path: root/net/eth_common.c
2018-04-08net: Move enetaddr env access code to env config instead of net configAlex Kiernan
In order that we can use eth_env_* even when CONFIG_NET isn't set, move these functions to environment code from net code. This fixes failures such as: board/ti/am335x/built-in.o: In function `board_late_init': board/ti/am335x/board.c:752: undefined reference to `eth_env_set_enetaddr' u-boot/board/ti/am335x/board.c:766: undefined reference to `eth_env_set_enetaddr' which caters for use cases such as: commit f411b5cca48f ("board: am335x: Always set eth/eth1addr environment variable") when Ethernet is required in Linux, but not U-Boot. Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
2017-08-16env: Rename eth_getenv_enetaddr() to eth_env_get_enetaddr()Simon Glass
Rename this function for consistency with env_get(). Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16env: Rename eth_setenv_enetaddr() to eth_env_set_enetaddr()Simon Glass
Rename this function for consistency with env_set(). Signed-off-by: Simon Glass <sjg@chromium.org>
2017-03-20net: don't override ethernet address environmentRoger Quadros
If the ethernet address environment is set with a valid ethernet address prevent overriding it as it is most likely set by the user and he/she doesn't want board code to automatically override it whatsoever. Signed-off-by: Roger Quadros <rogerq@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-02-07net: cosmetic: Make the MAC address string less magicaloliver@schinagl.nl
In u-boot printf has been extended with the %pM formatter to allow printing of MAC addresses. However buffers that want to store a MAC address cannot safely get the size. Add a define for this case so the string of a MAC address can be reliably obtained. Signed-off-by: Olliver Schinagl <oliver@schinagl.nl> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-01-28net: Move remaining common functions to eth_common.cSimon Glass
Move eth_current_changed(), eth_set_current(), eth_mac_skip() and eth_get_name() into the common file. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-01-28net: Move environment functions to the common fileSimon Glass
Move the functions which set ethernet environment variables to the common file. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-01-28net: Move common init into a new eth_common.c fileSimon Glass
Only half of the init is actually common. Move that part into a new common file and call it from driver-model and legacy code. More common functions will be added in future patches. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
