path: root/nand_spl
2010-01-27Nand boot: Add nand boot support for MPC8569mds boardLiu Yu
This patch add nand boot support for MPC8569mds board. Signed-off-by: Liu Yu <yu.liu@freescale.com>
2009-11-04ppc/85xx: Fix inclusion of 83xx immap in 85xx buildsKumar Gala
The nand_boot_fsl_elbc.c is shared between 83xx & 85xx however we should not be including the immap_83xx.h when building 85xx. We can just get this all from common.h Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-10-26ppc/85xx: Fix compiler warning in nand_spl/.../p1_p2_rdb/nand_boot.cKumar Gala
nand_boot.c: In function 'board_init_f': nand_boot.c:44: warning: 'sys_clk' may be used uninitialized in this function Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-10-26ppc/85xx: Fix building NAND_SPL out of treeKumar Gala
We need to source files to exist in the O=<FOO> nand_spl dir when we build out of tree. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-10-16ppc/P1_P2_RDB: NAND Boot SupportDipen Dudhat
NAND Boot support for P1 and P2 series RDB platforms. This patch is derived from NAND Boot support on MPC8536DS. Signed-off-by: Dipen Dudhat <dipen.dudhat@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-30Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxWolfgang Denk
2009-09-30NAND boot: MPC8536DS supportMingkai Hu
MPC8536E can support booting from NAND flash which uses the image u-boot-nand.bin. This image contains two parts: a 4K NAND loader and a main U-Boot image. The former is appended to the latter to produce u-boot-nand.bin. The 4K NAND loader includes the corresponding nand_spl directory, along with the code twisted by CONFIG_NAND_SPL. The main U-Boot image just like a general U-Boot image except the parts that included by CONFIG_SYS_RAMBOOT. When power on, eLBC will automatically load from bank 0 the 4K NAND loader into the FCM buffer RAM where CPU can execute the boot code directly. In the first stage, the NAND loader copies itself to RAM or L2SRAM to free up the FCM buffer RAM, then loads the main image from NAND flash to RAM or L2SRAM and boot from it. This patch implements the NAND loader to load the main image into L2SRAM, so the main image can configure the RAM by using SPD EEPROM. In the first stage, the NAND loader copies itself to the second to last 4K address space, and uses the last 4K address space as the initial RAM for stack. Obviously, the size of L2SRAM shouldn't be less than the size of the image used. If so, the workaround is to generate another image that includes the code to configure the RAM by SPD and load it to L2SRAM first, then relocate the main image to RAM to boot up. Signed-off-by: Mingkai Hu <Mingkai.hu@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-28ppc4xx: Convert PPC4xx SDRAM defines from lower case to upper caseStefan Roese
The latest PPC4xx register cleanup patch missed some SDRAM defines. This patch now changes lower case UIC defines to upper case. Also some names are changed to match the naming in the IBM/AMCC users manuals (e.g. mem_mcopt1 -> SDRAM0_CFG). Signed-off-by: Stefan Roese <sr@denx.de>
2009-09-11ppc4xx: Big cleanup of PPC4xx definesStefan Roese
This patch cleans up multiple issues of the 4xx register (mostly DCR, SDR, CPR, etc) definitions: - Change lower case defines to upper case (plb4_acr -> PLB4_ACR) - Change the defines to better match the names from the user's manuals (e.g. cprpllc -> CPR0_PLLC) - Removal of some unused defines Please test this patch intensive on your PPC4xx platform. Even though I tried not to break anything and tested successfully on multiple 4xx AMCC platforms, testing on custom platforms is recommended. Signed-off-by: Stefan Roese <sr@denx.de>
2009-08-21Fix all linker scripts for older binutils versions (pre-2.16)Wolfgang Denk
Commit f62fb99941c6 fixed handling of all rodata sections by using a wildcard combined with calls to ld's builtin functions SORT_BY_ALIGNMENT() and SORT_BY_NAME(). Unfortunately these functions were only introduced with biunutils version 2.16, so the modification broke building with all tool chains using older binutils. This patch makes it work again. This is done by omitting the use of these functions for such old tool chains. This will result in slightly larger target binaries, as the rodata sections are no longer in optimal order alignment-wise which reauls in unused gaps, but the effect was found to be insignificant - especially compared to the fact that you cannot build U-Boot at all in the current state. As ld seems to have no support for conditionals we run the linker script through the C preprocessor which can be easily used to remove the unwanted function calls. Note that the C preprocessor must be run with the "-ansi" (or a "-std=") option to make sure all the system-specific predefined macros outside the reserved namespace are suppressed. Otherise, cpp might for example substitute "powerpc" to "1", thus corrupting for example "OUTPUT_ARCH(powerpc)" etc. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Mike Frysinger <vapier@gentoo.org>
2009-08-21NAND boot: fix nand_load overlap issueMingkai Hu
The code copy data from NAND flash block by block, so when the data length isn't a whole-number multiple of the block size, it will overlap the rest space. Signed-off-by: Mingkai Hu <Mingkai.hu@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-07-30ppc4xx: Canyonlands-NAND-boot: Support 2 Crucial 512MByte SODIMM'sStefan Roese
Some Canyonlands boards are equipped with different SODIMM's. This is no problem with the "normal" NOR booting Canyonlands U-Boot, since it automatically detects the SODIMM's via SPD data and correctly configures them. But the NAND booting version is different. Here we only have 4k of image size to completely setup the hardware, including DDR2 setup. So we need to use a fixed DDR2 setup here. This doesn't work for different SODIMM's right now. Currently only this Crucial SODIMM is support: CT6464AC667.8FB (dual ranked) Now some boards are shipped with this SODIMM: CT6464AC667.4FE (single ranked) This patch now supports both SODIMM's by configuring first for the dual ranked DIMM. A quick shows, if this module is really installed. If this test fails, the DDR2 controller is re-configured for the single ranked SODIMM. Tested with those SODIMM's: CT6464AC667.8FB (dual ranked) CT6464AC667.4FE (single ranked) Signed-off-by: Stefan Roese <sr@denx.de>
2009-07-16nand/ppc4xx: Move PPC4xx NAND driver to common NAND driver directoryStefan Roese
Signed-off-by: Stefan Roese <sr@denx.de> Cc: Scott Wood <scottwood@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-07-07nand_spl: Fix cmd_ctrl usage in nand_boot.c.Scott Wood
When adding large page NAND support to this file, I had a misunderstanding about the exact semantics of NAND_CTRL_CHANGE (which isn't documented anywhere I can find) -- it is apparently just a hint to drivers, which aren't required to preserve the old value for subsequent non-"change" invocations. This change makes nand_boot.c no longer assume this. Note that this happened to work by chance with some NAND drivers, which don't preserve the value, but treat 0 equivalently to NAND_CTRL_ALE. I don't have hardware to test this, so any testing is appreciated. Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-07-07nand_spl: read environment early, when booting from NAND using nand_splGuennadi Liakhovetski
Currently, when booting from NAND using nand_spl, in the beginning the default environment is used until later in boot process the dynamic environment is read out. This way environment variables that must be interpreted early, like the baudrate or "silent", cannot be modified dynamically and remain at their default values. Fix this problem by reading out main and redundand (if used) copies of the environment in the nand_spl code. Signed-off-by: Guennadi Liakhovetski <lg@denx.de> Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-07-06MX31: Add NAND SPL boot support to i.MX31 PDK board.Magnus Lilja
Signed-off-by: Magnus Lilja <lilja.magnus@gmail.com>
2009-06-21MX31: Add NAND SPL for i.MX31.Magnus Lilja
This patch adds the NAND SPL framework needed to boot i.MX31 boards from NAND. It has been tested on a i.MX31 PDK board with large page NAND. Small page NANDs should work as well, but this has not been tested. Note: The i.MX31 NFC uses a non-standard layout for large page NANDs, whether this is compatible with a particular setup depends on how the NAND device is programmed by the flash programmer (e.g. JTAG debugger). The patch is based on the work by Maxim Artamonov. Signed-off-by: Maxim Artamonov <scn1874@yandex.ru> Signed-off-by: Magnus Lilja <lilja.magnus@gmail.com>
2009-05-15Fix e-mail address of Gary Jennejohn.Detlev Zundel
Signed-off-by: Detlev Zundel <dzu@denx.de>
2009-03-09SIMPC8313 board: fix out of tree building.Wolfgang Denk
Fix typo in makefile which broke out of tree builds. Also use expolicit "rm" instead of "ln -sf" which is known to be unreliable. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-01-28Merge branch 'master' of git://git.denx.de/u-boot-nand-flashWolfgang Denk
2009-01-28mpc83xx: fix undefined reference to `flush_cache' error in simpc8313 buildKim Phillips
extend commit c70564e6b1bd08f3230182392238907f3531a87e "NAND: Fix cache and memory inconsistency issue" to add the cache.o dependency to the simpc8313 build and fix this: ...Large Page NAND...Configuring for SIMPC8313 board... nand_boot_fsl_elbc.o: In function `nand_boot': nand_spl/board/sheldon/simpc8313/nand_boot_fsl_elbc.c:150: undefined reference to `flush_cache' make[1]: *** [/home/r1aaha/git/u-boot-mpc83xx/nand_spl/u-boot-spl] Error 1 make: *** [nand_spl] Error 2 Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-01-26nand_spl: Fix compile problem with board_nand_init() prototypeStefan Roese
This patch removes the now obsolete and additionally wrongly defined board_nand_init() prototype from nand_spl/nand_boot.c. Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-01-23Merge branch 'next'Kim Phillips
2009-01-23mpc83xx: New board support for SIMPC8313Ron Madrid
This patch will create a new board, SIMPC8313, from Sheldon Instruments. This board boots from NAND devices and is configureable for either large or small page devices. The board supports non-soldered DDR2, one ethernet port, a Marvell 88E1118 PHY, and PCI host support. The board also has a FPGA connected to the eLBC providing glue logic to a TMS320C67xx DSP. Signed-off-by: Ron Madrid <ron_madrid@sbcglobal.net> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-01-23NAND: Fix cache and memory inconsistency issueDave Liu
We load the secondary stage u-boot image from NAND to system memory by nand_load, but we did not flush d-cache to memory, nor invalidate i-cache before we jump to RAM. When the system has cache enabled and the TLB/page attribute of system memory is cacheable, it will cause issues. - 83xx family is using the d-cache lock, so all of d-cache access is cache-inhibited. so you can't see the issue. - 85xx family is using d-cache, i-cache enable, partial cache lock. you will see the issue. This patch fixes the cache issue. Signed-off-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-10-29Make Freescale local bus registers available for both 83xx and 85xx.Haiying Wang
- Rename lbus83xx_t to fsl_lbus_t and move it to asm/fsl_lbc.h so that it can be shared by both 83xx and 85xx - Remove lbus83xx_t and replace it with fsl_lbus_t in all 83xx boards files which use lbus83xx_t. - Move FMR, FIR, FCR, FPAR, LTESR from mpc83xx.h to asm/fsl_lbc.h so that 85xx can share them. Signed-off-by: Jason Jin <Jason.Jin@freescale.com> Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-08-31ARM: Add support for S3C6400 based SMDK6400 boardGuennadi Liakhovetski
SMDK6400 can only boot U-Boot from NAND-flash. This patch adds a nand_spl driver for it too. The board can also boot from the NOR flash, but due to hardware limitations it can only address 64KiB on it, which is not enough for U-Boot. Based on the original sources by Samsung for U-Boot 1.1.6. Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
2008-08-21NAND: Remove delay from nand_boot_fsl_elbc.c.Scott Wood
It was for debugging purposes, and shouldn't have been left in. Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-08-14Coding Style cleanup, update CHANGELOGWolfgang Denk
2008-08-12nand_spl: Support page-aligned read in nand_load, use chipselectGuennadi Liakhovetski
Supporting page-aligned reads doesn't incure any sinificant overhead, just a small change in the algorithm. Also replace in_8 with readb, since there is no in_8 on ARM. Signed-off-by: Guennadi Liakhovetski <lg@denx.de> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-08-12NAND boot: Update large page support for current API.Scott Wood
Also, remove the ctrl variable in favor of passing the constants directly, and remove redundant (u8) casts. Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-08-12NAND boot: MPC8313ERDB supportScott Wood
Note that with older board revisions, NAND boot may only work after a power-on reset, and not after a warm reset. I don't have a newer board to test on; if you have a board with a 33MHz crystal, please let me know if it works after a warm reset. Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-08-12NAND: Update nand_spl driver to match updated nand subsystemStefan Roese
This patch changes the NAND booting driver nand_spl/nand_boot.c to match the new infrastructure from the updated NAND subsystem. This NAND subsystem was recently synced again with the Linux 2.6.22 MTD/NAND subsystem. Signed-off-by: Stefan Roese <sr@denx.de>
2008-07-30NAND: $(obj)-qualify ecc.h in kilauea NAND boot Makefile.Scott Wood
This fixes building out-of-tree. Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-06-04ppc4xx: Fix problem with SDRAM init in bamboo NAND booting portStefan Roese
This patch fixes a problem spotted by Eugene O'Brian (thanks Eugene) introduced by the commit: ppc4xx/NAND_SPL: Consolidate 405 and 440 NAND booting code in start.S With this patch SDRAM will get initialized again and booting from NAND is working again. Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Eugene O'Brien <eugene.obrien@advantechamt.com>
2008-06-03Remove shell variable UNDEF_SYM.Kenneth Johansson
UNDEF_SYM is a shell variable in the main Makefile used to force the linker to add all u-boot commands to the final image. It has no use here. Signed-off-by: Kenneth Johansson <kenneth@southpole.se>
2008-06-03ppc4xx: Change Kilauea to use the common DDR2 init functionStefan Roese
This patch changes the kilauea and kilauea_nand (for NAND booting) board port to not use a board specific DDR2 init routine anymore. Now the common code from cpu/ppc4xx is used. Thanks to Grant Erickson for all his basic work on this 405EX early bootup. Signed-off-by: Stefan Roese <sr@denx.de>
2008-06-03ppc4xx/NAND_SPL: Consolidate 405 and 440 NAND booting code in start.SStefan Roese
This patch consolidates the 405 and 440 parts of the NAND booting code selected via CONFIG_NAND_SPL. Now common code is used to initialize the SDRAM by calling initdram() and to "copy/relocate" to SDRAM/OCM/etc. Only *after* running from this location, nand_boot() is called. Please note that the initsdram() call is now moved from nand_boot.c to start.S. I experienced problems with some boards like Kilauea (405EX), which don't have internal SRAM (OCM) and relocation needs to be done to SDRAM before the NAND controller can get accessed. When initdram() is called later on in nand_boot(), this can lead to problems with variables in the bss sections like nand_ecc_pos[]. Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Scott Wood <scottwood@freescale.com>
2008-05-14ppc4xx: Individual handling of ddr2_fixed.c for canyonlands_nand buildStefan Roese
Canyonlands has a file ddr2_fixed.c which needs special treatment when building in separate directory. It has to be linked to build directory otherwise it is not seen. Signed-off-by: Stefan Roese <sr@denx.de>
2008-04-30ppc4xx: Adapt Canyonlands fixed DDR2 setup to new DIMM moduleStefan Roese
This patch changes the Canyonlands/Glacier fixed DDR2 controller setup used for NAND booting to match the values needed for the new 512MB DIMM modules shipped with the productions boards: Crucial: CT6464AC667.8FB Signed-off-by: Stefan Roese <sr@denx.de>
2008-04-25Merge branch 'master' of git://www.denx.de/git/u-boot-nand-flashWolfgang Denk
2008-04-18ppc4xx: Change Canyonlands to support booting from 2k page NAND devicesStefan Roese
2008-04-18ppc4xx: Adjust Canyonlands fixed DDR2 setup (NAND booting) to 512MB SODIMMStefan Roese
2008-04-18nand_spl: Update nand_spl to support 2k page size NAND devicesStefan Roese
This patch adds support for booting from 2k page sized NAND device (e.g. Micron 29F2G08AAC). Tested on AMCC Canyonlands. Signed-off-by: Stefan Roese <sr@denx.de>
2008-03-15ppc4xx: Add Canyonlands NAND booting supportStefan Roese
460EX doesn't support a fixed bootstrap option to boot from 512 byte page NAND devices. The only bootstrap option for NAND booting is option F for 2k page devices. So to boot from a 512 bype page device, the I2C bootstrap EEPROM needs to be programmed accordingly. This patch adds basic NAND booting support for the AMCC Canyonlands aval board and also adds support to the "bootstrap" command, to enable NAND booting I2C setting. Tested with 512 byte page NAND device (32MByte) on Canyonlands. Signed-off-by: Stefan Roese <sr@denx.de>
