path: root/net/link_local.c
2017-03-26net: link_local: Fix netmask endianness bugAlexandre Messier
The network mask must be stored in network order when in a 'struct in_addr'. This fix removes the "gatewayip needed but not set" message on the console when using a link-local IP setup. Signed-off-by: Alexandre Messier <amessier@tycoint.com> Signed-off-by: Sylvain Lemieux <slemieux@tycoint.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-04-18net: cosmetic: Fix checkpatch.pl failures in net.cJoe Hershberger
Finish eliminating CamelCase from net.c and other failures Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Fix checkpatch.pl failures in linklocalJoe Hershberger
A few new rules in checkpatch.pl since linklocal.c was added. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Name ethaddr variables consistentlyJoe Hershberger
Use "_ethaddr" at the end of variables and drop CamelCase. Make constant values actually 'const'. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Change IPaddr_t to struct in_addrJoe Hershberger
This patch is simply clean-up to make the IPv4 type that is used match what Linux uses. It also attempts to move all variables that are IP addresses use good naming instead of CamelCase. No functional change. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2013-06-24net: Correct check for link-local target IP conflictJoe Hershberger
Make the link-local code conform more completely with the RFC. This will prevent ARP queries for the target (such as while it is rebooting) from causing the device to choose a different link-local address, thinking that its address is in use by another machine. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-12-15net: Fix endianness bug in link-localJoe Hershberger
The ip is stored in network order, so we can't test it in host order. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Kim Phillips <kim.phillips@freescale.com>
2012-07-19net: link_local: fix buildbenoit.thebaudeau@advans
Fix comment within comment build error. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Joe Hershberger <joe.hershberger@gmail.com>
2012-07-10Minor Coding Style cleanupWolfgang Denk
2012-07-07net: use common rand()/srand() functionsMichael Walle
Replace rand() with the functions from lib/. The link-local network code stores its own seed, derived from the MAC address. Thus making it independent from calls to srand() in other modules. Signed-off-by: Michael Walle <michael@walle.cc> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2012-05-23net: Allow filtering on debug traces in the net subsystemJoe Hershberger
Add several levels of DEBUG prints so that you can limit the noise to the severety of your problem. DEBUG_LL_STATE = Link local state machine changes DEBUG_DEV_PKT = Packets or info directed to the device DEBUG_NET_PKT = Packets on info on the network at large DEBUG_INT_STATE = Internal network state changes Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-05-23net: Add link-local addressing supportJoe Hershberger
Code based on networking/zcip.c in busybox commit 8531d76a15890c2c535908ce888b2e2aed35b172 Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
