path: root/net/arp.c
2015-10-28net/arp: account for ARP delay, avoid duplicate packets on timeoutStefan Brüns
eth_rx() in the main reception loop may trigger sending a packet which is already timed out (or will immediately) upon reception of an ARP reply. As long as the ARP reply is pending, the timeout handler of a packet should be postponed. Happens on TFTP with bad network (e.g. WLAN). Signed-off-by: Stefan Brüns <stefan.bruens@rwth-aachen.de> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-10-28net/arp: Do not run net_start_again() on timeoutStefan Brüns
net_start_again() will be called from net_loop() if state is NETLOOP_FAIL. Signed-off-by: Stefan Brüns <stefan.bruens@rwth-aachen.de> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-04-18net: cosmetic: Fix checkpatch.pl failures in net.cJoe Hershberger
Finish eliminating CamelCase from net.c and other failures Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Clean up ARP variables and functionsJoe Hershberger
Make a thorough pass through all variables and function names contained within arp and remove CamelCase and improve naming. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Cleanup internal packet buffer namesJoe Hershberger
This patch cleans up the names of internal packet buffer names that are used within the network stack and the functions that use them. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2015-04-18net: cosmetic: Name ethaddr variables consistentlyJoe Hershberger
Use "_ethaddr" at the end of variables and drop CamelCase. Make constant values actually 'const'. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Change IPaddr_t to struct in_addrJoe Hershberger
This patch is simply clean-up to make the IPv4 type that is used match what Linux uses. It also attempts to move all variables that are IP addresses use good naming instead of CamelCase. No functional change. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-10-10SPDX License cleanup for LiMon imported filesWolfgang Denk
A number of network related files were imported from the LiMon project; these contain a somewhat unclear license statement: Copyright 1994 - 2000 Neil Russell. (See License) I analyzed the source code of LiMon v1.4.2 which was used for this import. It does not contain any "License" file, but the top level directory contains a file "COPYING", which turns out to be GPL v2 of June 1991. So it is legitimate to conclude that the LiMon derived files are also to be released under GPLv2. Mark them as such. Signed-off-by: Wolfgang Denk <wd@denx.de>
2012-11-04net/: sparse fixesKim Phillips
bootp.c:44:14: warning: symbol 'dhcp_state' was not declared. Should it be static? bootp.c:45:15: warning: symbol 'dhcp_leasetime' was not declared. Should it be static? bootp.c:46:10: warning: symbol 'NetDHCPServerIP' was not declared. Should it be static? arp.c:30:17: warning: symbol 'NetArpWaitReplyIP' was not declared. Should it be static? arp.c:37:16: warning: symbol 'NetArpTxPacket' was not declared. Should it be static? arp.c:38:17: warning: symbol 'NetArpPacketBuf' was not declared. Should it be static? atheros.c:33:19: warning: symbol 'AR8021_driver' was not declared. Should it be static? net.c:183:7: warning: symbol 'PktBuf' was not declared. Should it be static? net.c:159:21: warning: symbol 'net_state' was not declared. Should it be static? ping.c:73:6: warning: symbol 'ping_start' was not declared. Should it be static? ping.c:82:13: warning: symbol 'ping_receive' was not declared. Should it be static? tftp.c:53:7: warning: symbol 'TftpRRQTimeoutMSecs' was not declared. Should it be static? tftp.c:54:5: warning: symbol 'TftpRRQTimeoutCountMax' was not declared. Should it be static? eth.c:125:19: warning: symbol 'eth_current' was not declared. Should it be static? Note: in the ping.c fix, commit a36b12f95a29647a06b5459198684fc142482020 "net: Move PING out of net.c" mistakenly carried the ifdef CMD_PING clause from when it was necessary to avoid warnings when it was embedded in net.c. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2012-07-10net: fix typo in arp clean upMike Frysinger
The clean up patch missed an &, so we end up passing an int rather than a pointer to the sprintf function. arp.c: In function 'ArpReceive': arp.c:197: warning: format '%p' expects type 'void *', but argument 3 has type 'int' Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-05-23net: Allow filtering on debug traces in the net subsystemJoe Hershberger
Add several levels of DEBUG prints so that you can limit the noise to the severety of your problem. DEBUG_LL_STATE = Link local state machine changes DEBUG_DEV_PKT = Packets or info directed to the device DEBUG_NET_PKT = Packets on info on the network at large DEBUG_INT_STATE = Internal network state changes Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-05-23net: Work-around for brain-damaged Cisco equipment with arp-proxyJoe Hershberger
Cisco's arp-proxy feature fails to ignore the link-local address range This means that a link-local device on a network with this Cisco equipment will reply to ARP requests for our device (in addition to our reply). If we happen to reply first, the requester's ARP table will be populated with our MAC address, and one packet will be sent to us... shortly following this, the requester will get an ARP reply from the Cisco equipment telling the requester to send packets their way instead of to our device from now on. This work-around detects this link-local condition and will delay replying to the ARP request for 5ms so that the first packet is sent to the Cisco equipment and all following packets are sent to our device. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-05-23net: Separate ArpRequest() into lower-level funcJoe Hershberger
Link-local support will need to send ARP packets, but needs more fine-grained control over the contents. Split the implementation into 2 parts so link-local can share the code. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-05-23net: Don't copy every packet that waits for an ARPJoe Hershberger
Use the NetArpTxPacket for the ARP packet, not to hold what used to be in NetTxPacket. This saves a copy and makes the code easier to understand. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2012-05-23net: Remove static allocation for MAC address in PingSend()Joe Hershberger
Don't force ARP clients to return the MAC address if they don't care (such as ping) Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-05-23net: Add net_update_ether() to handle ARP and Ping repliesJoe Hershberger
When the network is VLAN or SNAP, net_update_ether() will preserve the original Ethernet packet header and simply replace the src and dest MACs and the protocol Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2012-05-23net: Refactor to separate the UDP handler from the ARP handlerJoe Hershberger
Call a built-in dummy if none is registered... don't require protocols to register a handler (eliminating dummies) NetConsole now uses the ARP handler when waiting on arp (instead of needing a #define hack in arp.c) Clear handlers at the end of net loop Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2012-05-23net: Refactor to use NetSendPacket instead of eth_send directlyJoe Hershberger
Use this entry-point consistently across the net/ code Use a static inline function to preserve code size Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2012-05-23net: Refactor packet length computationsJoe Hershberger
Save the length when it is computed instead of forgetting it and subtracting pointers to figure it out again. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-05-23net: cosmetic: Replace magic numbers in arp.c with constantsJoe Hershberger
Use field names and sizes when accessing ARP packets Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-05-23net: cosmetic: Rename tmp to reply_ip_addr in arp.cJoe Hershberger
Renamed for clarity Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2012-05-23net: cosmetic: Un-typedef ARP_tJoe Hershberger
Remove typedef and lower-case letters Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-05-23net: cosmetic: Un-typedef Ethernet_tJoe Hershberger
Separate the Ethernet header from the 802 header. Base the size constants on the structs. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-05-23net: cosmetic: Un-typedef IP_tJoe Hershberger
Rename IP header related things to IP_UDP. The existing definition of IP_t includes UDP header, so name it to accurately describe the structure. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-05-23net: Move ARP out of net.cJoe Hershberger
Separate this functionality out of the net.c behemoth Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2003-06-05* Add support for RMU boardwdenk
* Add support for TQM862L at 100/50 MHz * Patch by Pantelis Antoniou, 02 Jun 2003: major reconstruction of networking code; add "ping" support (outgoing only!)
2002-09-28Initial revisionwdenk
