path: root/net/bootp.c
2016-06-12net: Handle an empty bootp extension sectionAndre Renaud
Avoid generating this section if there is nothing in it. Signed-off-by: Andre Renaud <andre@designa-electronics.com> Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-05-27net: Optionally use pxe client arch from variableAlexander Graf
The client architecture that we pass to a dhcp server depends on the target payload that we want to execute. An EFI binary has a different client arch than a legacy binary or a u-boot binary. So let's parameterize the pxe client arch field to allow an override via the distro script, so that our efi boot path can tell the dhcp server that it's actually an efi firmware. Signed-off-by: Alexander Graf <agraf@suse.de>
2016-05-27distro: Add efi pxe boot codeAlexander Graf
Now that we can expose network functionality to EFI applications, the logical next step is to load them via pxe to execute them as well. This patch adds the necessary bits to the distro script to automatically load and execute EFI payloads. It identifies the dhcp client as a uEFI capable PXE client, hoping the server returns a tftp path to a workable EFI binary that we can then execute. To enable boards that don't come with a working device tree preloaded, this patch also adds support to load a device tree from the /dtb directory on the remote tftp server. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-05-27bootp: Move vendor class identifier set to functionAlexander Graf
Both the dhcp as well as the bootp case add vendor class identifier parameters into their packets. Let's move that into a separate function to make overlaying easier. Signed-off-by: Alexander Graf <agraf@suse.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-05-27efi_loader: Add network access supportAlexander Graf
We can now successfully boot EFI applications from disk, but users may want to also run them from a PXE setup. This patch implements rudimentary network support, allowing a payload to send and receive network packets. With this patch, I was able to successfully run grub2 with network access inside of QEMU's -M xlnx-ep108. Signed-off-by: Alexander Graf <agraf@suse.de>
2016-03-27bootp: Prevent u-boot from using others responses.Anton Persson
In rare circumstances two dhcp clients may generate the same bootp ID. If this happens it is vital that the client also checks the hw address in the received response to prevent IP address conflicts. Signed-off-by: Anton Persson <don.juanton@gmail.com>
2016-02-26net: bootp: Add environment variable for timeout periodAlexandre Messier
There is currently one config option (CONFIG_NET_RETRY_COUNT) that is available to tune the retries of the network stack. Unfortunately, it is global to all protocols, and the value is interpreted differently in all of them. Add a new environment variable that directly sets the retry period for BOOTP timeouts. If this new value is not set, the period is still derived from the default number of retries, or from CONFIG_NET_RETRY_COUNT if defined. When both the new variable is set and CONFIG_NET_RETRY_COUNT is defined, the variable has precedence. Signed-off-by: Alexandre Messier <amessier@tycoint.com>
2016-01-28net: Add bootfile in DHCP RequestAlexandre Messier
Add the bootfile name in the DHCP Request packet, in addition to it already being sent in the DHCP Discover. This is needed by some DHCP servers so that the bootfile name is properly returned by the server to the client in the DHCP Ack, as expected by U-Boot. Signed-off-by: Alexandre Messier <amessier@tycoint.com>
2016-01-28net: bootp: Ignore packets whose yiaddr is 0Peng Fan
When doing `dhcp`, there is a bad dhcp server in my network which always reply dhcp request with yiaddr 0, which cause uboot can not successfully get ipaddr from the good dhcp server. But the Linux PC can get the ip address even if there is a bad dhcp server. This patch is to fix that even if there is a bad dhcp server, uboot can still get ipaddr and tftp work ok. The way is to ignore the packets from the bad dhcp server by filtering out the yiaddr whose value is 0. Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Wolfgang Denk <wd@denx.de> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-10-29net: parse DHCP options from overloaded file/sname fieldsStefan Brüns
If Option 52 in the vendor option field signals overloading of the file and/or sname fields, these field may contain additional options. Formatting of file/sname contained options is the same as in the vendor options field, but without the leading magic. Signed-off-by: Stefan Brüns <stefan.bruens@rwth-aachen.de> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-10-29net: Do not overwrite options found in overloaded 'file' fieldStefan Brüns
If 'file' is overloaded, it is wrong to get or put the bootfile name from it/to it. Signed-off-by: Stefan Brüns <stefan.bruens@rwth-aachen.de> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-10-28net: cancel timeout handler after DHCPACKStefan Brüns
Timeout handler should be stopped after reception of DHCPACK. If "autoload" is not set, the handler is immediately replaced by the TFTP handler, otherwise it may trigger before the next boot stage begins. Signed-off-by: Stefan Brüns <stefan.bruens@rwth-aachen.de> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-10-28net: Fix parsing of Bootp/DHCP option 0 (Pad)Stefan Brüns
Pad has no len byte, so the normal parsing code fails. Signed-off-by: Stefan Brüns <stefan.bruens@rwth-aachen.de> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-10-28net: send RFC1542 compliant value for bootp requestsStefan Brüns
RFC1542, 3.2: "The 'secs' field of a BOOTREQUEST message SHOULD represent the elapsed time, in seconds, since the client sent its first BOOTREQUEST message. Note that this implies that the 'secs' field of the first BOOTREQUEST message SHOULD be set to zero." Signed-off-by: Stefan Brüns <stefan.bruens@rwth-aachen.de> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-10-28net: reject Bootp/DHCP packets with bad OP valueStefan Brüns
Rename check_packet to check_reply_packet to make its function more obvious. The check for DHCP_* values is completely off, as it should compare against DHCP option 53 (Message Type). Only valid value for any Bootp/DHCP reply is BOOTREPLY. Signed-off-by: Stefan Brüns <stefan.bruens@rwth-aachen.de> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-10-28net: protect status led access in bootpThomas Chou
This fixes the error when STATUS_LED_BOOT is not defined. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-10-28net: bootp fix vci string on SPL-BootHannes Petermaier
If CONFIG_CMD_DHCP is enabled, the vci (vendor-class-identifier) string isn't inserted into the bootp-packet during SPL stage because the CONFIG_BOOTP_VCI_STRING instead CONFIG_SPL_NET_VCI_STRING We fix this with testing for CONFIG_SPL_BUILD and testing for existing CONFIG_SPL_NET_VCI_STRING. Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-09-07net: tftp: Move tftp.h file from ./net to ./include/netLukasz Majewski
This change gives the ability to reuse the <tftp.h> header file by other subsystems (like e.g. dfu). Without this change compilation error emerges for the legacy update.c file. Signed-off-by: Lukasz Majewski <l.majewski@majess.pl> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-04-18net: Fix incorrect DHCP/BOOTP packets on 64-bit systemsSergey Temerkhanov
This commit fixes incorrect DHCP/BOOTP packet layout caused by 'ulong' type size difference on 64 and 32-bit architectures. It also renames NetReadLong()/NetCopyLong() to net_read_u32/net_copy_u32() accordingly. Signed-off-by: Radha Mohan Chintakuntla <rchintakuntla@cavium.com> Signed-off-by: Sergey Temerkhanov <s.temerkhanov@gmail.com> Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Fix checkpatch.pl failures in net.cJoe Hershberger
Finish eliminating CamelCase from net.c and other failures Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Clean up DHCP variables and functionsJoe Hershberger
Make a thorough pass through all variables and function names contained within bootp.c and remove CamelCase and improve naming. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Cleanup internal packet buffer namesJoe Hershberger
This patch cleans up the names of internal packet buffer names that are used within the network stack and the functions that use them. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2015-04-18net: cosmetic: Name ethaddr variables consistentlyJoe Hershberger
Use "_ethaddr" at the end of variables and drop CamelCase. Make constant values actually 'const'. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Fixup var names for DHCP stringsJoe Hershberger
Remove CamelCase variable naming. Move the definition to the same compilation unit as the primary use. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Fixup var names related to boot fileJoe Hershberger
The variables around the bootfile were inconsistent and used CamelCase. Update them to make the code more readable. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Change IPaddr_t to struct in_addrJoe Hershberger
This patch is simply clean-up to make the IPv4 type that is used match what Linux uses. It also attempts to move all variables that are IP addresses use good naming instead of CamelCase. No functional change. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-12-08net: bootp: as CONFIG_BOOTP_SERVERIP is defined, keep bootfile not changedWu, Josh
Currenly when CONFIG_BOOTP_SERVERIP is defined, the SERVERIP is not changed when receive the BOOTP packet. But BOOTFILE is changed via BOOTP packet. As we will load the BOOTFILE from SERVERIP, if the BOOTFILE is modified by bootp packet but SERVERIP is not, that is not make sense. This patch make SERVERIP and BOOTFILE be consistent. If we define the CONFIG_BOOTP_SERVERIP, then SERVERIP and BOOTFILE will not changed by BOOTP packet. Only IP address is changed. Signed-off-by: Josh Wu <josh.wu@atmel.com>
2014-08-21net: More BOOTP retry timeout improvementsThierry Reding
It's not unusual for DHCP servers to take a couple hundred milliseconds to respond to DHCP discover messages. One possible reason for the delay can be that the server checks (typically using an ARP request) that the IP it's about to hand out isn't in use yet. To make matters worse, some servers may also queue up requests and process them sequentially, which can cause excessively long delays if clients retry too fast. Commit f59be6e850b3 ("net: BOOTP retry timeout improvements") shortened the retry timeouts significantly, but the BOOTP/DHCP implementation in U-Boot doesn't handle that well because it will ignore incoming replies to earlier requests. In one particular setup this increases the time it takes to obtain a DHCP lease from 630 ms to 8313 ms. This commit attempts to fix this in two ways. First it increases the initial retry timeout from 10 ms to 250 ms to give DHCP servers some more time to respond. At the same time a cache of outstanding DHCP request IDs is kept so that the implementation will know to continue transactions even after a retransmission of the DISCOVER message. The maximum retry timeout is also increased from 1 second to 2 seconds. An ID cache of size 4 will keep DHCP requests around for 8 seconds (once the maximum retry timeout has been reached) before dropping them. This should give servers plenty of time to respond. If it ever turns out that this isn't enough, the size of the cache can easily be increased. With this commit the DHCP lease on the above-mentioned setup still takes longer (1230 ms) than originally, but that's an acceptable compromise to improve DHCP lease acquisition time for a broader range of setups. To make it easier to benchmark DHCP in the future, this commit also adds the time it took to obtain a lease to the final "DHCP client bound to address x.x.x.x" message. Tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2014-08-09net: BOOTP retry timeout improvementsStephen Warren
Currently, the BOOTP code sends out its initial request as soon as the Ethernet driver indicates "link up". If this packet is lost or not replied to for some reason, the code waits for a 1s timeout before retrying. For some reason, such early packets are often lost on my system, so this causes an annoying delay. To optimize this, modify the BOOTP code to have very short timeouts for the first packet transmitted, but gradually increase the timeout each time a timeout occurs. This way, if the first packet is lost, the second packet is transmitted quite quickly and hence the overall delay is low. However, if there's still no response, we don't keep spewing out packets at an insane speed. It's arguably more correct to try and find out why the first packet is lost. However, it seems to disappear inside my Ethenet chip; the TX chip indicates no error during TX (not that it has much in the way of reporting...), yet wireshark on the RX side doesn't see any packet. FWIW, I'm using an ASIX USB Ethernet adapter. Perhaps "link up" is reported too early or based on the wrong condition in HW, and we should add some fixed extra delay into the driver. However, this would slow down every link up event even if it ends up not being needed in some cases. Having BOOTP retry quickly applies the fix/WAR to every possible Ethernet device, and is quite simple to implement, so seems a better solution. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2014-07-22bootp can use mdelayPavel Machek
Cleanup bootp code by using mdelay. Signed-off-by: Pavel Machek <pavel@denx.de> Acked-by: Marek Vasut <marex@denx.de>
2014-04-02lib: uuid: code refactor for proper maintain between uuid bin and stringPrzemyslaw Marczak
Changes in lib/uuid.c to: - uuid_str_to_bin() - uuid_bin_to_str() New parameter is added to specify input/output string format in listed functions This change allows easy recognize which UUID type is or should be stored in given string array. Binary data of UUID and GUID is always stored in big endian, only string representations are different as follows. String byte: 0 36 String char: xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx string UUID: be be be be be string GUID: le le le be be This patch also updates functions calls and declarations in a whole code. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Stephen Warren <swarren@nvidia.com> Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: trini@ti.com
2012-11-04net/: sparse fixesKim Phillips
bootp.c:44:14: warning: symbol 'dhcp_state' was not declared. Should it be static? bootp.c:45:15: warning: symbol 'dhcp_leasetime' was not declared. Should it be static? bootp.c:46:10: warning: symbol 'NetDHCPServerIP' was not declared. Should it be static? arp.c:30:17: warning: symbol 'NetArpWaitReplyIP' was not declared. Should it be static? arp.c:37:16: warning: symbol 'NetArpTxPacket' was not declared. Should it be static? arp.c:38:17: warning: symbol 'NetArpPacketBuf' was not declared. Should it be static? atheros.c:33:19: warning: symbol 'AR8021_driver' was not declared. Should it be static? net.c:183:7: warning: symbol 'PktBuf' was not declared. Should it be static? net.c:159:21: warning: symbol 'net_state' was not declared. Should it be static? ping.c:73:6: warning: symbol 'ping_start' was not declared. Should it be static? ping.c:82:13: warning: symbol 'ping_receive' was not declared. Should it be static? tftp.c:53:7: warning: symbol 'TftpRRQTimeoutMSecs' was not declared. Should it be static? tftp.c:54:5: warning: symbol 'TftpRRQTimeoutCountMax' was not declared. Should it be static? eth.c:125:19: warning: symbol 'eth_current' was not declared. Should it be static? Note: in the ping.c fix, commit a36b12f95a29647a06b5459198684fc142482020 "net: Move PING out of net.c" mistakenly carried the ifdef CMD_PING clause from when it was necessary to avoid warnings when it was embedded in net.c. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2012-10-01OMAP: networking support for SPLIlya Yanok
This patch adds support for networking in SPL. Some devices are capable of loading SPL via network so it makes sense to load the main U-Boot binary via network too. This patch tries to use existing network code as much as possible. Unfortunately, it depends on environment which in turn depends on other code so SPL size is increased significantly. No effort was done to decouple network code and environment so far. Signed-off-by: Ilya Yanok <ilya.yanok@cogentembedded.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Tom Rini <trini@ti.com>
2012-10-01net/bootp: add VCI support for BOOTP alsoIlya Yanok
Vendor Class Identifier option is common to BOOTP and DHCP and can be useful without PXE. So send VCI in both BOOTP and DHCP requests if CONFIG_BOOTP_VCI_STRING is defined. Signed-off-by: Ilya Yanok <ilya.yanok@cogentembedded.com> Signed-off-by: Tom Rini <trini@ti.com>
2012-09-27net: Quietly ignore DHCP Option 28 (Broadcast Address)Brian Rzycki
Some DHCP servers (notably dnsmasq) always transmit DHCP Option 28, Broadcast Address as specified in RFC 2132. Without this patch u-boot displays the warning: *** Unhandled DHCP Option in OFFER/ACK: 28 The patch suppresses the warning and ignores DHCP Option 28. There is no environment variable to set the broadcast address into and if for some reason u-boot needs the broadcast it can be calculated from ipaddr and netmask. Signed-off-by: Brian Rzycki <bmr@freescale.com>
2012-07-19net: bootp: fix buildbenoit.thebaudeau@advans
Fix NetSetState function name used with CONFIG_BOOTP_MAY_FAIL. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Joe Hershberger <joe.hershberger@gmail.com>
2012-07-08net: make net_rand.h inclusion depend on BOOTP_RANDOM_DELAYKim Phillips
commit "net: use common rand()/srand() functions" introduced the following build warning on the current u-boot-arm tree: $ ./MAKEALL MPC8313ERDB_66 Configuring for MPC8313ERDB_66 - Board: MPC8313ERDB, Options: SYS_66MHZ text data bss dec hex filename 271988 13976 41768 327732 50034 ./u-boot In file included from bootp.c:15:0: net_rand.h: In function 'srand_mac': net_rand.h:40:2: warning: implicit declaration of function 'srand' [-Wimplicit-function-declaration] adding this dependency fixes it. Cc: Michael Walle <michael@walle.cc> Cc: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Acked-by: Michael Walle <michael@walle.cc>
2012-05-23net: Add option CONFIG_BOOTP_MAY_FAILJoe Hershberger
This is useful if you want to look for a DHCP server, but try some other settings if not available. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2012-05-23net: Fix unused variable compile warningJoe Hershberger
If CONFIG_BOOTP_SERVERIP is not defined, unused variable warning is reported. This was fixed upstream using a compiler feature instead of a simple reorder of the statements. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-05-23net: Refactor to separate the UDP handler from the ARP handlerJoe Hershberger
Call a built-in dummy if none is registered... don't require protocols to register a handler (eliminating dummies) NetConsole now uses the ARP handler when waiting on arp (instead of needing a #define hack in arp.c) Clear handlers at the end of net loop Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2012-05-23net: Move debug trace to point of actionJoe Hershberger
2012-05-23net: Refactor bootp packet length computationsJoe Hershberger
Eliminate pointer subtraction that recovers values computed earlier Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2012-05-23net: Refactor IP, UPD, and ICMP header writing functionsJoe Hershberger
ICMP (ping) was reimplementing IP header code... it now shares code. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-05-23net: cosmetic: Rename OPT_SIZE to OPT_FIELD_SIZEJoe Hershberger
Clearer constant name. Also remove related BOOTP_SIZE which was unused and doesn't take into account VLAN packets. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-05-23net: cosmetic: Un-typedef Ethernet_tJoe Hershberger
Separate the Ethernet header from the 802 header. Base the size constants on the structs. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-05-23net: cosmetic: Un-typedef IP_tJoe Hershberger
Rename IP header related things to IP_UDP. The existing definition of IP_t includes UDP header, so name it to accurately describe the structure. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-05-23net: Move MAC-seeded rand out of bootp.cJoe Hershberger
Make the MAC-seeded random number generator available to /net in general. MAC-seeded rand will be needed by link-local as well, so give it an interface. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2012-05-15net: cosmetic: bootp.* checkpatch complianceJoe Hershberger
2012-05-15net: Remove volatile from net APIJoe Hershberger
2012-03-18bootstage: Plumb in bootstage calls for basic operationsSimon Glass
This inserts bootstage calls into tftp, usb start and bootm. We could go further, but this is a reasonable start to illustrate the concept. Signed-off-by: Simon Glass <sjg@chromium.org>
