path: root/net/net.c
2015-04-18net: cosmetic: Clean up DNS variables and functionsJoe Hershberger
Make a thorough pass through all variables and function names contained within dns.c and remove CamelCase and improve naming. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Clean up CDP variables and functionsJoe Hershberger
Make a thorough pass through all variables and function names contained within cdp.c and remove CamelCase and improve naming. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Clean up SNTP variables and functionsJoe Hershberger
Make a thorough pass through all variables and function names contained within sntp.c and remove CamelCase and improve naming. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Clean up RARP variables and functionsJoe Hershberger
Make a thorough pass through all variables and function names contained within rarp.c and remove CamelCase and improve naming. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Clean up NFS variables and functionsJoe Hershberger
Make a thorough pass through all variables and function names contained within nfs.c and remove CamelCase and improve naming. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Clean up DHCP variables and functionsJoe Hershberger
Make a thorough pass through all variables and function names contained within bootp.c and remove CamelCase and improve naming. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Clean up ARP variables and functionsJoe Hershberger
Make a thorough pass through all variables and function names contained within arp and remove CamelCase and improve naming. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Clean up TFTP variables and functionsJoe Hershberger
Make a thorough pass through all variables and function names contained within tftp and remove CamelCase and improve naming. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Fix var naming net <-> eth driversJoe Hershberger
Update the naming convention used in the network stack functions and variables that Ethernet drivers use to interact with it. This cleans up the temporary hacks that were added to this interface along with the DM support. This patch has a few remaining checkpatch.pl failures that would be out of the scope of this patch to fix (drivers that are in gross violation of checkpatch.pl). Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Cleanup internal packet buffer namesJoe Hershberger
This patch cleans up the names of internal packet buffer names that are used within the network stack and the functions that use them. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2015-04-18net: cosmetic: Name ethaddr variables consistentlyJoe Hershberger
Use "_ethaddr" at the end of variables and drop CamelCase. Make constant values actually 'const'. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Fixup var names for DHCP stringsJoe Hershberger
Remove CamelCase variable naming. Move the definition to the same compilation unit as the primary use. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Fixup var names related to boot fileJoe Hershberger
The variables around the bootfile were inconsistent and used CamelCase. Update them to make the code more readable. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Change IPaddr_t to struct in_addrJoe Hershberger
This patch is simply clean-up to make the IPv4 type that is used match what Linux uses. It also attempts to move all variables that are IP addresses use good naming instead of CamelCase. No functional change. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: Improve error handlingJoe Hershberger
Take a pass at plumbing errors through to the users of the network stack Currently only the start() function errors will be returned from NetLoop(). recv() tends not to have errors, so that is likely not worth adding. send() certainly can return errors, but this patch does not attempt to plumb them yet. halt() is not expected to error. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-04-18net: Clean up network stack names used in DM driversJoe Hershberger
Take the opportunity to enforce better names on newly written or retrofitted Ethernet drivers. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-04-18net: Make netretry actually do somethingJoe Hershberger
netretry previously would only retry in one specific case (your MAC address is not set) and no other. This is basically useless. In the DM implementation for eth it turns this into a completely useless case since an un-configured MAC address results in not even entering the NetLoop. The behavior is now changed to retry any failed command (rotating through the eth adapters if ethrotate != no). It also defaulted to retry forever. It is now changed to default to not retry Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-04-18net: Remove the bd* parameter from net stack functionsJoe Hershberger
This value is not used by the network stack and is available in the global data, so stop passing it around. For the one legacy function that still expects it (init op on old Ethernet drivers) pass in the global pointer version directly to avoid changing that interface. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reported-by: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org> (Trival fix to remove an unneeded variable declaration in 4xx_enet.c)
2015-04-18net: Provide a function to get the current MAC addressJoe Hershberger
The current implementation exposes the eth_device struct to code that needs to access the MAC address. Add a wrapper function for this to abstract away the pointer for this operation. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-02-12net: Use new checksum functionsSimon Glass
Drop the old checksum functions in favour of the new ones. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2014-10-10SPDX License cleanup for LiMon imported filesWolfgang Denk
A number of network related files were imported from the LiMon project; these contain a somewhat unclear license statement: Copyright 1994 - 2000 Neil Russell. (See License) I analyzed the source code of LiMon v1.4.2 which was used for this import. It does not contain any "License" file, but the top level directory contains a file "COPYING", which turns out to be GPL v2 of June 1991. So it is legitimate to conclude that the LiMon derived files are also to be released under GPLv2. Mark them as such. Signed-off-by: Wolfgang Denk <wd@denx.de>
2014-08-09net: BOOTP retry timeout improvementsStephen Warren
Currently, the BOOTP code sends out its initial request as soon as the Ethernet driver indicates "link up". If this packet is lost or not replied to for some reason, the code waits for a 1s timeout before retrying. For some reason, such early packets are often lost on my system, so this causes an annoying delay. To optimize this, modify the BOOTP code to have very short timeouts for the first packet transmitted, but gradually increase the timeout each time a timeout occurs. This way, if the first packet is lost, the second packet is transmitted quite quickly and hence the overall delay is low. However, if there's still no response, we don't keep spewing out packets at an insane speed. It's arguably more correct to try and find out why the first packet is lost. However, it seems to disappear inside my Ethenet chip; the TX chip indicates no error during TX (not that it has much in the way of reporting...), yet wireshark on the RX side doesn't see any packet. FWIW, I'm using an ASIX USB Ethernet adapter. Perhaps "link up" is reported too early or based on the wrong condition in HW, and we should add some fixed extra delay into the driver. However, this would slow down every link up event even if it ends up not being needed in some cases. Having BOOTP retry quickly applies the fix/WAR to every possible Ethernet device, and is quite simple to implement, so seems a better solution. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2014-06-19fix: CONFIG_NETCONSOLE start/handle this stuff only outside SPLHannes Petermaier
SPL stage does not support various networking things, and therefore CONFIG_NETCONSOLE cannot be built within SPL. Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
2013-08-26NET: Add net_busy_flag if CONFIG_USB_KEYBOARD is definedJim Lin
This flag is to make console aware that NET transfer is running or not. Signed-off-by: Jim Lin <jilin@nvidia.com>
2013-06-19NET: Fix system hanging if NET device is not installedJim Lin
If we try to boot from NET device, NetInitLoop in net.c will be invoked. If NET device is not installed, eth_get_dev() function will return eth_current value, which is NULL. When NetInitLoop is called, "eth_get_dev->enetaddr" will access restricted memory area and therefore cause hanging. This issue is found on Tegra30 Cardhu platform after adding CONFIG_CMD_NET and CONFIG_CMD_DHCP in config header file. Signed-off-by: Jim Lin <jilin@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2013-02-28net: Use new numeric setenv functionsSimon Glass
Use setenv_ulong(), setenv_hex() and setenv_addr() in net/ Signed-off-by: Simon Glass <sjg@chromium.org>
2012-12-13env: Add a bootfile env handlerJoe Hershberger
Remove the hard-coded bootfile handler and use a callback instead Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-12-13env: Use getenv_yesno() more generallyJoe Hershberger
Move the getenv_yesno() to env_common.c and change most checks for 'y' or 'n' to use this helper. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-11-04net/: sparse fixesKim Phillips
bootp.c:44:14: warning: symbol 'dhcp_state' was not declared. Should it be static? bootp.c:45:15: warning: symbol 'dhcp_leasetime' was not declared. Should it be static? bootp.c:46:10: warning: symbol 'NetDHCPServerIP' was not declared. Should it be static? arp.c:30:17: warning: symbol 'NetArpWaitReplyIP' was not declared. Should it be static? arp.c:37:16: warning: symbol 'NetArpTxPacket' was not declared. Should it be static? arp.c:38:17: warning: symbol 'NetArpPacketBuf' was not declared. Should it be static? atheros.c:33:19: warning: symbol 'AR8021_driver' was not declared. Should it be static? net.c:183:7: warning: symbol 'PktBuf' was not declared. Should it be static? net.c:159:21: warning: symbol 'net_state' was not declared. Should it be static? ping.c:73:6: warning: symbol 'ping_start' was not declared. Should it be static? ping.c:82:13: warning: symbol 'ping_receive' was not declared. Should it be static? tftp.c:53:7: warning: symbol 'TftpRRQTimeoutMSecs' was not declared. Should it be static? tftp.c:54:5: warning: symbol 'TftpRRQTimeoutCountMax' was not declared. Should it be static? eth.c:125:19: warning: symbol 'eth_current' was not declared. Should it be static? Note: in the ping.c fix, commit a36b12f95a29647a06b5459198684fc142482020 "net: Move PING out of net.c" mistakenly carried the ifdef CMD_PING clause from when it was necessary to avoid warnings when it was embedded in net.c. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2012-10-03net: fix netconsole filteringJoe Hershberger
Adjustment of Michael Walle's fix patch Commit 8a0eccb1056b313b45ab62e3aac400f339aa71b4 breaks netconsole. src_ip must not be converted to host byte order, because nc_ip is already stored in network byte order (see string_to_ip(), called by getenv_IPaddr()). Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-09-24net: Filter incoming netconsole packets by IPJoe Hershberger
Check the incoming packets' source IP address... if ncip isn't set to a broadcast address, only listen to the client at ncip. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-09-24net: Improve the speed of netconsoleJoe Hershberger
Previously u-boot would initialize the network interface for every network operation and then shut it down again. This makes sense for most operations where the network in not known to be needed soon after the operation is complete. In the case of netconsole, it will use the network for every interaction with the shell or every printf. This means that the network is being reinitialized very often. On many devices, this intialization is very slow. This patch checks for consecutive netconsole actions and leaves the ethernet hardware initialized between them. It will still behave the same old way for all other network operations and any time another network operation happens between netconsole operations. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Stefano Babic <sbabic@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
2012-09-24net: bugfix: NetSetTimeout assumes CONFIG_SYS_HZ=1000Tetsuyuki Kobayashi
NetSetTimeout sets incorrect value to timeDelta when CONFIG_SYS_HZ != 1000. Signed-off-by: Tetsuyuki Kobayashi <koba@kmckk.co.jp>
2012-07-24net: Make sure the ethaddr is updated in net_init()Joe Hershberger
NetConsole may call NetSendUDPPacket before NetLoop is called. This will cause the source MAC address (NetOurEther) to be wrong. Instead of only changing it in NetLoop, move it to NetLoopInit so that it is also updated when net_init() is called (especially by nc_start()). Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reported-by: Michael Walle <michael@walle.cc> Acked-by: Michael Walle <michael@walle.cc>
2012-05-23net: Allow filtering on debug traces in the net subsystemJoe Hershberger
Add several levels of DEBUG prints so that you can limit the noise to the severety of your problem. DEBUG_LL_STATE = Link local state machine changes DEBUG_DEV_PKT = Packets or info directed to the device DEBUG_NET_PKT = Packets on info on the network at large DEBUG_INT_STATE = Internal network state changes Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-05-23net: Add link-local addressing supportJoe Hershberger
Code based on networking/zcip.c in busybox commit 8531d76a15890c2c535908ce888b2e2aed35b172 Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-05-23net: Don't copy every packet that waits for an ARPJoe Hershberger
Use the NetArpTxPacket for the ARP packet, not to hold what used to be in NetTxPacket. This saves a copy and makes the code easier to understand. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2012-05-23net: Fix net buffer initializationJoe Hershberger
A new non-static function net_init() will initialize buffers and read from the environment. Only update from the env on each entry to NetLoop(). Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2012-05-23net: Remove unused parameter from NetInitLoop()Joe Hershberger
Noone uses it. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2012-05-23net: Add net_update_ether() to handle ARP and Ping repliesJoe Hershberger
When the network is VLAN or SNAP, net_update_ether() will preserve the original Ethernet packet header and simply replace the src and dest MACs and the protocol Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2012-05-23net: Refactor to separate the UDP handler from the ARP handlerJoe Hershberger
Call a built-in dummy if none is registered... don't require protocols to register a handler (eliminating dummies) NetConsole now uses the ARP handler when waiting on arp (instead of needing a #define hack in arp.c) Clear handlers at the end of net loop Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2012-05-23net: Refactor to protect access to the NetState variableJoe Hershberger
Changes to NetState now go through an accessor function called net_set_state() Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-05-23net: Refactor to use NetSendPacket instead of eth_send directlyJoe Hershberger
Use this entry-point consistently across the net/ code Use a static inline function to preserve code size Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2012-05-23net: Refactor NetSendUDPPacket to share more codeJoe Hershberger
Share more of the code that is common between ARP vs not. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2012-05-23net: Refactor IP, UPD, and ICMP header writing functionsJoe Hershberger
ICMP (ping) was reimplementing IP header code... it now shares code. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-05-23net: cosmetic: Alphabetize includes in net.cJoe Hershberger
Easier to find when alphabetized Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-05-23net: cosmetic: Rename CDPHandler to cdp_receiveJoe Hershberger
This is not called as a handler, so don't name it that way Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-05-23net: cosmetic: Rename "x" to "eth_proto"Joe Hershberger
x is a poor variable name Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2012-05-23net: cosmetic: Add a more explicit comment about 802.2Joe Hershberger
Make the comment more accurate about the header including SNAP Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2012-05-23net: cosmetic: Rename parameter len to payload_lenJoe Hershberger
This name more explicitly claims that it does not include the header size Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
