path: root/net/Kconfig
2015-05-21net: Handle ethaddr changes as an env callbackJoe Hershberger
When the ethaddr is changed in the env, update the device pdata at the same time (only if it is probed for the DM case; only if registered for the non-DM case). Again this gets us closer to completely non-polled env needed to simplify the net_loop. This requires that the NET feature select the REGEX feature. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2015-05-19net: Implement random ethaddr fallback in eth.cJoe Hershberger
Implement the random ethaddr fallback in eth.c so it is in a common place and not reimplemented in each board or driver that wants this behavior. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-09-24kconfig: add blank Kconfig filesMasahiro Yamada
This would be useful to start moving various config options. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
