In rare circumstances two dhcp clients may generate the same
bootp ID. If this happens it is vital that the client also checks
the hw address in the received response to prevent IP address conflicts.
Signed-off-by: Anton Persson <don.juanton@gmail.com>
There is currently one config option (CONFIG_NET_RETRY_COUNT) that
is available to tune the retries of the network stack.
Unfortunately, it is global to all protocols, and the value is
interpreted differently in all of them.
Add a new environment variable that directly sets the retry period for
BOOTP timeouts. If this new value is not set, the period is still derived
from the default number of retries, or from CONFIG_NET_RETRY_COUNT if
defined. When both the new variable is set and CONFIG_NET_RETRY_COUNT
is defined, the variable has precedence.
Signed-off-by: Alexandre Messier <amessier@tycoint.com>
Add the bootfile name in the DHCP Request packet, in addition
to it already being sent in the DHCP Discover.
This is needed by some DHCP servers so that the bootfile name is
properly returned by the server to the client in the DHCP Ack, as
expected by U-Boot.
When doing `dhcp`, there is a bad dhcp server in my network
which always reply dhcp request with yiaddr 0, which cause
uboot can not successfully get ipaddr from the good dhcp server.
But the Linux PC can get the ip address even if there is a bad
dhcp server. This patch is to fix that even if there is a bad
dhcp server, uboot can still get ipaddr and tftp work ok.
The way is to ignore the packets from the bad dhcp server by filtering
out the yiaddr whose value is 0.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Reviewed-by: Wolfgang Denk <wd@denx.de>
If Option 52 in the vendor option field signals overloading
of the file and/or sname fields, these field may contain
additional options. Formatting of file/sname contained options
is the same as in the vendor options field, but without the
leading magic.
Signed-off-by: Stefan Brüns <stefan.bruens@rwth-aachen.de>
If 'file' is overloaded, it is wrong to get or put the bootfile name
from it/to it.
Timeout handler should be stopped after reception of DHCPACK. If "autoload"
is not set, the handler is immediately replaced by the TFTP handler,
otherwise it may trigger before the next boot stage begins.
Pad has no len byte, so the normal parsing code fails.
RFC1542, 3.2:
"The 'secs' field of a BOOTREQUEST message SHOULD represent the
elapsed time, in seconds, since the client sent its first BOOTREQUEST
message. Note that this implies that the 'secs' field of the first
BOOTREQUEST message SHOULD be set to zero."
Rename check_packet to check_reply_packet to make its function more
obvious.
The check for DHCP_* values is completely off, as it should
compare against DHCP option 53 (Message Type). Only valid value for
any Bootp/DHCP reply is BOOTREPLY.
This fixes the error when STATUS_LED_BOOT is not defined.
If CONFIG_CMD_DHCP is enabled, the vci (vendor-class-identifier) string
isn't inserted into the bootp-packet during SPL stage because the
CONFIG_BOOTP_VCI_STRING
instead
CONFIG_SPL_NET_VCI_STRING
We fix this with testing for CONFIG_SPL_BUILD and testing for existing
CONFIG_SPL_NET_VCI_STRING.
Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at>
This change gives the ability to reuse the <tftp.h> header file by other
subsystems (like e.g. dfu).
Without this change compilation error emerges for the legacy update.c file.
Signed-off-by: Lukasz Majewski <l.majewski@majess.pl>
This commit fixes incorrect DHCP/BOOTP packet layout caused by
'ulong' type size difference on 64 and 32-bit architectures.
It also renames NetReadLong()/NetCopyLong() to
net_read_u32/net_copy_u32() accordingly.
Signed-off-by: Radha Mohan Chintakuntla <rchintakuntla@cavium.com>
Signed-off-by: Sergey Temerkhanov <s.temerkhanov@gmail.com>
Finish eliminating CamelCase from net.c and other failures
Make a thorough pass through all variables and function names contained
within bootp.c and remove CamelCase and improve naming.
This patch cleans up the names of internal packet buffer names that are
used within the network stack and the functions that use them.
Use "_ethaddr" at the end of variables and drop CamelCase.
Make constant values actually 'const'.
Remove CamelCase variable naming.
Move the definition to the same compilation unit as the primary use.
The variables around the bootfile were inconsistent and used CamelCase.
Update them to make the code more readable.
This patch is simply clean-up to make the IPv4 type that is used match
what Linux uses. It also attempts to move all variables that are IP
addresses use good naming instead of CamelCase. No functional change.
Currenly when CONFIG_BOOTP_SERVERIP is defined, the SERVERIP is not changed
when receive the BOOTP packet. But BOOTFILE is changed via BOOTP packet.
As we will load the BOOTFILE from SERVERIP, if the BOOTFILE is modified
by bootp packet but SERVERIP is not, that is not make sense.
This patch make SERVERIP and BOOTFILE be consistent. If we define the
CONFIG_BOOTP_SERVERIP, then SERVERIP and BOOTFILE will not changed by
BOOTP packet. Only IP address is changed.
Signed-off-by: Josh Wu <josh.wu@atmel.com>
It's not unusual for DHCP servers to take a couple hundred milliseconds
to respond to DHCP discover messages. One possible reason for the delay
can be that the server checks (typically using an ARP request) that the
IP it's about to hand out isn't in use yet. To make matters worse, some
servers may also queue up requests and process them sequentially, which
can cause excessively long delays if clients retry too fast.
Commit f59be6e850b3 ("net: BOOTP retry timeout improvements") shortened
the retry timeouts significantly, but the BOOTP/DHCP implementation in
U-Boot doesn't handle that well because it will ignore incoming replies
to earlier requests. In one particular setup this increases the time it
takes to obtain a DHCP lease from 630 ms to 8313 ms.
This commit attempts to fix this in two ways. First it increases the
initial retry timeout from 10 ms to 250 ms to give DHCP servers some
more time to respond. At the same time a cache of outstanding DHCP
request IDs is kept so that the implementation will know to continue
transactions even after a retransmission of the DISCOVER message. The
maximum retry timeout is also increased from 1 second to 2 seconds. An
ID cache of size 4 will keep DHCP requests around for 8 seconds (once
the maximum retry timeout has been reached) before dropping them. This
should give servers plenty of time to respond. If it ever turns out
that this isn't enough, the size of the cache can easily be increased.
With this commit the DHCP lease on the above-mentioned setup still takes
longer (1230 ms) than originally, but that's an acceptable compromise to
improve DHCP lease acquisition time for a broader range of setups.
To make it easier to benchmark DHCP in the future, this commit also adds
the time it took to obtain a lease to the final "DHCP client bound to
address x.x.x.x" message.
Signed-off-by: Thierry Reding <treding@nvidia.com>
Currently, the BOOTP code sends out its initial request as soon as the
Ethernet driver indicates "link up". If this packet is lost or not
replied to for some reason, the code waits for a 1s timeout before
retrying. For some reason, such early packets are often lost on my
system, so this causes an annoying delay.
To optimize this, modify the BOOTP code to have very short timeouts for
the first packet transmitted, but gradually increase the timeout each
time a timeout occurs. This way, if the first packet is lost, the second
packet is transmitted quite quickly and hence the overall delay is low.
However, if there's still no response, we don't keep spewing out packets
at an insane speed.
It's arguably more correct to try and find out why the first packet is
lost. However, it seems to disappear inside my Ethenet chip; the TX chip
indicates no error during TX (not that it has much in the way of
reporting...), yet wireshark on the RX side doesn't see any packet.
FWIW, I'm using an ASIX USB Ethernet adapter. Perhaps "link up" is
reported too early or based on the wrong condition in HW, and we should
add some fixed extra delay into the driver. However, this would slow down
every link up event even if it ends up not being needed in some cases.
Having BOOTP retry quickly applies the fix/WAR to every possible
Ethernet device, and is quite simple to implement, so seems a better
solution.
Cleanup bootp code by using mdelay.
Signed-off-by: Pavel Machek <pavel@denx.de>
Changes in lib/uuid.c to:
- uuid_str_to_bin()
- uuid_bin_to_str()
New parameter is added to specify input/output string format in listed functions
This change allows easy recognize which UUID type is or should be stored in given
string array. Binary data of UUID and GUID is always stored in big endian, only
string representations are different as follows.
String byte: 0 36
String char: xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx
string UUID: be be be be be
string GUID: le le le be be
This patch also updates functions calls and declarations in a whole code.
Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com>
Cc: Stephen Warren <swarren@nvidia.com>
Cc: Lukasz Majewski <l.majewski@samsung.com>
Cc: trini@ti.com
bootp.c:44:14: warning: symbol 'dhcp_state' was not declared. Should it be static?
bootp.c:45:15: warning: symbol 'dhcp_leasetime' was not declared. Should it be static?
bootp.c:46:10: warning: symbol 'NetDHCPServerIP' was not declared. Should it be static?
arp.c:30:17: warning: symbol 'NetArpWaitReplyIP' was not declared. Should it be static?
arp.c:37:16: warning: symbol 'NetArpTxPacket' was not declared. Should it be static?
arp.c:38:17: warning: symbol 'NetArpPacketBuf' was not declared. Should it be static?
atheros.c:33:19: warning: symbol 'AR8021_driver' was not declared. Should it be static?
net.c:183:7: warning: symbol 'PktBuf' was not declared. Should it be static?
net.c:159:21: warning: symbol 'net_state' was not declared. Should it be static?
ping.c:73:6: warning: symbol 'ping_start' was not declared. Should it be static?
ping.c:82:13: warning: symbol 'ping_receive' was not declared. Should it be static?
tftp.c:53:7: warning: symbol 'TftpRRQTimeoutMSecs' was not declared. Should it be static?
tftp.c:54:5: warning: symbol 'TftpRRQTimeoutCountMax' was not declared. Should it be static?
eth.c:125:19: warning: symbol 'eth_current' was not declared. Should it be static?
Note: in the ping.c fix, commit a36b12f95a29647a06b5459198684fc142482020
"net: Move PING out of net.c" mistakenly carried the ifdef CMD_PING
clause from when it was necessary to avoid warnings when it was embedded
in net.c.
This patch adds support for networking in SPL. Some devices are
capable of loading SPL via network so it makes sense to load the
main U-Boot binary via network too. This patch tries to use
existing network code as much as possible. Unfortunately, it depends
on environment which in turn depends on other code so SPL size
is increased significantly. No effort was done to decouple network
code and environment so far.
Signed-off-by: Ilya Yanok <ilya.yanok@cogentembedded.com>
Vendor Class Identifier option is common to BOOTP and DHCP and
can be useful without PXE. So send VCI in both BOOTP and DHCP
requests if CONFIG_BOOTP_VCI_STRING is defined.
Some DHCP servers (notably dnsmasq) always transmit DHCP Option 28,
Broadcast Address as specified in RFC 2132. Without this patch u-boot
displays the warning:
*** Unhandled DHCP Option in OFFER/ACK: 28
The patch suppresses the warning and ignores DHCP Option 28. There is
no environment variable to set the broadcast address into and if for
some reason u-boot needs the broadcast it can be calculated from
ipaddr and netmask.
Signed-off-by: Brian Rzycki <bmr@freescale.com>
Fix NetSetState function name used with CONFIG_BOOTP_MAY_FAIL.
Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
Cc: Joe Hershberger <joe.hershberger@gmail.com>
commit "net: use common rand()/srand() functions" introduced the following
build warning on the current u-boot-arm tree:
$ ./MAKEALL MPC8313ERDB_66
Configuring for MPC8313ERDB_66 - Board: MPC8313ERDB, Options: SYS_66MHZ
271988 13976 41768 327732 50034 ./u-boot
In file included from bootp.c:15:0:
net_rand.h: In function 'srand_mac':
net_rand.h:40:2: warning: implicit declaration of function 'srand' [-Wimplicit-function-declaration]
adding this dependency fixes it.
Cc: Michael Walle <michael@walle.cc>
Acked-by: Michael Walle <michael@walle.cc>
This is useful if you want to look for a DHCP server, but try some
other settings if not available.
If CONFIG_BOOTP_SERVERIP is not defined, unused variable warning is
reported. This was fixed upstream using a compiler feature instead
of a simple reorder of the statements.
Call a built-in dummy if none is registered... don't require
protocols to register a handler (eliminating dummies)
NetConsole now uses the ARP handler when waiting on arp
(instead of needing a #define hack in arp.c)
Clear handlers at the end of net loop
Eliminate pointer subtraction that recovers values computed earlier
ICMP (ping) was reimplementing IP header code... it now shares code.
Clearer constant name.
Also remove related BOOTP_SIZE which was unused and doesn't take
into account VLAN packets.
Separate the Ethernet header from the 802 header.
Base the size constants on the structs.
Rename IP header related things to IP_UDP. The existing definition
of IP_t includes UDP header, so name it to accurately describe the
structure.
Make the MAC-seeded random number generator available to /net in
general. MAC-seeded rand will be needed by link-local as well, so
give it an interface.
This inserts bootstage calls into tftp, usb start and bootm. We
could go further, but this is a reasonable start to illustrate
the concept.
Fix:
bootp.c: In function 'BootpCopyNetParams':
bootp.c:108:11: warning: unused variable 'tmp_ip' [-Wunused-variable]
The rarp code includes another instance of the auto_load logic, so call
what is now net_auto_load() instead.
This also fixes an incorrect call to TftpStart() which was never seen
since apparently no boards enable rarp.
TftpStart should support starting either a get or a put.
These options are required to be present in RFC 4578 compliant DHCP
requests. They give more information to DHCP servers to allow serving
different DHCP responses to different systems based on client
architecture, client capabilities, UUID, or vendor.
Signed-off-by: Jason Hobbs <jason.hobbs@calxeda.com>
Commit 093498669 (Put common autoload code into auto_load() function)
broke handling of autoload environment variable not being set.
The bootp/dhcp code will just keep on requesting IP address forever
and never start TFTP download.
Fix it by moving TftpStart() outside the conditional like it was before.
Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk>
Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
