path: root/nand_spl/board/amcc/sequoia
2011-03-31Fix build issues cause by LDFLAGS_FINAL changesWolfgang Denk
Commit 6dc1ece "Introduce a new linker flag LDFLAGS_FINAL" modified a number of Makefiles in a way that broke out-of-tree builds. The problem was that $(nandobj) was used before it got defined. Fix this. Signed-off-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-03-27rename _end to __bss_end__Po-Yu Chuang
Currently, _end is used for end of BSS section. We want _end to mean end of u-boot image, so we rename _end to __bss_end__ first. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
2011-03-22Introduce a new linker flag LDFLAGS_FINALHaiying Wang
commit 8aba9dceebb14144e07d19593111ee3a999c37fc Divides variable of linker flags to LDFLAGS-u-boot and LDFLAGS breaks the usage of --gc-section to build nand_spl. We still need linker option --gc-section for every uboot image, not only the main one. LDFLAGS_FINAL passes the --gc-sections to each uboot image. To get the proper linker flags, we use LDFLAGS and LDFLAGS_FINAL to replace PLATFORM_LDFLAGS in the Makefile of each nand_spl board. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
2010-12-16powerpc/nand spl: link libgccScott Wood
Recent GCC (4.4+) performs out-of-line epilogues in some cases, when optimizing for size. It causes a link error for _restgpr_30_x (and similar) if libgcc is not linked. It actually increases size with very small binaries, due to the fixed size of the out-of-line code, and not having any functions that actually need to restore more than 2 or 3 registers. But I don't see a way to turn it off, other than asking GCC to optimize for speed -- which may also increase size for some boards. Signed-off-by: Scott Wood <scottwood@freescale.com> Acked-by: Kim Phillips <kim.phillips@freescale.com> Acked-by: Wolfgang Denk <wd@denx.de>
2010-11-27ppc4xx: Cleanup for partial linking and --gc-sectionsWolfgang Denk
This commit adapts 4xx boards for partial linking with --gc-sections. Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Tirumala Marri <tmarri@apm.com> Cc: David Updegraff <dave@cray.com> Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Cc: Dirk Eibach <eibach@gdsys.de> Cc: Larry Johnson <lrj@acm.org> Cc: Peter De Schrijver <p2@mind.be> Cc: Niklaus Giger <niklaus.giger@netstal.com> Cc: Daniel Poirot <dan.poirot@windriver.com> Acked-by: Stefan Roese <sr@denx.de>
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
2009-08-21Fix all linker scripts for older binutils versions (pre-2.16)Wolfgang Denk
Commit f62fb99941c6 fixed handling of all rodata sections by using a wildcard combined with calls to ld's builtin functions SORT_BY_ALIGNMENT() and SORT_BY_NAME(). Unfortunately these functions were only introduced with biunutils version 2.16, so the modification broke building with all tool chains using older binutils. This patch makes it work again. This is done by omitting the use of these functions for such old tool chains. This will result in slightly larger target binaries, as the rodata sections are no longer in optimal order alignment-wise which reauls in unused gaps, but the effect was found to be insignificant - especially compared to the fact that you cannot build U-Boot at all in the current state. As ld seems to have no support for conditionals we run the linker script through the C preprocessor which can be easily used to remove the unwanted function calls. Note that the C preprocessor must be run with the "-ansi" (or a "-std=") option to make sure all the system-specific predefined macros outside the reserved namespace are suppressed. Otherise, cpp might for example substitute "powerpc" to "1", thus corrupting for example "OUTPUT_ARCH(powerpc)" etc. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Mike Frysinger <vapier@gentoo.org>
2009-07-16nand/ppc4xx: Move PPC4xx NAND driver to common NAND driver directoryStefan Roese
Signed-off-by: Stefan Roese <sr@denx.de> Cc: Scott Wood <scottwood@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-06-03Remove shell variable UNDEF_SYM.Kenneth Johansson
UNDEF_SYM is a shell variable in the main Makefile used to force the linker to add all u-boot commands to the final image. It has no use here. Signed-off-by: Kenneth Johansson <kenneth@southpole.se>
2008-01-09fix comments with new drivers organizationMarcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
2008-01-04ppc4xx: Fix Sequoia NAND booting targetStefan Roese
The Sequoia NAND booting target now uses the recently extracted cpu/ppc4xx/denali_data_eye.c file too. Signed-off-by: Stefan Roese <sr@denx.de>
2007-11-25drivers/mtd : move mtd drivers to drivers/mtdJean-Christophe PLAGNIOL-VILLARD
2007-06-01Merge with /home/stefan/git/u-boot/bamboo-nandStefan Roese
2007-06-01ppc4xx: Update Sequoia NAND booting support with ECCStefan Roese
2007-05-05ppc4xx: Sequoia: Remove cpu/ppc4xx/speed.c from NAND bootingStefan Roese
Using cpu/ppc4xx/speed.c to calculate the bus frequency is too big for the 4k NAND boot image so define bus_frequency to 133MHz here which is save for the refresh counter setup. Signed-off-by: Stefan Roese <sr@denx.de>
2007-03-06[PATCH] Speed optimization of AMCC Sequoia/Rainier DDR2 setupStefan Roese
As provided by the AMCC applications team, this patch optimizes the DDR2 setup for 166MHz bus speed. The values provided are also save to use on a "normal" 133MHz PLB bus system. Only the refresh counter setup has to be adjusted as done in this patch. For this the NAND booting version had to include the "speed.c" file from the cpu/ppc4xx directory. With this addition the NAND SPL image will just fit into the 4kbytes of program space. gcc version 4.x as provided with ELDK 4.x is needed to generate this optimized code. Signed-off-by: Stefan Roese <sr@denx.de>
2007-01-05[PATCH] Add DDR2 optimization code for Sequoia (440EPx) boardStefan Roese
This code will optimize the DDR2 controller setup on a board specific basis. Note: This code doesn't work right now on the NAND booting image for the Sequoia board, since it doesn't fit into the 4kBytes for the SPL image. Signed-off-by: Stefan Roese <sr@denx.de>
2006-10-23Fix sequoia separate object direcory building problems.Marian Balakowicz
2006-09-12Update NAND boot documentationStefan Roese
Patch by Stefan Roese, 12 Sep 2006
2006-09-07Add support for AMCC Sequoia PPC440EPx eval boardStefan Roese
- Add support for PPC440EPx & PPC440GRx - Add support for PPC440EP(x)/GR(x) NAND controller in cpu/ppc4xx directory - Add NAND boot functionality for Sequoia board, please see doc/README.nand-boot-ppc440 for details - This Sequoia NAND image doesn't support environment in NAND for now. This will be added in a short while. Patch by Stefan Roese, 07 Sep 2006
