As ppc4xx currently only supports the deprecated nand_spl infrastructure
and nobody seems to have time / resources to port this over to the newer
SPL infrastructure, lets remove NAND booting completely.
This should not affect the "normal", non NAND-booting ppc4xx platforms
that are currently supported.
Cc: Tirumala Marri <tmarri@apm.com>
Cc: Matthias Fuchs <matthias.fuchs@esd.eu>
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
Cc: Tom Rini <trini@ti.com>
Tested-by: Matthias Fuchs <matthias.fuchs@esd.eu>
Rename OBJCFLAGS to OBJCOPYFLAGS beforehand to use
"cmd_objcopy" in scripts/Makefile.lib in an upcoming commit.
Now we are ready to switch over to real Kbuild.
This commit disables temporary scripts:
scripts/{Makefile.build.tmp, Makefile.host.tmp}
and enables real Kbuild scripts:
scripts/{Makefile.build,Makefile.host,Makefile.lib}.
This switch is triggered by the line in scripts/Kbuild.include
-build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build.tmp obj
+build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build obj
We need to adjust some build scripts for U-Boot.
But smaller amount of modification is preferable.
Additionally, we need to fix compiler flags which are
locally added or removed.
In Kbuild, it is not allowed to change CFLAGS locally.
Instead, ccflags-y, asflags-y, cppflags-y,
CFLAGS_$(basetarget).o, CFLAGS_REMOVE_$(basetarget).o
are prepared for that purpose.
Tested-by: Gerhard Sittig <gsi@denx.de>
This commit changes the working directory
where the build process occurs.
Before this commit, build process occurred under the source
tree for both in-tree and out-of-tree build.
That's why we needed to add $(obj) prefix to all generated
files in makefiles like follows:
$(obj)u-boot.bin: $(obj)u-boot
Here, $(obj) is empty for in-tree build, whereas it points
to the output directory for out-of-tree build.
And our old build system changes the current working directory
with "make -C <sub-dir>" syntax when descending into the
sub-directories.
On the other hand, Kbuild uses a different idea
to handle out-of-tree build and directory descending.
The build process of Kbuild always occurs under the output tree.
When "O=dir/to/store/output/files" is given, the build system
changes the current working directory to that directory and
restarts the make.
Kbuild uses "make -f $(srctree)/scripts/Makefile.build obj=<sub-dir>"
syntax for descending into sub-directories.
(We can write it like "make $(obj)=<sub-dir>" with a shorthand.)
This means the current working directory is always the top
of the output directory.
[trini: Fixup common/cmd_io.c]
Note this is a tree-wide change affecting multiple architectures.
At present we use __bss_start, but mostly __bss_end__. This seems
inconsistent and in a number of places __bss_end is used instead.
Change to use __bss_end for the BSS end symbol throughout U-Boot. This
makes it possible to use the asm-generic/sections.h file on all
archs.
There was a mix of UTF-8 and ISO-8859 files in the U-Boot source
tree, which could cause issues with the patchwork review system.
This commit converts all ISO-8859 files to UTF-8.
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
Commit 6dc1ece "Introduce a new linker flag LDFLAGS_FINAL" modified a
number of Makefiles in a way that broke out-of-tree builds. The
problem was that $(nandobj) was used before it got defined.
Fix this.
Currently, _end is used for end of BSS section. We want _end to mean
end of u-boot image, so we rename _end to __bss_end__ first.
Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
commit 8aba9dceebb14144e07d19593111ee3a999c37fc
Divides variable of linker flags to LDFLAGS-u-boot and LDFLAGS
breaks the usage of --gc-section to build nand_spl. We still need linker option
--gc-section for every uboot image, not only the main one. LDFLAGS_FINAL passes
the --gc-sections to each uboot image.
To get the proper linker flags, we use LDFLAGS and LDFLAGS_FINAL to replace
PLATFORM_LDFLAGS in the Makefile of each nand_spl board.
Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
Recent GCC (4.4+) performs out-of-line epilogues in some cases, when
optimizing for size. It causes a link error for _restgpr_30_x (and similar)
if libgcc is not linked.
It actually increases size with very small binaries, due to the fixed size
of the out-of-line code, and not having any functions that actually need to
restore more than 2 or 3 registers. But I don't see a way to turn it off,
other than asking GCC to optimize for speed -- which may also increase
size for some boards.
Acked-by: Kim Phillips <kim.phillips@freescale.com>
Acked-by: Wolfgang Denk <wd@denx.de>
This commit adapts 4xx boards for partial linking with --gc-sections.
Cc: Stefan Roese <sr@denx.de>
Cc: David Updegraff <dave@cray.com>
Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
Cc: Dirk Eibach <eibach@gdsys.de>
Cc: Larry Johnson <lrj@acm.org>
Cc: Peter De Schrijver <p2@mind.be>
Cc: Niklaus Giger <niklaus.giger@netstal.com>
Cc: Daniel Poirot <dan.poirot@windriver.com>
The change is currently needed to be able to remove the board
configuration scripting from the top level Makefile and replace it by
a simple, table driven script.
Moving this configuration setting into the "CONFIG_*" name space is
also desirable because it is needed if we ever should move forward to
a Kconfig driven configuration system.
This patch moves some ppc4xx related headers from the common include
directory (include/) to the powerpc specific one
(arch/powerpc/include/asm/). This way to common include directory is not
so cluttered with files.
As discussed on the list, move "arch/ppc" to "arch/powerpc" to
better match the Linux directory structure.
Please note that this patch also changes the "ppc" target in
MAKEALL to "powerpc" to match this new infrastructure. But "ppc"
is kept as an alias for now, to not break compatibility with
scripts using this name.
Acked-by: Detlev Zundel <dzu@denx.de>
Cc: Peter Tyser <ptyser@xes-inc.com>
The latest PPC4xx register cleanup patch missed some SDRAM defines.
This patch now changes lower case UIC defines to upper case. Also
some names are changed to match the naming in the IBM/AMCC users
manuals (e.g. mem_mcopt1 -> SDRAM0_CFG).
This patch cleans up multiple issues of the 4xx register (mostly
DCR, SDR, CPR, etc) definitions:
- Change lower case defines to upper case (plb4_acr -> PLB4_ACR)
- Change the defines to better match the names from the
user's manuals (e.g. cprpllc -> CPR0_PLLC)
- Removal of some unused defines
Please test this patch intensive on your PPC4xx platform. Even though
I tried not to break anything and tested successfully on multiple
4xx AMCC platforms, testing on custom platforms is recommended.
Commit f62fb99941c6 fixed handling of all rodata sections by using a
wildcard combined with calls to ld's builtin functions SORT_BY_ALIGNMENT()
and SORT_BY_NAME(). Unfortunately these functions were only
introduced with biunutils version 2.16, so the modification broke
building with all tool chains using older binutils.
This patch makes it work again. This is done by omitting the use of
these functions for such old tool chains. This will result in
slightly larger target binaries, as the rodata sections are no longer
in optimal order alignment-wise which reauls in unused gaps, but the
effect was found to be insignificant - especially compared to the fact
that you cannot build U-Boot at all in the current state.
As ld seems to have no support for conditionals we run the linker
script through the C preprocessor which can be easily used to remove
the unwanted function calls.
Note that the C preprocessor must be run with the "-ansi" (or a
"-std=") option to make sure all the system-specific predefined
macros outside the reserved namespace are suppressed. Otherise, cpp
might for example substitute "powerpc" to "1", thus corrupting for
example "OUTPUT_ARCH(powerpc)" etc.
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: Scott Wood <scottwood@freescale.com>
A recent gcc added a new unaligned rodata section called '.rodata.str1.1',
which needs to be added the the linker script. Instead of just adding this
one section, we use a wildcard ".rodata*" to get all rodata linker section
gcc has now and might add in the future.
However, '*(.rodata*)' by itself will result in sub-optimal section
ordering. The sections will be sorted by object file, which causes extra
padding between the unaligned rodata.str.1.1 of one object file and the
aligned rodata of the next object file. This is easy to fix by using the
SORT_BY_ALIGNMENT command.
This patch has not be tested one most of the boards modified. Some boards
have a linker script that looks something like this:
*(.text)
. = ALIGN(16);
*(.rodata)
*(.rodata.str1.4)
*(.eh_frame)
I change this to:
*(.text)
. = ALIGN(16);
*(.eh_frame)
*(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*)))
This means the start of rodata will no longer be 16 bytes aligned.
However, the boundary between text and rodata/eh_frame is still aligned to
16 bytes, which is what I think the real purpose of the ALIGN call is.
Signed-off-by: Trent Piepho <xyzzy@speakeasy.org>
Most of the bss initialization loop increments 4 bytes
at a time. And the loop end is checked for an 'equal'
condition. Make the bss end address aligned by 4, so
that the loop will end as expected.
Signed-off-by: Selvamuthukumar <selva.muthukumar@e-coninfotech.com>
This patch changes the return type of initdram() from long int to phys_size_t.
This is required for a couple of reasons: long int limits the amount of dram
to 2GB, and u-boot in general is moving over to phys_size_t to represent the
size of physical memory. phys_size_t is defined as an unsigned long on almost
all current platforms.
This patch *only* changes the return type of the initdram function (in
include/common.h, as well as in each board's implementation of initdram). It
does not actually modify the code inside the function on any of the platforms;
platforms which wish to support more than 2GB of DRAM will need to modify
their initdram() function code.
Build tested with MAKEALL for ppc, arm, mips, mips-el. Booted on powerpc
MPC8641HPCN.
Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
This patch fixes a problem spotted by Eugene O'Brian (thanks Eugene)
introduced by the commit:
ppc4xx/NAND_SPL: Consolidate 405 and 440 NAND booting code in start.S
With this patch SDRAM will get initialized again and booting from NAND
is working again.
Acked-by: Eugene O'Brien <eugene.obrien@advantechamt.com>
UNDEF_SYM is a shell variable in the main Makefile used to force the
linker to add all u-boot commands to the final image. It has no use here.
Signed-off-by: Kenneth Johansson <kenneth@southpole.se>
With recent toolchain versions, some boards would not build because
or errors like this one (here for ocotea board when building with
ELDK 4.2 beta):
ppc_4xx-ld: section .bootpg [fffff000 -> fffff23b] overlaps section .bss [fffee900 -> fffff8ab]
For many boards, the .bss section is big enough that it wraps around
at the end of the address space (0xFFFFFFFF), so the problem will not
be visible unless you use a 64 bit tool chain for development. On
some boards however, changes to the code size (due to different
optimizations) we bail out with section overlaps like above.
The fix is to add the NOLOAD attribute to the .bss and .sbss
sections, telling the linker that .bss does not consume any space in
the image.
Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
drivers/rtc/Makefile
This patch also adds a note to the fixed DDR setup for Bamboo NAND booting:
Note:
As found out by Eugene O'Brien <eugene.obrien@advantechamt.com>, the fixed
DDR setup has problems (U-Boot crashes randomly upon TFTP), when the DIMM
modules are still plugged in. So it is recommended to remove the DIMM
modules while using the NAND booting code with the fixed SDRAM setup!
Signed-off-by: Eugene O'Brien <eugene.obrien@advantechamt.com>
Bamboo has a file sdram.c which needs special treatment when building in
separate directory. It has to be linked to build directory otherwise it is
not seen.
Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com>
This patch adds NAND booting support for the AMCC Bamboo eval board.
Since the NAND-SPL boot image is limited to 4kbytes, this version
only supports the onboard 64MBytes of DDR. The DIMM modules can't be
supported, since the setup code for I2C DIMM autodetection and
configuration is too big for this NAND bootloader.
