path: root/net/arp.h
2014-10-10SPDX License cleanup for LiMon imported filesWolfgang Denk
A number of network related files were imported from the LiMon project; these contain a somewhat unclear license statement: Copyright 1994 - 2000 Neil Russell. (See License) I analyzed the source code of LiMon v1.4.2 which was used for this import. It does not contain any "License" file, but the top level directory contains a file "COPYING", which turns out to be GPL v2 of June 1991. So it is legitimate to conclude that the LiMon derived files are also to be released under GPLv2. Mark them as such. Signed-off-by: Wolfgang Denk <wd@denx.de>
2012-05-23net: Separate ArpRequest() into lower-level funcJoe Hershberger
Link-local support will need to send ARP packets, but needs more fine-grained control over the contents. Split the implementation into 2 parts so link-local can share the code. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-05-23net: Don't copy every packet that waits for an ARPJoe Hershberger
Use the NetArpTxPacket for the ARP packet, not to hold what used to be in NetTxPacket. This saves a copy and makes the code easier to understand. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2012-05-23net: cosmetic: Un-typedef Ethernet_tJoe Hershberger
Separate the Ethernet header from the 802 header. Base the size constants on the structs. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-05-23net: cosmetic: Un-typedef IP_tJoe Hershberger
Rename IP header related things to IP_UDP. The existing definition of IP_t includes UDP header, so name it to accurately describe the structure. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-05-23net: Move ARP out of net.cJoe Hershberger
Separate this functionality out of the net.c behemoth Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2003-06-05* Add support for RMU boardwdenk
* Add support for TQM862L at 100/50 MHz * Patch by Pantelis Antoniou, 02 Jun 2003: major reconstruction of networking code; add "ping" support (outgoing only!)
2000-12-28Initial revisionwdenk
