Commit f62fb99941c6 fixed handling of all rodata sections by using a
wildcard combined with calls to ld's builtin functions SORT_BY_ALIGNMENT()
and SORT_BY_NAME(). Unfortunately these functions were only
introduced with biunutils version 2.16, so the modification broke
building with all tool chains using older binutils.
This patch makes it work again. This is done by omitting the use of
these functions for such old tool chains. This will result in
slightly larger target binaries, as the rodata sections are no longer
in optimal order alignment-wise which reauls in unused gaps, but the
effect was found to be insignificant - especially compared to the fact
that you cannot build U-Boot at all in the current state.
As ld seems to have no support for conditionals we run the linker
script through the C preprocessor which can be easily used to remove
the unwanted function calls.
Note that the C preprocessor must be run with the "-ansi" (or a
"-std=") option to make sure all the system-specific predefined
macros outside the reserved namespace are suppressed. Otherise, cpp
might for example substitute "powerpc" to "1", thus corrupting for
example "OUTPUT_ARCH(powerpc)" etc.
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: Scott Wood <scottwood@freescale.com>
UNDEF_SYM is a shell variable in the main Makefile used to force the
linker to add all u-boot commands to the final image. It has no use here.
Signed-off-by: Kenneth Johansson <kenneth@southpole.se>
Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
Bamboo has a file sdram.c which needs special treatment when building in
separate directory. It has to be linked to build directory otherwise it is
not seen.
Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com>
This patch adds NAND booting support for the AMCC Bamboo eval board.
Since the NAND-SPL boot image is limited to 4kbytes, this version
only supports the onboard 64MBytes of DDR. The DIMM modules can't be
supported, since the setup code for I2C DIMM autodetection and
configuration is too big for this NAND bootloader.
