path: root/net/net.c
2010-01-17Make getenv_IPaddr() globalDirk Behme
There are boards out there that do not have network support in U-Boot (CONFIG_CMD_NET not set), but they do so in Linux. This makes it desirable to be able to port network configuration (like the IP address) to the Linux kernel. We should not make the passing of the IP configuration to Linux dependent on U-Boot features / settings. For this, make getenv_IPaddr() global. This fixes build error u-boot/lib_xxx/board.c:360: undefined reference to `getenv_IPaddr' on various architectures. Signed-off-by: Dirk Behme <dirk.behme@googlemail.com> Acked-by: Ben Warren <biggerbadderben@gmail.com>
2009-12-13net: pull CONFIG checks out of source and into makefileMike Frysinger
Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-11-24Repair the 'netretry=once' option.Remy Bohmer
'netretry = once' does the same as 'netretry = yes', because it is not stored when it was tried once. Signed-off-by: Remy Bohmer <linux@bohmer.net> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-08-25net: defragment IP packetsAlessandro Rubini
The defragmenting code is enabled by CONFIG_IP_DEFRAG; the code is useful for TFTP and NFS transfers. The user can specify the maximum defragmented payload as CONFIG_NET_MAXDEFRAG (default 16k). Since NFS has a bigger per-packet overhead than TFTP, the static reassembly buffer can hold CONFIG_NET_MAXDEFRAG + the NFS overhead. The packet buffer is used as an array of "hole" structures, acting as a double-linked list. Each new fragment can split a hole in two, reduce a hole or fill a hole. No support is there for a fragment overlapping two diffrent holes (i.e., thre new fragment is across an already-received fragment). Signed-off-by: Alessandro Rubini <rubini@gnudd.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-08-07minor debug cleanups in ./netRobin Getz
Minor ./net cleanups - no functional changes - change #ifdef DEBUG printf(); #endif to just debug() - changed __FUNCTION__ to __func__ - got rid of extra whitespace between function and opening brace - removed unnecessary braces on if statements gcc dead code elimination should make this functionally/size equivalent when DEBUG is not defined. (confirmed on Blackfin, with gcc 4.3.3). Signed-off-by: Robin Getz <rgetz@blackfin.uclinux.org> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-07-22Save server's MAC address in environmentRobin Getz
Linux's netconsole works much better when you can pass it the MAC address of the server. (otherwise it just uses broadcast, which everyone else on my network complains about :) This sets the env var "serveraddr" (to match ethaddr), so that you can pass it to linux with whatever bootargs you want to.... addnetconsole=set bootargs $(bootargs) netconsole=@$(ipaddr)/eth0,@$(serverip)/$(serveraddr) Signed-of-by: Robin Getz <rgetz@blackfin.uclinux.org> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-07-22DHCP regression on 2009-06Michael Zaidman
Fixed the DHCP/BOOTP/RARP regression introduced in u-boot-2009.06 by initializing our IP addr to 0 in order to accept any IP addr assigned to us by the DHCP/BOOTP/RARP server. Ack-by: Robin Getz <rgetz@blackfin.uclinux.org> Signed-off-by: Michael Zaidman <michael.zaidman@gmail.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-07-22Add DNS supportRobin Getz
On 04 Oct 2008 Pieter posted a dns implementation for U-Boot. http://www.mail-archive.com/u-boot-users@lists.sourceforge.net/msg10216.html > > DNS can be enabled by setting CFG_CMD_DNS. After performing a query, > the serverip environment var is updated. > > Probably there are some cosmetic issues with the patch. Unfortunatly I > do not have the time to correct these. So if anybody else likes DNS > support in U-Boot and has the time, feel free to patch it in the main tree. Here it is again - slightly modified & smaller: - update to 2009-06 (Pieter's patch was for U-Boot 1.2.0) - README.dns is added - syntax is changed (now takes a third option, the env var to store the result in) - add a random port() function in net.c - sort Makefile in ./net/Makefile - dns just returns unless a env var is given - run through checkpatch, and clean up style issues - remove packet from stack - cleaned up some comments - failure returns much faster (if server responds, don't wait for timeout) - use built in functions (memcpy) rather than byte copy. Signed-off-by: Robin Getz <rgetz@blackfin.uclinux.org> Signed-off-by: Pieter Voorthuijsen <pieter.voorthuijsen@prodrive.nl> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-07-22net: rename NetRxPkt to NetRxPacketMike Frysinger
The net code is mostly consistent in using 'Packet' rather than 'Pkt', so rename the minor detractor to follow suite. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-05-15netloop: updates for NetLoopHeiko Schocher
Fix some issues introduced from commit: 2f70c49e5b9813635ad73666aa30f304c7fdeda9 suggested by Mike Frysinger. - added some comment for the env_id variable in common_cmd_nvedit.c - moved some variables in fn scope instead of file scope - NetInitLoop now static void Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Ben Warren <biggerbadderben@gmail.com>
2009-04-19NetLoop initialization bugMichael Zaidman
The patch fixes the bug of partial initialization of global network parameters. Upon u-boot's start up the first ping command causes a failure of the consequent TFTP command. It happens in the recently added mechanism of the NetLoop initialization where initialization of global network parameters is separated in the NetInitLoop routine which is called per env_id change. Thus, ping request will initialize the network parameters necessary for ping operation only, afterwards the env_changed_id will be set to the env_id that will prevent all following initialization requests from other protocols. The problem is that the initialized by ping subset of network parameters is not sufficient for other protocols and particularly for TFTP which requires the NetServerIp also. Signed-off-by: Michael Zaidman <michael.zaidman@gmail.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-03-20net: get mac address from environment and use eth util funcsMike Frysinger
Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com>
2009-03-20convert print_IPaddr() to %pI4Mike Frysinger
Now that our printf functions support the %pI4 modifier like the kernel, let's drop the inflexible print_IPaddr() function and covert over to the %pI4 modifier. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com>
2009-02-22netloop: speed up NetLoopHeiko Schocher
NetLoop polls every cycle with getenv some environment variables. This is horribly slow, especially when the environment is big. This patch reads only the environment variables in NetLoop, when they were changed. Also moved the init part of the NetLoop function in a seperate function. Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-01-28Fix IP alignment problemOlav Morken
This patch removes volatile from: volatile IP_t *ip = (IP_t *)xip; Due to a bug, avr32-gcc will assume that ip is aligned on a word boundary when using volatile, which causes an exception since xip isn't aligned on a word boundary. Signed-off-by: Gunnar Rangoy <gunnar@rangoy.com> Signed-off-by: Paul Driveklepp <pauldriveklepp@gmail.com> Signed-off-by: Olav Morken <olavmrk@gmail.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-12-09Merge branch 'master' of git://git.denx.de/u-boot-netWolfgang Denk
2008-12-06Update U-Boot's build timestamp on every compilePeter Tyser
Use the GNU 'date' command to auto-generate a new U-Boot timestamp on every compile. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-12-04net: Add additional IP fragmentation checkPeter Tyser
Ignore IP packets which have the "more fragments" flag bit set. This flag indicates the IP packet is fragmented and must be ignored by U-Boot. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-12-04net: Define IP flag field valuesPeter Tyser
These defines were pulled from the "Add simple IP/UDP fragmentation support" patch from Frank Haverkamp <haver@vnet.ibm.com>. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-10-18net: express the first argument to NetSetTimeout() in millisecondsBartlomiej Sieka
Enforce millisecond semantics of the first argument to NetSetTimeout() -- the change is transparent for well-behaving boards (CFG_HZ == 1000 and get_timer() countiing in milliseconds). Rationale for this patch is to enable millisecond granularity for network-related timeouts, which is needed for the upcoming automatic software update feature. Summary of changes: - do not scale the first argument to NetSetTimeout() by CFG_HZ - change timeout values used in the networking code to milliseconds Signed-off-by: Rafal Czubak <rcz@semihalf.com> Signed-off-by: Bartlomiej Sieka <tur@semihalf.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-07-13Fix some more printf() format issues.Wolfgang Denk
2008-07-13Fix some more printf() format issues.Jean-Christophe PLAGNIOL-VILLARD
2008-07-11Fix some more print() format errors.Wolfgang Denk
2008-06-04Get rid of annoying/superfluous bad-checksum warning messageRemy Bohmer
U-boot can complain a lot about 'checksum bad' when it is attached to the network. It is annoying for ordinary users who start to doubt the network connection in general when they see messages like this. This is caused by the routine NetCksumOk() which cannot handle IP-headers longer than 20 bytes. Those packages can be ignored anyway by U-boot, so we trash them now before checking the checksum. Signed-off-by: Remy Bohmer <linux@bohmer.net> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-04-28net: make ARP timeout configurableGuennadi Liakhovetski
Currently the timeout waiting for an ARP reply is hard set to 5 seconds. On i.MX31ADS due to a hardware "strangeness" up to four first IP packets to the boards get lost, which typically are ARP replies. By configuring the timeout to a lower value we significantly improve the first network transfer time on this board. The timeout is specified in milliseconds, later internally it is converted to deciseconds, because it has to be converted to hardware ticks, and CFG_HZ ranges from 900 to 27000000 on different boards. Signed-off-by: Guennadi Liakhovetski <lg@denx.de> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-01-03net: Add CONFIG_NET_DO_NOT_TRY_ANOTHER optionMatthias Fuchs
When CONFIG_NET_DO_NOT_TRY_ANOTHER is defined U-Boot's networking stack does not automatically switch to another interface. This patch does not touch the default behavior. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-01-03Introduce new eth_receive routineRafal Jaworowski
The purpose of this routine is receiving a single network frame, outside of U-Boot's NetLoop(). Exporting it to standalone programs that run on top of U-Boot will let them utilise networking facilities. For sending a raw frame the already existing eth_send() can be used. The direct consumer of this routine is the newly introduced API layer for external applications (enabled with CONFIG_API). Signed-off-by: Rafal Jaworowski <raj@semihalf.com> Signed-off-by: Piotr Kruszynski <ppk@semihalf.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2007-11-18Fix warning differ in signedness in net/net.c and net/nfs.cJean-Christophe PLAGNIOL-VILLARD
2007-09-12Fix memory corruption problem on STX GP3 SSA Board.Wolfgang Denk
2007-08-14Coding style cleanup; rebuild CHANGELOGWolfgang Denk
2007-08-13multicast tftp: RFC2090David Updegraff
Implemented IETF RFC2090, Multicast TFTP. Initial implementation on Realtek RTL8139 and Freescale TSEC. Signed-off-by: David Updegraff <dave@cray.com> Signed-off-by: Ben Warren <bwarren@qstreams.com>
2007-07-10net/: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-09Finally retire cmd_confdefs.h and CONFIG_BOOTP_MASK!Jon Loeliger
All of the choices for CONFIG_BOOTP_ are now documented in the README file. You must now individually select exactly the set that you want using a series of #define CONFIG_BOOTP_<x> statements in the board port config files now. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2007-07-09net/: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04net/: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2007-03-07net - Support ping reply when processing net-loopEd Swarthout
Add ICMP_ECHO_REQUEST packet support by responding with a ICMP_ECHO_REPLY. This permits the ping command to test the phy interface when the phy is put in loopback mode (typically by setting register 0 bit 14). It also allows the port to respond to an external ping when u-boot is processing some other net command (such as tftp). This is useful when tftp appears to hang. Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com> Signed-off-by: Ben Warren <bwarren@qstreams.com>
2006-03-12Fix behaviour if gatewayip is not setWolfgang Denk
Patch by Robin Gilks, 23 Dec 2004
2005-11-10Add explanation for CDP checksum algorithmWolfgang Denk
2005-10-28Add support for multiple PHYs.Marian Balakowicz
2005-08-31Add I2C support to TQM8540 and TQM8560 boards (EEPROM, RTC, LM75-DTT).Stefan Roese
Removed CFG_CMD_DISPLAY from default commands. Fixed compiler warning in net.c. Patch by Stefan Roese, 31 Aug 2005
2005-08-26Prepare U-Boot for gcc-4.xWolfgang Denk
2005-08-12Minor code cleanupWolfgang Denk
2005-08-12Add UPD-Checksum code, fix problem in net.c (return instead of break)Stefan Roese
Patch by Reinhard Arlt, 12 Aug 2005
2005-05-03README: add explanation about patch policywdenk
net/net.c: fix indentation
2005-04-03Patch by David Adair, 27 Oct 2004:wdenk
Add missing 440GX SDRAM Controller reset
2005-04-03* Patch by Richard Klingler, 03 Apr 2005:wdenk
Add call to eth_halt() in net/net.c when called functions fail after eth_init() has been called. * Patch by Sam Song, 3 April 2005: - Update README.Netconsole - Update README
