path: root/net/nfs.c
2008-02-14NFS Timeout with large files.Hiroshi Ito
Retry to send NFS packet before reaching timeout. Signed-off-by: Hiroshi Ito <ito@mlb.co.jp>
2007-11-18Fix warning differ in signedness in net/net.c and net/nfs.cJean-Christophe PLAGNIOL-VILLARD
2007-11-03Fix typo in nfs.cGuennadi Liakhovetski
An obvious typo. Originally fixed in linkstation u-boot port. Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
2007-07-11Fix some compile problems introduced by the latest CFG_CMD_xxx cleanupStefan Roese
2007-07-09net/: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04net/: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2005-08-06Fix return code of NFS commandWolfgang Denk
Patch by Hiroshi Ito, 11 Dec 2004
2005-08-04Fix endianess problem in TFTP / NFS default filenamesWolfgang Denk
Patch by Hiroshi Ito, 06 Dec 2004
2004-09-28* Patch by Ganapathi C, 04 Aug 2004:wdenk
Fix NFS timeout issue
2004-06-30* Fix "cls" command when used with splash screenLABEL_2004_07_01_1200wdenk
* Increase NFS download timeout (now 1 min - 10 sec is to short for a slow download of a big image)
2004-04-15Patches by Pantelis Antoniou, 30 Mar 2004:wdenk
add networking support for VLANs (802.1q), and CDP (Cisco Discovery Protocol)
2004-03-23* Patches by Thomas Viehweger, 16 Mar 2004:wdenk
- show PCI clock frequency on MPC8260 systems - add FCC_PSMR_RMII flag for HiP7 processors - in do_jffs2_fsload(), take load address from load_addr if not set explicit, update load_addr otherwise - replaced printf by putc/puts when no formatting is needed (smaller code size, faster execution)
2004-03-14* Patch by Yuli Barcohen, 4 Mar 2004:wdenk
Fix problems with GCC 3.3.x which changed handling of global variables explicitly initialized to zero (now in .bss instead of .data as before). * Patch by Leon Kukovec, 02 Mar 2004: add strswab() to fix IDE LBA capacity, firmware and model numbers on little endian machines * Patch by Masami Komiya, 02 Mar 2004: - Remove get_ticks() from NFS code - Add verification of RPC transaction ID * Patch by Pierre Aubert, 02 Mar 2004: cleanup for IDE and USB drivers for MPC5200
2004-02-27* Patch by Steven Scholz, 25 Feb 2004:wdenk
- Timeouts in FPGA code should be based on CFG_HZ - Minor cleanup in code for Altera FPGA ACEX1K * Patch by Steven Scholz, 25 Feb 2004: Changed "Directory Hierarchy" section in README * Patch by Masami Komiya, 25 Feb 2004: Reduce copy count in nfs_read_reply() of NFS code
2004-02-24* Patch by Masami Komiya, 24 Feb 2004:wdenk
Update NetBootFileXferSize in NFS code * Patch by Scott McNutt, 24 Feb 2004: fix packet length in NFS code
2004-02-24* Patch by Masami Komiy, 22 Feb 2004:wdenk
Add support for NFS for file download * Minor code cleanup
