CFG_64BIT_LBA) - Added support for 64bit printing in vsprintf (CFG_64BIT_VSPRINTF) - Added support for 64bit strtoul (CFG_64BIT_STRTOUL) * Patch by Masami Komiya, 27 Feb 2004: Fix rarpboot: add autoload by NFS * Patch by Dan Eisenhut, 26 Feb 2004: fix flash_write return value in saveenv * Patch by Stephan Linz, 11 Dec 2003 expand config.mk to avoid trigraph warnings on NIOS * Rename "BMS2003" board into "HMI10"
2003-05-31* Patch by Marc Singer, 29 May 2003:LABEL_2003_05_31_2115wdenk
Fixed rarp boot method for IA32 and other little-endian CPUs. * Patch by Marc Singer, 28 May 2003: Added port I/O commands. * Patch by Matthew McClintock, 28 May 2003 - cpu/mpc824x/start.S: fix relocation code when booting from RAM - minor patches for utx8245 * Patch by Daniel Engström, 28 May 2003: x86 update * Patch by Dave Ellis, 9 May 2003 + 27 May 2003: add nand flash support to SXNI855T configuration fix/extend nand flash support: - fix 'nand erase' command so does not erase bad blocks - fix 'nand write' command so does not write to bad blocks - fix nand_probe() so handles no flash detected properly - add doc/README.nand - add .jffs2 and .oob options to nand read/write - add 'nand bad' command to list bad blocks - add 'clean' option to 'nand erase' to write JFFS2 clean markers - make NAND read/write faster * Patch by Rune Torgersen, 23 May 2003: Update for MPC8266ADS board
