path: root/mmc_spl/board/samsung/smdkv310/Makefile
2011-09-03SMDKV310: MMC SPL: Remove unwanted dummy functionsChander Kashyap
Removed dummy functions in "mmc_spl/board/samsung/smdkv310/mmc_boot.c", @mmc_boot.c void do_undefined_instruction(struct pt_regs *pt_regs); void do_software_interrupt(struct pt_regs *pt_regs); void do_prefetch_abort(struct pt_regs *pt_regs); void do_data_abort(struct pt_regs *pt_regs); void do_not_used(struct pt_regs *pt_regs); void do_fiq(struct pt_regs *pt_regs); void do_irq(struct pt_regs *pt_regs); not required as called conditionally in start.S @start.S \#ifdef CONFIG_SPL_BUILD _undefined_instruction: .word _undefined_instruction _software_interrupt: .word _software_interrupt _prefetch_abort: .word _prefetch_abort _data_abort: .word _data_abort _not_used: .word _not_used _irq: .word _irq _fiq: .word _fiq _pad: .word 0x12345678 /* now 16*4=64 */ \#else _undefined_instruction: .word undefined_instruction _software_interrupt: .word software_interrupt _prefetch_abort: .word prefetch_abort _data_abort: .word data_abort _not_used: .word not_used _irq: .word irq _fiq: .word fiq _pad: .word 0x12345678 /* now 16*4=64 */ \#endif e.g. undefined_instruction: get_bad_stack bad_save_user_regs bl do_undefined_instruction Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org>
2011-08-04SMDKV310: MMC_SPL: Fix building when using "make O="Chander Kashyap
Fixes dependency build error with "make O=" option. "make O=" option is used to specify output directory. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org>
2011-07-26replace CONFIG_PRELOADER with CONFIG_SPL_BUILDAneesh V
replace all occurences of CONFIG_PRELOADER with CONFIG_SPL_BUILD Signed-off-by: Aneesh V <aneesh@ti.com>
2011-05-26ARMV7: MMC SPL Boot support for SMDKV310 boardChander Kashyap
Added MMC SPL boot support for SMDKV310. This framework design is based on nand_spl support. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
