path: root/mkconfig
2009-09-15mkconfig: split the board make target to multiple config targetsWolfgang Denk
To simplify the top level makefile it useful to be able to parse the top level makefile target to multiple individual target, then put them to the config.h, leave the board config file to handle the different targets. Note that this method uses the '_'(underline) as the delimiter when splits the board make target. Signed-off-by: Mingkai Hu <Mingkai.hu@freescale.com> This also reverts commit 511c02f611cb5afa1b8ca5980caaaabaa0de377f. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-09-10mkconfig: pass the board name to board config fileMingkai Hu
Then we can handle different config targets in the board file, which simplifies the top level Makefile for boards that have multiple config targets. Signed-off-by: Mingkai Hu <Mingkai.hu@freescale.com>
2009-02-19mkconfig: include board config.h before asm/config.hKim Phillips
swapping the include order suppresses warnings for board configs that define their own CONFIG_MAX_MEM_MAPPED: In file included from /home/r1aaha/git/u-boot/include/config.h:5, from /home/r1aaha/git/u-boot/include/common.h:35, from simpc8313.c:26: /home/r1aaha/git/u-boot/include/configs/SIMPC8313.h:81:1: warning: "CONFIG_MAX_MEM_MAPPED" redefined In file included from /home/r1aaha/git/u-boot/include/config.h:4, from /home/r1aaha/git/u-boot/include/common.h:35, from simpc8313.c:26: /home/r1aaha/git/u-boot/include/asm/config.h:28:1: warning: this is the location of the previous definition Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-02-10Add an architecture specific config.h for common definesKumar Gala
We have common defines that we duplicate in various ways. Having an arch specific config.h gives us a common location for those defines. Eventually we should be able to replace this when we have proper Kconfig support. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2006-07-21* Cleanup TQM5200 board configurations:Wolfgang Denk
- make highboot configurations use environment at high end, too, to avoid flash fragmentation - always use redundand environment - don't enable video code for modules without graphics controller - provide useful (though different) mtdparts settings - get rid of CONFIG_CS_AUTOCONF which was always set anyway * Extend mkconfig tool to print more useful target name
2005-08-03Fix typo in mkconfig script (used == instead of =)Wolfgang Denk
Patch by Murray Jensen, 18 Jul 2005
2005-07-21Fix file permissionsWolfgang Denk
2005-04-03Patch by Steven Scholz, 03 Apr 2005:wdenk
- create SoC specific directories include/asm-arm/arch-imx and include/asm-arm/arch-s3c24x0
2004-10-09Patch by Steven Scholz, 16 Aug 2004:wdenk
- Introducing the concept of SoCs "./cpu/$(CPU)/$(SOC)" - creating subdirs for SoCs ./cpu/arm920t/imx and ./cpu/arm920t/s3c24x0 - moving SoC specific code out of cpu/arm920t/ into cpu/arm920t/$(SOC)/ - moving drivers/s3c24x0_i2c.c and drivers/serial_imx.c out of drivers/ into cpu/arm920t/$(SOC)/
