path: root/libfdt
2007-11-21Update libfdt from device tree compiler (dtc)Kumar Gala
Update libfdt to commit 8eaf5e358366017aa2e846c5038d1aa19958314e from the device tree compiler (dtc) project. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-11-21Removed some nonused fdt functions and moved fdt_find_and_setprop out of libfdtKumar Gala
Removed: fdt_node_is_compatible fdt_find_node_by_type fdt_find_compatible_node To ease merge of newer libfdt as we aren't using them anywhere at this time. Also moved fdt_find_and_setprop out of libfdt into fdt_support.c for the same reason. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-11-21[BUILD] conditionally compile libfdt/*.c in libfdt/MakefileKumar Gala
Modify libfdt/Makefile to conditionally compile the *.c files based on the board config. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-11-15Build: split COBJS value into multiple linesGrant Likely
This change is in preparation for condtitionial compile support in the build system. By spliting them all into seperate lines now, subsequent patches that change 'COBJS-y += ' into 'COBJS-$(CONFIG_<blah>) += ' will be less invasive and easier to review Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-09-06libfdt: add convenience function fdt_find_and_setprop()Grant Likely
Given the path to a node, fdt_find_and_setprop() allows a property value to be set directly. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-08-13Minor coding style cleanup. Update CHANGELOG.Wolfgang Denk
2007-08-10For fdt_find_node_by_path(), handle the root path properly.Gerald Van Baren
Also removes the special case root path detection in cmd_fdt.c since it is no longer necessary. Signed-off-by: Gerald Van Baren <vanbaren@cideas.com>
2007-08-10Add fdt_find_node_by_type() and fdt_find_compatible_node() to LIBFDTGerald Van Baren
Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Acked-by: Gerald Van Baren <vanbaren@cideas.com>
2007-08-10Replace fdt_node_offset() with fdt_find_node_by_path().Gerald Van Baren
The new name matches more closely the kernel's name, which is also a much better description. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Acked-by: Gerald Van Baren <vanbaren@cideas.com>
2007-08-10libfdt: Conditionally compile based on CONFIG_OF_LIBFDTGerald Van Baren
This is the way u-boot reduces configured-out code. At Wolfgang Grandegger and Wolfgang Denk's request, make libfdt conform. Signed-off-by: Gerald Van Baren <vanbaren@cideas.com>
2007-04-18Clenaup, update CHANGELOGWolfgang Denk
2007-04-14Add some utilities to manipulate the reserved memory map.Gerald Van Baren
2007-04-06libfdt: Make fdt_check_header() publicGerald Van Baren
Changed _fdt_check_header() to fdt_check_header() and made it part of the interface - it is a useful routine. Also did some asthetics cleanup to the include files (headers).
2007-04-04Minor cleanup.Wolfgang Denk
2007-03-31Fix some minor whitespace violations.Gerald Van Baren
2007-03-31libfdt: Enhanced and published fdt_next_tag()Gerald Van Baren
Enhanced the formerly private function _fdt_next_tag() to allow stepping through the tree, used to produce a human-readable dump, and made it part of the published interface. Also added some comments.
2007-03-31libfdt: Customizations for use by u-boot.Gerald Van Baren
Changes to David Gibson's original source to fit into u-boot's environment. No functionality changes.
2007-03-31libfdt: Import libfdt source (2 of 2)Gerald Van Baren
This adds the applicable libfdt source files (unmodified) and a README to explain where the source came from.
2007-03-31libfdt: Import libfdt source (1 of 2)Gerald Van Baren
