path: root/nand_spl/board/samsung
2010-11-28Remove board_init_f function from nand_boot.cSughosh Ganu
Remove the board_init_f function from nand_spl/nand_boot.c. This function is to be defined by all boards using the nand_spl functionality in their individual board directory. Currently this function was being used by the smdk6400 board. Added the board specific function definition. Signed-off-by: Sughosh Ganu <urwithsughosh@gmail.com> Acked-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-04-13arm: Move cpu/$CPU to arch/arm/cpu/$CPUPeter Tyser
2009-08-21Fix all linker scripts for older binutils versions (pre-2.16)Wolfgang Denk
Commit f62fb99941c6 fixed handling of all rodata sections by using a wildcard combined with calls to ld's builtin functions SORT_BY_ALIGNMENT() and SORT_BY_NAME(). Unfortunately these functions were only introduced with biunutils version 2.16, so the modification broke building with all tool chains using older binutils. This patch makes it work again. This is done by omitting the use of these functions for such old tool chains. This will result in slightly larger target binaries, as the rodata sections are no longer in optimal order alignment-wise which reauls in unused gaps, but the effect was found to be insignificant - especially compared to the fact that you cannot build U-Boot at all in the current state. As ld seems to have no support for conditionals we run the linker script through the C preprocessor which can be easily used to remove the unwanted function calls. Note that the C preprocessor must be run with the "-ansi" (or a "-std=") option to make sure all the system-specific predefined macros outside the reserved namespace are suppressed. Otherise, cpp might for example substitute "powerpc" to "1", thus corrupting for example "OUTPUT_ARCH(powerpc)" etc. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Mike Frysinger <vapier@gentoo.org>
2009-05-15Fix e-mail address of Gary Jennejohn.Detlev Zundel
Signed-off-by: Detlev Zundel <dzu@denx.de>
2008-08-31ARM: Add support for S3C6400 based SMDK6400 boardGuennadi Liakhovetski
SMDK6400 can only boot U-Boot from NAND-flash. This patch adds a nand_spl driver for it too. The board can also boot from the NOR flash, but due to hardware limitations it can only address 64KiB on it, which is not enough for U-Boot. Based on the original sources by Samsung for U-Boot 1.1.6. Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
