path: root/nand_spl
2007-03-06[PATCH] Speed optimization of AMCC Sequoia/Rainier DDR2 setupStefan Roese
As provided by the AMCC applications team, this patch optimizes the DDR2 setup for 166MHz bus speed. The values provided are also save to use on a "normal" 133MHz PLB bus system. Only the refresh counter setup has to be adjusted as done in this patch. For this the NAND booting version had to include the "speed.c" file from the cpu/ppc4xx directory. With this addition the NAND SPL image will just fit into the 4kbytes of program space. gcc version 4.x as provided with ELDK 4.x is needed to generate this optimized code. Signed-off-by: Stefan Roese <sr@denx.de>
2007-01-05[PATCH] Add DDR2 optimization code for Sequoia (440EPx) boardStefan Roese
This code will optimize the DDR2 controller setup on a board specific basis. Note: This code doesn't work right now on the NAND booting image for the Sequoia board, since it doesn't fit into the 4kBytes for the SPL image. Signed-off-by: Stefan Roese <sr@denx.de>
2006-10-23Fix sequoia separate object direcory building problems.Marian Balakowicz
2006-10-09Coding style cleanupWolfgang Denk
2006-09-12Add NAND environment support for PPC440EPx Sequoia NAND boot configStefan Roese
Patch by Stefan Roese, 12 Sep 2006
2006-09-12Update NAND boot documentationStefan Roese
2006-09-07Add support for AMCC Sequoia PPC440EPx eval boardStefan Roese
- Add support for PPC440EPx & PPC440GRx - Add support for PPC440EP(x)/GR(x) NAND controller in cpu/ppc4xx directory - Add NAND boot functionality for Sequoia board, please see doc/README.nand-boot-ppc440 for details - This Sequoia NAND image doesn't support environment in NAND for now. This will be added in a short while. Patch by Stefan Roese, 07 Sep 2006
