The migration of boards from Makefile to boards.cfg was due for v2012.03, but
smdk6400 did not follow, and it does not build, so move it to scrapyard. It will
still be possible to restore it from the Git history before fixing it.
Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
Use __image_copy_end instead of __bss_start for the end of the image to
relocate. This is the same as commit 033ca72, but applied to all ARM start.S.
This is a more appropriate symbol naming for an image copy & relocate feature,
and this also saves a useless copy of data put between __image_copy_end and
__bss_start in linker scripts (e.g. relocation information, or MMU
initialization tables used only before jumping to the relocated image).
Albert's rework of the linker scripts conflicted with Simon's making
everyone use __bss_end. We also had a minor conflict over
README.scrapyard being added to in mainline and enhanced in
u-boot-arm/master with proper formatting.
arch/arm/cpu/ixp/u-boot.lds
arch/arm/cpu/u-boot.lds
arch/arm/lib/Makefile
board/actux1/u-boot.lds
board/actux2/u-boot.lds
board/actux3/u-boot.lds
board/dvlhost/u-boot.lds
board/freescale/mx31ads/u-boot.lds
doc/README.scrapyard
include/configs/tegra-common.h
Build tested for all of ARM and run-time tested on am335x_evm.
Note this is a tree-wide change affecting multiple architectures.
At present we use __bss_start, but mostly __bss_end__. This seems
inconsistent and in a number of places __bss_end is used instead.
Change to use __bss_end for the BSS end symbol throughout U-Boot. This
makes it possible to use the asm-generic/sections.h file on all
archs.
Refactor linker-generated array code so that symbols
which were previously linker-generated are now compiler-
generated. This causes relocation records of type
R_ARM_ABS32 to become R_ARM_RELATIVE, which makes
code which uses LGA able to run before relocation as
well as after.
Note: this affects more than ARM targets, as linker-
lists span possibly all target architectures, notably
PowerPC.
arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds
arch/arm/cpu/arm926ejs/spear/u-boot-spl.lds
arch/arm/cpu/armv7/omap-common/u-boot-spl.lds
board/ait/cam_enc_4xx/u-boot-spl.lds
board/davinci/da8xxevm/u-boot-spl-da850evm.lds
board/davinci/da8xxevm/u-boot-spl-hawk.lds
board/vpac270/u-boot-spl.lds
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
The command declaration now uses the new LG-array method to generate
list of commands. Thus the __u_boot_cmd section is now superseded and
redundant and therefore can be removed. Also, remove externed symbols
associated with this section from include/command.h .
Cc: Joe Hershberger <joe.hershberger@gmail.com>
Cc: Mike Frysinger <vapier@gentoo.org>
Add section for the linker-generated lists into all possible linker
files, so that everyone can easily use these lists. This is mostly
a mechanical adjustment.
s3c64xx.c implemented its own nand_read_byte, nand_write_buf and
nand_read_buf functions. This provoked a regression when these functions
were made public by patch 55f429bb39614a16b1bacc9a8bea9ac01a60bfc8.
This deletes these duplicated functions from s3c64xx.c and adds the generic
implementations in nand_base.c to the spl Makefile. It also adds
-ffcuntion-sections and -gc-sections to the compilation flags of the SPL to
avoid errors originating from unused functions in nand_base.c.
Description of the regression:
http://article.gmane.org/gmane.comp.boot-loaders.u-boot/108873
Signed-off-by: Simon Schwarz <simonschwarzcor@gmail.com>
Cc: scottwood@freescale.com
Cc: s-paulraj@ti.com
Cc: albert.u.boot@aribaud.net
Since we rename _end to __bss_end__, But we need add _end symbol for
the end of u-boot image.
Signed-off-by: Zhong Hongbo <bocui107@gmail.com>
Commit 6dc1ece "Introduce a new linker flag LDFLAGS_FINAL" modified a
number of Makefiles in a way that broke out-of-tree builds. The
problem was that $(nandobj) was used before it got defined.
Fix this.
In the nand_spl feature of SMDK6400. Add some relocation symbols to
nand_spl/board/samsung/smdk6400/u-boot.lds to fix the compile error.
Currently, _end is used for end of BSS section. We want _end to mean
end of u-boot image, so we rename _end to __bss_end__ first.
Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
commit 8aba9dceebb14144e07d19593111ee3a999c37fc
Divides variable of linker flags to LDFLAGS-u-boot and LDFLAGS
breaks the usage of --gc-section to build nand_spl. We still need linker option
--gc-section for every uboot image, not only the main one. LDFLAGS_FINAL passes
the --gc-sections to each uboot image.
To get the proper linker flags, we use LDFLAGS and LDFLAGS_FINAL to replace
PLATFORM_LDFLAGS in the Makefile of each nand_spl board.
Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
Remove the board_init_f function from nand_spl/nand_boot.c. This
function is to be defined by all boards using the nand_spl
functionality in their individual board directory.
Currently this function was being used by the smdk6400 board. Added
the board specific function definition.
Signed-off-by: Sughosh Ganu <urwithsughosh@gmail.com>
Acked-by: Scott Wood <scottwood@freescale.com>
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
The change is currently needed to be able to remove the board
configuration scripting from the top level Makefile and replace it by
a simple, table driven script.
Moving this configuration setting into the "CONFIG_*" name space is
also desirable because it is needed if we ever should move forward to
a Kconfig driven configuration system.
Commit f62fb99941c6 fixed handling of all rodata sections by using a
wildcard combined with calls to ld's builtin functions SORT_BY_ALIGNMENT()
and SORT_BY_NAME(). Unfortunately these functions were only
introduced with biunutils version 2.16, so the modification broke
building with all tool chains using older binutils.
This patch makes it work again. This is done by omitting the use of
these functions for such old tool chains. This will result in
slightly larger target binaries, as the rodata sections are no longer
in optimal order alignment-wise which reauls in unused gaps, but the
effect was found to be insignificant - especially compared to the fact
that you cannot build U-Boot at all in the current state.
As ld seems to have no support for conditionals we run the linker
script through the C preprocessor which can be easily used to remove
the unwanted function calls.
Note that the C preprocessor must be run with the "-ansi" (or a
"-std=") option to make sure all the system-specific predefined
macros outside the reserved namespace are suppressed. Otherise, cpp
might for example substitute "powerpc" to "1", thus corrupting for
example "OUTPUT_ARCH(powerpc)" etc.
Signed-off-by: Detlev Zundel <dzu@denx.de>
A recent gcc added a new unaligned rodata section called '.rodata.str1.1',
which needs to be added the the linker script. Instead of just adding this
one section, we use a wildcard ".rodata*" to get all rodata linker section
gcc has now and might add in the future.
However, '*(.rodata*)' by itself will result in sub-optimal section
ordering. The sections will be sorted by object file, which causes extra
padding between the unaligned rodata.str.1.1 of one object file and the
aligned rodata of the next object file. This is easy to fix by using the
SORT_BY_ALIGNMENT command.
This patch has not be tested one most of the boards modified. Some boards
have a linker script that looks something like this:
*(.text)
. = ALIGN(16);
*(.rodata)
*(.rodata.str1.4)
*(.eh_frame)
I change this to:
*(.text)
. = ALIGN(16);
*(.eh_frame)
*(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*)))
This means the start of rodata will no longer be 16 bytes aligned.
However, the boundary between text and rodata/eh_frame is still aligned to
16 bytes, which is what I think the real purpose of the ALIGN call is.
Signed-off-by: Trent Piepho <xyzzy@speakeasy.org>
Most of the bss initialization loop increments 4 bytes
at a time. And the loop end is checked for an 'equal'
condition. Make the bss end address aligned by 4, so
that the loop will end as expected.
Signed-off-by: Selvamuthukumar <selva.muthukumar@e-coninfotech.com>
SMDK6400 can only boot U-Boot from NAND-flash. This patch adds a nand_spl
driver for it too. The board can also boot from the NOR flash, but due to
hardware limitations it can only address 64KiB on it, which is not enough
for U-Boot. Based on the original sources by Samsung for U-Boot 1.1.6.
Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
