Previously u-boot would initialize the network interface for every
network operation and then shut it down again. This makes sense for
most operations where the network in not known to be needed soon after
the operation is complete. In the case of netconsole, it will use the
network for every interaction with the shell or every printf. This
means that the network is being reinitialized very often. On many
devices, this intialization is very slow.
This patch checks for consecutive netconsole actions and leaves the
ethernet hardware initialized between them. It will still behave the
same old way for all other network operations and any time another
network operation happens between netconsole operations.
NetSetTimeout sets incorrect value to timeDelta when CONFIG_SYS_HZ != 1000.
Signed-off-by: Tetsuyuki Kobayashi <koba@kmckk.co.jp>
NetConsole may call NetSendUDPPacket before NetLoop is called. This
will cause the source MAC address (NetOurEther) to be wrong. Instead
of only changing it in NetLoop, move it to NetLoopInit so that it is
also updated when net_init() is called (especially by nc_start()).
Reported-by: Michael Walle <michael@walle.cc>
Acked-by: Michael Walle <michael@walle.cc>
Add several levels of DEBUG prints so that you can limit the noise to
the severety of your problem.
DEBUG_LL_STATE = Link local state machine changes
DEBUG_DEV_PKT = Packets or info directed to the device
DEBUG_NET_PKT = Packets on info on the network at large
DEBUG_INT_STATE = Internal network state changes
Code based on networking/zcip.c in busybox
commit 8531d76a15890c2c535908ce888b2e2aed35b172
Use the NetArpTxPacket for the ARP packet, not to hold what used to
be in NetTxPacket.
This saves a copy and makes the code easier to understand.
A new non-static function net_init() will initialize buffers and
read from the environment. Only update from the env on each entry
to NetLoop().
Noone uses it.
When the network is VLAN or SNAP, net_update_ether() will preserve
the original Ethernet packet header and simply replace the src and
dest MACs and the protocol
Call a built-in dummy if none is registered... don't require
protocols to register a handler (eliminating dummies)
NetConsole now uses the ARP handler when waiting on arp
(instead of needing a #define hack in arp.c)
Clear handlers at the end of net loop
Changes to NetState now go through an accessor function called
net_set_state()
Use this entry-point consistently across the net/ code
Use a static inline function to preserve code size
Share more of the code that is common between ARP vs not.
ICMP (ping) was reimplementing IP header code... it now shares code.
Easier to find when alphabetized
This is not called as a handler, so don't name it that way
x is a poor variable name
Make the comment more accurate about the header including SNAP
This name more explicitly claims that it does not include the
header size
Remove typedef and lower-case name
Eliminate the typedef and remove capital letters
Separate the Ethernet header from the 802 header.
Base the size constants on the structs.
Add a structure that only contains IP header fields to be used by
functions that don't need UDP
Rename IP_HDR_SIZE_NO_UDP to IP_HDR_SIZE
Rename IP header related things to IP_UDP. The existing definition
of IP_t includes UDP header, so name it to accurately describe the
structure.
Separate this functionality out of the net.c behemoth
Checking for CDP packets should be encapsulated, not copied code.
This field gets read in one place (by "bdinfo"), and we can replace
that with getenv("ipaddr"). After all, the bi_ip_addr field is kept
up-to-date implicitly with the value of the ipaddr env var.
Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
This inserts bootstage calls into tftp, usb start and bootm. We
could go further, but this is a reasonable start to illustrate
the concept.
When building u-boot as 64 bit application (e.g. sandbox) ulong might be
64 bits in size. This breaks network code as IPaddr_t is 64 bytes in
size then and an IPv4 address is 32 bits in size. This patch makes sure
that IPaddr_t is always 32 bits in size. Also some warnings introduced
by this patch are fixed.
Signed-off-by: Matthias Weisser <weisserm@arcor.de>
Fix:
net.c: In function 'CDPHandler':
net.c:1083:8: warning: variable 'applid' set but not used
[-Wunused-but-set-variable]
The rarp code includes another instance of the auto_load logic, so call
what is now net_auto_load() instead.
This also fixes an incorrect call to TftpStart() which was never seen
since apparently no boards enable rarp.
This is intended purely as a code size reduction.
This commit reduces code size a little by making the ICMP handler only
available to tftpput. This is reasonable since it is the only user at
present (ping just uses the normal handler).
This adds logic to tftp.c to implement the tftp 'put' command, and
updates the README.
This is a better name for this protocol. Also remove the typedef to keep
checkpatch happy, and move zeroing of NetBootFileXferSize a little
earlier since TFTPPUT will need to change this.
ICMP packets can tell you when there is no server at the other end. It
is useful for tftp to figure this out, so that a quick error can be
displayed, rather than pointlessly retrying.
This adds an ICMP packet handler to the net interface.
NetReceive() is a very long function with a lot of indent. Before adding
code to the ICMP bit, split it out.
This is long over due. All but two net drivers have been converted, but
those have now been dropped.
The only thing left to do is actually delete all references to NET_MULTI
and code that is compiled when that is not defined. So here we scrub the
core code.
At least on ARM the ipaddr is only set in board_init_r function. The
problem is if ipaddr is not defined in environment importing another
environment defined don't update the ipaddr value.
For example, suppose we've a default environment without net variables
defined and we want to import an uEnv.txt environment from SD-card like
this:
ipaddr=192.168.2.240
netmask=255.255.255.0
gatewayip=192.168.2.1
serverip=192.168.2.114
Then if you try boot from NFS results in:
Importing environment from mmc ...
Running uenvcmd ...
smc911x: detected LAN9221 controller
smc911x: phy initialized
smc911x: MAC ac:de:48:00:00:00
*** ERROR: `ipaddr' not set
The ipaddr at this point is NULL beacause is only set at board_init_r
function. This patch updates the ipaddr value if the environment has
changed.
Signed-off-by: Enric Balletbo i Serra <eballetbo@iseebcn.com>
Signed-off-by: Luca Ceresoli <luca.ceresoli@comelit.it>
Acked-by: Detlev Zundel <dzu@denx.de>
This removes the following checkpatch issue:
- ERROR: do not use assignment in if condition
Cc: Ben Warren <biggerbadderben@gmail.com>
This removes the following checkpatch issues:
- ERROR: switch and case should be at the same indent
- WARNING: suspect code indent for conditional statements
- WARNING: labels should not be indented
- ERROR: return is not a function, parentheses are not required
- ERROR: "foo * bar" should be "foo *bar"
- ERROR: "(foo*)" should be "(foo *)"
- WARNING: braces {} are not necessary for single statement blocks
- WARNING: braces {} are not necessary for any arm of this statement
