path: root/net/bootp.c
2006-10-12Minor code cleanup.Wolfgang Denk
2006-10-09Make bootp implementation RFC3046 compliantWolfgang Denk
Patch by Joakim Larsson, 27 Jun 2006
2006-03-12Add support for the DHCP vendor optional bootfile (#67).Wolfgang Denk
Ignores the vendor TFTP server name option (#66). Patch by Murray Jensen, 30 Jun 2005
2005-04-02Fix problems with SNTP support;wdenk
enable SNTP support in some boards.
2005-04-01* Patch by Masami Komiya, 30 Mar 2005:wdenk
add SNTP support and expand time server and time offset fields of DHCP support. See doc/README.SNTP * Patch by Steven Scholz, 13 Dec 2004: Fix bug in at91rm920 ethernet driver
2004-04-15Patches by Pantelis Antoniou, 30 Mar 2004:wdenk
add networking support for VLANs (802.1q), and CDP (Cisco Discovery Protocol)
2004-03-23* Patches by Thomas Viehweger, 16 Mar 2004:wdenk
- show PCI clock frequency on MPC8260 systems - add FCC_PSMR_RMII flag for HiP7 processors - in do_jffs2_fsload(), take load address from load_addr if not set explicit, update load_addr otherwise - replaced printf by putc/puts when no formatting is needed (smaller code size, faster execution)
2004-03-14* Patch by Philippe Robin, 09 Mar 2004:wdenk
Added ARM Integrator AP, CP and Versatile PB926EJ-S Reference Platform support. * Patch by Masami Komiya, 08 Mar 2004: Don't overwrite server IP address or boot file name when the boot server does not return values * Patch by listmember@orkun.us, 5 Mar 2004: Removed compile time restriction on CFG_I2C_SPEED for DS1338 RTC
2004-03-14* Patch by Travis Sawyer, 01 Mar 2004:wdenk
Ocotea: - Add IBM PPC440GX Ref Platform support (Ocotea) Original code by Paul Reynolds <PaulReynolds@lhsolutions.com> Adapted to U-Boot and 440GX port 440gx_enet.c: - Add gracious handling of all Ethernet Pin Selections for 440GX - Add RGMII selection for Cicada CIS8201 Gigabit PHY ppc440.h: - Add needed bit definitions - Fix formatting * Patch by Carl Riechers, 1 Mar 2004: Add PPC440GX prbdv0 divider to fix memory clock calculation. * Patch by Stephan Linz, 27 Feb 2004 - avoid problems for targets without NFS download support
2004-03-12Add support for Siemens SX1 mobile phone;LABEL_2004_03_12_0130wdenk
add support for USB-based console (enable with "setenv stdout usbtty; setenv stdin usbtty")
2004-02-27* Patch by Pierre Aubert, 26 Feb 2004wdenk
add IDE support for MPC5200 * Patch by Masami Komiya, 26 Feb 2004: add autoload via NFS * Patch by Stephen Williams Use of CONFIG_SERIAL_SOFTWARE_FIFO in board.c consistent with uses elsewhere in the source.
2003-08-28- Added CONFIG_BOOTP_DNS2 and CONFIG_BOOTP_SEND_HOSTNAME to CONFIG_BOOTP_MASK.stroese
2003-06-05* Add support for RMU boardwdenk
* Add support for TQM862L at 100/50 MHz * Patch by Pantelis Antoniou, 02 Jun 2003: major reconstruction of networking code; add "ping" support (outgoing only!)
2003-06-03* Patches by Udi Finkelstein, 2 June 2003:LABEL_2003_06_04_0200wdenk
- Added support for custom keyboards, initialized by defining a board-specific drv_keyboard_init as well as defining CONFIG_KEYBOARD . - Added support for the RBC823 board. - cpu/mpc8xx/lcd.c now automatically calculates the Horizontal Pixel Count field. * Fix alignment problem in BOOTP (dhcp_leasetime option) [pointed out by Nicolas Lacressonničre, 2 Jun 2003] * Patch by Mark Rakes, 14 May 2003: add support for Intel e1000 gig cards. * Patch by Nye Liu, 3 Jun 2003: fix critical typo in MAMR definition (include/mpc8xx.h) * Fix requirement to align U-Boot image on 16 kB boundaries on PPC. * Patch by Klaus Heydeck, 2 Jun 2003 Minor changes for KUP4K configuration
2003-04-10Changed DHCP client to use ip address from server option field #54 from the ↵stroese
OFFER-paket in the server option field #54 in the REQUEST-paket. This fixes a problem using a Windows 2000 DHCP server, where the DHCP-server is not the TFTP-server.
2003-04-05* Patch by Arun Dharankar, 4 Apr 2003:LABEL_2003_04_05_0300wdenk
Add IDMA example code (tested on 8260 only) * Add support for Purple Board (MIPS64 5Kc) * Add support for MIPS64 5Kc CPUs * Fix missing setting of "loadaddr" and "bootfile" on ARM and MIPS * Patch by Denis Peter, 04 Apr 2003: - update MIP405-4 board * Patches by Denis Peter, 03 April 2003: - fix PCI IRQs on MPL boards - fix two more un-relocated pointer problems * Fix behaviour of "run" command: - print error message iv variable does not exist - terminate processing of arguments in case of error * Patches by Peter Figuli, 10 Mar 2003 - Add support for BTUART on PXA platform - Add support for WEP EP250 (PXA) board * Fix flash problems on INCA-IP; add tool to allow bruning images to flash using a BDI2000 * Implement fix for I2C Edge Conditions problem for all boards that use the bit-banging driver (common/soft_i2c.c) * Add patches by Robert Schwebel, 31 Mar 2003: - csb226 board: bring in sync with innokom/memsetup.S - csb226 board: fix MDREFR handling - misc doc fixes / extensions - innokom board: cleanup, MDREFR fix in memsetup.S, config update - add BOOT_PROGRESS to armlinux.c
2003-03-06* Patches by Robert Schwebel, 06 Mar 2003:wdenk
- fix bug in BOOTP code (must use NetCopyIP) - update of CSB226 port - clear BSS segment on XScale - added support for i2c_init_board() function - update to the Innokom plattform * Extend support for redundand environments for configurations where environment size < sector size
2002-09-27Initial revisionwdenk
