This has always been confusing, and the idea of these functions returning the
number of interfaces initialized was half-baked and ultimately pointless.
Instead, act more like regular functions and return < 0 on failure, >= 0 on
success.
This change shouldn't break anything.
All are within an #ifdef CONFIG_NET_MULTI block already
Commit 6e37b1a3a25004d3df5867de49fff6b3fc9c4f04 modifies several net calls
to take a (const char *) parameter instead of (char *), but in some cases
the modified functions call other functions taking (char *). The end result
is warnings about discarding the const qualifier.
This patch fixes these other function signatures.
Some commands operate on eth device names (like 'mii'), but those cannot
be passed on the command line as one argument. So detect devices like
these and warn about them so someone will fix it.
Move it inside the #ifdef CONFIG_NET_MULTI to avoid
eth.c:64: warning: 'eth_mac_skip' defined but not used
messages from anumber of old, non-CONFIG_NET_MULTI boards.
Cc: Ben Warren <biggerbadderben@gmail.com>
Add a new function to the eth_device struct for programming a network
controller's hardware address.
After all network devices have been initialized and the proper MAC address
for each has been determined, make a device driver call to program the
address into the device. Only device instances with valid unicast addresses
will be programmed.
Acked-by: Detlev Zundel <dzu@denx.de>
Tested-by: Prafulla Wadaskar <prafulla@marvell.com>
Tested-by: Heiko Schocher <hs@denx.de>
Tested-by: Thomas Chou <thomas@wytron.com.tw>
Signed-off-by: Detlev Zundel <dzu@denx.de>
In the previous enetaddr refactoring, the assumption with commit 56b555a644
was that the eth layer would handle the env -> device enetaddr syncing.
This was not the case as eth_initialize() is called only once and the sync
occurs there. So make sure the eth_init() function does the env -> device
sync with every network init.
Reported-by: Andrzej Wolski <awolski@poczta.fm>
Minor ./net cleanups - no functional changes
- change #ifdef DEBUG printf(); #endif to just debug()
- changed __FUNCTION__ to __func__
- got rid of extra whitespace between function and opening brace
- removed unnecessary braces on if statements
gcc dead code elimination should make this functionally/size equivalent
when DEBUG is not defined. (confirmed on Blackfin, with gcc 4.3.3).
Signed-off-by: Robin Getz <rgetz@blackfin.uclinux.org>
Added CONFIG_NET_MULTI to all Davinci boards
Removed all calls to Davinci network driver from board code
Added cpu_eth_init() to cpu/arm926ejs/cpu.c
Fix some issues introduced from commit:
2f70c49e5b9813635ad73666aa30f304c7fdeda9
suggested by Mike Frysinger.
- added some comment for the env_id variable in common_cmd_nvedit.c
- moved some variables in fn scope instead of file scope
- NetInitLoop now static void
Acked-by: Ben Warren <biggerbadderben@gmail.com>
__attribute__ follows gcc's documented syntax and is generally more
common than __attribute. This change is only asthetic and should not
affect functionality.
Declare new utility functions for converting between the environment
variables (eth*addr) and the binary MAC address representation. This way
we can unify all the random places that already do this kind of thing.
The functions in question:
eth_parse_enetaddr - "..." -> {...}
eth_getenv_enetaddr - env -> {...}
eth_setenv_enetaddr - {...} -> env
CC: Ben Warren <biggerbadderben@gmail.com>
NetLoop polls every cycle with getenv some environment variables.
This is horribly slow, especially when the environment is big.
This patch reads only the environment variables in NetLoop,
when they were changed.
Also moved the init part of the NetLoop function in a seperate
function.
This allows code to iterate through the ethernet devices
Signed-off-by: Andy Fleming <afleming@freescale.com>
Removed initialization of the driver from net/eth.c
All in-tree IBM/AMCC PPC4xx boards using the EMAC get this new CONFIG
Affected boards:
Several MPC8xx boards
Several MPC8260/MPC8272 boards
Several MPC85xx boards
This patch will move au1x00_eth_initialize from net/eth.c to cpu_eth_init
as a part of ongoing eth_initialize cleanup work. The function ret value
is also fixed as it should be negative on fail.
Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
Also, removed the driver initialization from net/eth.c
Added as a convenience for other platforms that uses MPC8360 (has 8 UCC).
Six eth interface is chosen because the platform I am using combines
UCC1&2 and UCC3&4 as 1000 Eth and the other four UCCs as 10/100 Eth.
Signed-off-by: Richard Retanubun <RichardRetanubun@RugggedCom.com>
Affected boards:
db64360
db64460
katmai
taihu
taishan
yucca
cpc45
cpu87
eXalion
elppc
debris
kvme080
mpc8315erdb
integratorap
ixdp425
oxc
pm826
pm828
pm854
pm856
ppmc7xx
sc3
sc520_spunk
sorcery
tqm8272
tqm85xx
utx8245
Also, wrapped contents of pci_eth_init() by CONFIG_PCI.
Affected boards:
cu824
bab7xx
adciop
dasa_sim
mousse
mpc8540eval
musenki
mvblue
pcippc2/pcippc6
sbc8240
stxssa
Affected boards:
ap1000
mvbc_p
PM854
Affected boards:
purple
Removed initialization of controller from net/eth.c
Modified board_eth_init() functions of boards that have this FEC in addition
to other Ethernet controllers.
Affected boards:
bc3450
icecube
mvbc_p
o2dnt
pm520
total5200
tq5200
Added a cpu_eth_init() function to MPC512x CPU directory and
removed code from net/eth.c
Affected boards:
IncaIP
Affected boards:
AmigaOneG3SE
Affected boards:
EVB64260
P3G4
ZUMA
Affected boards:
PN62
sc520_cdp
Affected boards:
a3000
Affected boards:
bc3450
cpci5200
mecp5200
pf2000
icecube
o2dnt
pm520
sandpoint8245
total5200
tqm5200
Affected boards:
mpc7448hpc2
Affected boards:
hidden_dragon
MPC8544DS
MPC8610HPCN
R2DPLUS
TB0229
Affected boards:
linkstation
r7780mp
Removed at91sam9_eth_initialize() from net/eth.c
DM644x is just one of a series of DaVinci chips that use the EMAC driver.
By replacing all the function names that start with dm644x_* to davinci_*
we make these function more portable. I have tested this change on my EVM.
DM6467 is another DaVinci SOC which uses the EMAC driver and i will
be sending patches that add DaVinci DM6467 support to the list soon.
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
The only board using this driver is the SL8245 board.
Removed initialization for the driver from net/eth.c
The only board using this driver is the Freescale MPC8610HPCD board.
Added board_eth_init() function to bf537-stamp board.
Removed initialization for the Blackin EMAC driver from net/eth.c
Added a cpu_eth_init() function to leon2/leon3 CPU directories and
Added a cpu_eth_init() function to coldfire CPU directories and
