Commit 3d5a335c announced that all the nand_spl boards
would be removed before v2014.07 release.
There is no need to set IVORs to anything but their default values,
so let's leave them where they are.
Suggested-by: Scott Wood <scottwood@freescale.com>
Acked-by: Scott Wood <scottwood@freescale.com>
[York Sun: Add back $(obj)start.S section in mpc8572ds/Makefile]
Reviewed-by: York Sun <yorksun@freescale.com>
Prior to Kbuild, $(OBJTREE) was used for pointing to the
top of build directory with absolute path.
In Kbuild style, $(objtree) is used instead.
This commit renames OBJTREE to objtree and delete the
defition of OBJTREE.
Prior to Kbuild, $(TOPDIR) or $(SRCTREE) was used for
pointing to the top of source directory.
(No difference between the two.)
In Kbuild style, $(srctree) is used for instead.
This commit renames SRCTREE to srctree and deletes the
defition of SRCTREE.
Note that SRCTREE in scripts/kernel-doc, scripts/docproc.c,
doc/DocBook/Makefile should be keep.
In Kbuild style, $(srctree) is used instead.
This commit renames TOPDIR to srctree and delete the
defition of TOPDIR.
Rename OBJCFLAGS to OBJCOPYFLAGS beforehand to use
"cmd_objcopy" in scripts/Makefile.lib in an upcoming commit.
Now we are ready to switch over to real Kbuild.
This commit disables temporary scripts:
scripts/{Makefile.build.tmp, Makefile.host.tmp}
and enables real Kbuild scripts:
scripts/{Makefile.build,Makefile.host,Makefile.lib}.
This switch is triggered by the line in scripts/Kbuild.include
-build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build.tmp obj
+build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build obj
We need to adjust some build scripts for U-Boot.
But smaller amount of modification is preferable.
Additionally, we need to fix compiler flags which are
locally added or removed.
In Kbuild, it is not allowed to change CFLAGS locally.
Instead, ccflags-y, asflags-y, cppflags-y,
CFLAGS_$(basetarget).o, CFLAGS_REMOVE_$(basetarget).o
are prepared for that purpose.
Tested-by: Gerhard Sittig <gsi@denx.de>
This commit changes the working directory
where the build process occurs.
Before this commit, build process occurred under the source
tree for both in-tree and out-of-tree build.
That's why we needed to add $(obj) prefix to all generated
files in makefiles like follows:
$(obj)u-boot.bin: $(obj)u-boot
Here, $(obj) is empty for in-tree build, whereas it points
to the output directory for out-of-tree build.
And our old build system changes the current working directory
with "make -C <sub-dir>" syntax when descending into the
sub-directories.
On the other hand, Kbuild uses a different idea
to handle out-of-tree build and directory descending.
The build process of Kbuild always occurs under the output tree.
When "O=dir/to/store/output/files" is given, the build system
changes the current working directory to that directory and
restarts the make.
Kbuild uses "make -f $(srctree)/scripts/Makefile.build obj=<sub-dir>"
syntax for descending into sub-directories.
(We can write it like "make $(obj)=<sub-dir>" with a shorthand.)
This means the current working directory is always the top
of the output directory.
Fix ccsr_ddr structure to avoid using typedef. Combine DDR2 and DDR3
structure for 83xx, 85xx and 86xx.
Signed-off-by: York Sun <yorksun@freescale.com>
Freescale DDR driver has been used for mpc83xx, mpc85xx, mpc86xx SoCs.
The similar DDR controllers will be used for ARM-based SoCs.
[trini: Fixup common/cmd_io.c]
Refactor linker-generated array code so that symbols
which were previously linker-generated are now compiler-
generated. This causes relocation records of type
R_ARM_ABS32 to become R_ARM_RELATIVE, which makes
code which uses LGA able to run before relocation as
well as after.
Note: this affects more than ARM targets, as linker-
lists span possibly all target architectures, notably
PowerPC.
arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds
arch/arm/cpu/arm926ejs/spear/u-boot-spl.lds
arch/arm/cpu/armv7/omap-common/u-boot-spl.lds
board/ait/cam_enc_4xx/u-boot-spl.lds
board/davinci/da8xxevm/u-boot-spl-da850evm.lds
board/davinci/da8xxevm/u-boot-spl-hawk.lds
board/vpac270/u-boot-spl.lds
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
There were a number of shared files that were using
CONFIG_SYS_MPC85xx_DDR_ADDR, or CONFIG_SYS_MPC86xx_DDR_ADDR, and
several variants (DDR2, DDR3). A recent patchset added
85xx-specific ones to code which was used by 86xx systems.
After reviewing places where these constants were used, and
noting that the type definitions of the pointers assigned to
point to those addresses were the same, the cleanest approach
to fixing this problem was to unify the namespace for the
85xx, 83xx, and 86xx DDR address definitions.
This patch does:
s/CONFIG_SYS_MPC8.xx_DDR/CONFIG_SYS_MPC8xxx_DDR/g
All 85xx, 86xx, and 83xx have been built with this change.
Signed-off-by: Andy Fleming <afleming@freescale.com>
Tested-by: Andy Fleming <afleming@freescale.com>
Acked-by: Kim Phillips <kim.phillips@freescale.com>
There is nothing really NAND-specific about this file.
Cc: Andy Fleming <afleming@freescale.com>
It applies to non-Freescale 85xx boards as well as Freescale boards,
so it doesn't belong in board/freescale. Plus, it needs to come out
of nand_spl if it's to be used by the new SPL.
It's arch code and not a driver, so move it where it belongs. When it
originally went into drivers/misc there was no 8xxx CPU directory.
This will make new-SPL support a little easier since we can keep the CPU
stuff together and not need to pull stuff in from drivers/misc.
Commit 97b24d3d51a92cb8c0c1e1a74abf22fe1a1807a3 "common: Add symbol
handling for generic lists into Makefile" introduced build errors in many
nand_spl targets, complaining of a missing u-boot.lst. When not doing an
out-of-tree build, $(obj) expands to nothing, so GCC ended up being given
-I with no argument (or rather, -ansi was the argument). The failure
didn't show up during a -j1 build because it was picking up the non-SPL
version of u-boot.lst.
This patch adds essential components for generation of the contents of
the linker section that is used by the linker-generated array. All of
the contents is held in a separate file, u-boot.lst, which is generated
at runtime just before U-Boot is linked.
The purpose of this code is to especially generate the appropriate
boundary symbols around each subsection in the section carrying the
linker-generated arrays. Obviously, the interim linker code for actual
placement of the variables into the section is generated too. The
generated file, u-boot.lst, is included into u-boot.lds via the linker
INCLUDE directive in u-boot.lds .
Adjustments are made in the Makefile and spl/Makefile so that the
u-boot.lds and u-boot-spl.lds depend on their respective .lst files.
Cc: Joe Hershberger <joe.hershberger@gmail.com>
Cc: Mike Frysinger <vapier@gentoo.org>
Tested-by: Joe Hershberger <joe.hershberger@ni.com>
This change reduces the SPL size by removing the redundant syncs produced
by out_be32 and just replies on one final sync
Done with:
sed -r '/in_be32/b; s/(out_be32)\(([^,]*),\s+(.*)\)/__raw_writel(\3, \2)/g' -i `git grep --name-only sdram_init nand_spl/`
Signed-off-by: Matthew McClintock <msm@freescale.com>
We have a requirement to wait a period of time before enabling the
DDR controller
The P1023RDS board is the reference board for the P1023 SoC.
Add support for booting it from NOR or NAND, with fixed 2G of DDR, PCIe,
UART, I2C, etc.
Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
Signed-off-by: Chunhe Lan <Chunhe.Lan@freescale.com>
Signed-off-by: Lei Xu <B33228@freescale.com>
