CONFIG_NET does not imply that there are actually network devices
available, only CONFIG_NETDEVICES does. Changing to this dependency
obsoletes the check in Kconfig because NETDEVICES means DM_ETH.
Fixes: 0efe1bcf5c2c ("efi_loader: Add network access support")
Suggested-by: Tom Rini <trini@konsulko.com>
Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com>
Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
to adjust the root path length.
Eg to 256 from Linux Kernel
Signed-off-by: Andre Kalb <andre.kalb@sma.de>
Reviewed-by: Ramon Fried <rfried.dev@gmail.com>
[trini: Guard extern so that !CONFIG_NET platforms will build]
CONFIG_NET_RETRY_COUNT
Cc: Ramon Fried <rfried.dev@gmail.com>
This option is not in use anywhere and the documentation implies it's
for some very old and unlikely to be seen currently issues. Rather than
update the code so the CONFIG symbol could be easily in Kconfig, remove
the code.
Acked-by: Ramon Fried <rfried.dev@gmail.com>
Use IS_ENABLED() instead, to reduce the number of build paths.
The VCI string sent during bootp of U-Boot-SPL is corrupt. This is
because the byte counter is not adjusted within the bootp_extended()
function when the VCI string is added. We fix this.
Signed-off-by: Walter Stoll <walter.stoll@duagon.com>
It is a pain to have to specify the value 10 in each call. Add a new
dectoul() function and update the code to use it.
- ProxyDHCP allows a second DHCP server to exist alongside your main
DHCP server and supply additional BOOTP related options
- When u-boot sends out a DHCP request, the real DHCP server will
respond with a normal response containing the new client IP address
while simultaneously the ProxyDHCP server will respond with a blank
client IP address and a `bootfile` option
- This patch adds CONFIG_SERVERIP_FROM_PROXYDHCP (default false) to
enable this behavior and CONFIG_SERVERIP_FROM_PROXYDHCP_DELAY_MS
(default 100) which tells u-boot to wait additional time after
receiving the main DHCP response to give the ProxyDHCP response time
to arrive
- The PXE spec for ProxyDHCP is more complicated than the solution
added here as diagramed on page 16:
http://www.pix.net/software/pxeboot/archive/pxespec.pdf:
DHCP Discover will be retried four times. The four timeouts are 4, 8, 16
and 32 seconds respectively. If a DHCPOFFER is received without an Option
timeouts in an attempt to receive a PXE response.
- Adding a simple delay worked for my purposes but let me know if a
more robust solution is required
Signed-off-by: Lyle Franklin <lylejfranklin@gmail.com>
Move this uncommon header out of the common header.
Move this header out of the common header.
Move this fairly uncommon header out of the common header.
Move this header out of the common header. Network support is used in
quite a few places but it still does not warrant blanket inclusion.
Note that this net.h header itself has quite a lot in it. It could be
split into the driver-mode support, functions, structures, checksumming,
etc.
Move env_get_ulong() over to the new header file.
Currently we can choose between 2 different types of behavior for the
serverip variable:
1) Always overwrite it with the DHCP server IP address (default)
2) Ignore what the DHCP server says (CONFIG_BOOTP_SERVERIP)
This patch adds a 3rd option:
3) Use serverip from DHCP if no serverip is given
(CONFIG_BOOTP_PREFER_SERVERIP)
With this new option, we can have the default case that a boot file gets
loaded from the DHCP provided TFTP server work while allowing users to
specify their own serverip variable to explicitly use a different tftp
server.
We can call commands like dhcp and bootp without arguments or with
explicit command line arguments that really should tell the code where
to look for files instead.
Unfortunately, the current code simply overwrites command line arguments
in the dhcp case with dhcp values.
This patch allows the code to preserve the command line values if they
were set on the command line. That way the semantics are slightly more
intuitive.
The reason this patch does that by introducing a new variable is that we
can not rely on net_boot_file_name[0] being unset, as today it's
completely legal to call "dhcp" and afterwards run "tftp" and expect the
latter to repeat the same query as before. I would prefer not to break
that behavior in case anyone relies on it.
When the following configuration is set
# CONFIG_CMD_DHCP is not set
CONFIG_CMD_BOOTP=y
CONFIG_BOOTP_NTPSERVER=y
The following compile error is observed
error: used struct type value where scalar is required
if (net_ntp_server)
Resolve this by checking net_ntp_server.s_addr instead.
Signed-off-by: Chris Packham <judge.packham@gmail.com>
This change allows the "MAY_FAIL" DHCP option to still attempt to
contact a DHCP server on each adapter and only give up once each
adapter has failed once. To get the existing behavior, set the
already-existing ethrotate=no variable.
Cc: Keng Soon Cheah <keng.soon.cheah@ni.com>
Cc: Chen Yee Chew <chen.yee.chew@ni.com>
Nothing from this header is used there, so remove it.
We are now using an env_ prefix for environment functions. Rename these
for consistency. Also add function comments in common.h.
Suggested-by: Wolfgang Denk <wd@denx.de>
two functions for consistency. Also add function comments in common.h.
Quite a few places use getenv() in a condition context, provoking a
warning from checkpatch. These are fixed up in this patch also.
We are now using an env_ prefix for environment functions. Rename setenv()
Move all of the status LED feature to drivers/led/Kconfig.
The LED status definitions were moved from the board configuration
files to the defconfig files.
TBD: Move all of the definitions in the include/status_led.h to the
relevant board's defconfig files.
Tested boards: CL-SOM-AM57x, CM-T335
Signed-off-by: Uri Mashiach <uri.mashiach@compulab.co.il>
Avoid generating this section if there is nothing in it.
Signed-off-by: Andre Renaud <andre@designa-electronics.com>
The client architecture that we pass to a dhcp server depends on the target
payload that we want to execute. An EFI binary has a different client arch
than a legacy binary or a u-boot binary.
So let's parameterize the pxe client arch field to allow an override via
the distro script, so that our efi boot path can tell the dhcp server that
it's actually an efi firmware.
Now that we can expose network functionality to EFI applications,
the logical next step is to load them via pxe to execute them as
well.
This patch adds the necessary bits to the distro script to automatically
load and execute EFI payloads. It identifies the dhcp client as a uEFI
capable PXE client, hoping the server returns a tftp path to a workable
EFI binary that we can then execute.
To enable boards that don't come with a working device tree preloaded,
this patch also adds support to load a device tree from the /dtb directory
on the remote tftp server.
Both the dhcp as well as the bootp case add vendor class identifier
parameters into their packets. Let's move that into a separate function
to make overlaying easier.
We can now successfully boot EFI applications from disk, but users
may want to also run them from a PXE setup.
This patch implements rudimentary network support, allowing a payload
to send and receive network packets.
With this patch, I was able to successfully run grub2 with network
access inside of QEMU's -M xlnx-ep108.
In rare circumstances two dhcp clients may generate the same
bootp ID. If this happens it is vital that the client also checks
the hw address in the received response to prevent IP address conflicts.
Signed-off-by: Anton Persson <don.juanton@gmail.com>
There is currently one config option (CONFIG_NET_RETRY_COUNT) that
is available to tune the retries of the network stack.
Unfortunately, it is global to all protocols, and the value is
interpreted differently in all of them.
Add a new environment variable that directly sets the retry period for
BOOTP timeouts. If this new value is not set, the period is still derived
from the default number of retries, or from CONFIG_NET_RETRY_COUNT if
defined. When both the new variable is set and CONFIG_NET_RETRY_COUNT
is defined, the variable has precedence.
Signed-off-by: Alexandre Messier <amessier@tycoint.com>
Add the bootfile name in the DHCP Request packet, in addition
to it already being sent in the DHCP Discover.
This is needed by some DHCP servers so that the bootfile name is
properly returned by the server to the client in the DHCP Ack, as
expected by U-Boot.
When doing `dhcp`, there is a bad dhcp server in my network
which always reply dhcp request with yiaddr 0, which cause
uboot can not successfully get ipaddr from the good dhcp server.
But the Linux PC can get the ip address even if there is a bad
dhcp server. This patch is to fix that even if there is a bad
dhcp server, uboot can still get ipaddr and tftp work ok.
The way is to ignore the packets from the bad dhcp server by filtering
out the yiaddr whose value is 0.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Reviewed-by: Wolfgang Denk <wd@denx.de>
If Option 52 in the vendor option field signals overloading
of the file and/or sname fields, these field may contain
additional options. Formatting of file/sname contained options
is the same as in the vendor options field, but without the
leading magic.
Signed-off-by: Stefan Brüns <stefan.bruens@rwth-aachen.de>
If 'file' is overloaded, it is wrong to get or put the bootfile name
from it/to it.
Timeout handler should be stopped after reception of DHCPACK. If "autoload"
is not set, the handler is immediately replaced by the TFTP handler,
otherwise it may trigger before the next boot stage begins.
Pad has no len byte, so the normal parsing code fails.
RFC1542, 3.2:
"The 'secs' field of a BOOTREQUEST message SHOULD represent the
elapsed time, in seconds, since the client sent its first BOOTREQUEST
message. Note that this implies that the 'secs' field of the first
BOOTREQUEST message SHOULD be set to zero."
Rename check_packet to check_reply_packet to make its function more
obvious.
The check for DHCP_* values is completely off, as it should
compare against DHCP option 53 (Message Type). Only valid value for
any Bootp/DHCP reply is BOOTREPLY.
This fixes the error when STATUS_LED_BOOT is not defined.
If CONFIG_CMD_DHCP is enabled, the vci (vendor-class-identifier) string
isn't inserted into the bootp-packet during SPL stage because the
CONFIG_BOOTP_VCI_STRING
instead
CONFIG_SPL_NET_VCI_STRING
We fix this with testing for CONFIG_SPL_BUILD and testing for existing
CONFIG_SPL_NET_VCI_STRING.
Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at>
This change gives the ability to reuse the <tftp.h> header file by other
subsystems (like e.g. dfu).
Without this change compilation error emerges for the legacy update.c file.
Signed-off-by: Lukasz Majewski <l.majewski@majess.pl>
This commit fixes incorrect DHCP/BOOTP packet layout caused by
'ulong' type size difference on 64 and 32-bit architectures.
It also renames NetReadLong()/NetCopyLong() to
net_read_u32/net_copy_u32() accordingly.
Signed-off-by: Radha Mohan Chintakuntla <rchintakuntla@cavium.com>
Signed-off-by: Sergey Temerkhanov <s.temerkhanov@gmail.com>
Finish eliminating CamelCase from net.c and other failures
Make a thorough pass through all variables and function names contained
within bootp.c and remove CamelCase and improve naming.
This patch cleans up the names of internal packet buffer names that are
used within the network stack and the functions that use them.
Use "_ethaddr" at the end of variables and drop CamelCase.
Make constant values actually 'const'.
Remove CamelCase variable naming.
Move the definition to the same compilation unit as the primary use.
The variables around the bootfile were inconsistent and used CamelCase.
Update them to make the code more readable.
This patch is simply clean-up to make the IPv4 type that is used match
what Linux uses. It also attempts to move all variables that are IP
addresses use good naming instead of CamelCase. No functional change.
Currenly when CONFIG_BOOTP_SERVERIP is defined, the SERVERIP is not changed
when receive the BOOTP packet. But BOOTFILE is changed via BOOTP packet.
As we will load the BOOTFILE from SERVERIP, if the BOOTFILE is modified
by bootp packet but SERVERIP is not, that is not make sense.
This patch make SERVERIP and BOOTFILE be consistent. If we define the
CONFIG_BOOTP_SERVERIP, then SERVERIP and BOOTFILE will not changed by
BOOTP packet. Only IP address is changed.
Signed-off-by: Josh Wu <josh.wu@atmel.com>
