libfdt is supposed to easy to embed in projects all and sundry.
Often, it won't be practical to separate the embedded libfdt's
namespace from that of the surrounding project. Which means there can
be namespace conflicts between even libfdt's internal/static functions
and functions or macros coming from the surrounding project's headers
via libfdt_env.h.
This patch, therefore, renames a bunch of libfdt internal functions
and macros and makes a few other chances to reduce the chances of
namespace collisions with embedding projects. Specifically:
- Internal functions (even static ones) are now named _fdt_*()
- The type and (static) global for the error table in
fdt_strerror() gain an fdt_ prefix
- The unused macro PALIGN is removed
- The memeq and streq macros are removed and open-coded in the
users (they were only used once each)
- Other macros gain an FDT_ prefix
- To save some of the bulk from the previous change, an
FDT_TAGALIGN() macro is introduced, where FDT_TAGALIGN(x) ==
FDT_ALIGN(x, FDT_TAGSIZE)
Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
This patch turns on the -Wpointer-arith option in the dtc Makefile,
and fixes the resulting warnings due to using (void *) in pointer
arithmetic. While convenient, pointer arithmetic on void * is not
portable, so it's better that we avoid it, particularly in libfdt.
Also add necessary definition of uintptr_t needed by David Gibson's
changeset "dtc: Enable and fix -Wpointer-arith warnings" (the definition
comes from stdint.h, which u-boot doesn't have). -- gvb
Signed-off-by: Gerald Van Baren <vanbaren@cideas.com>
This patch makes a couple of small cleanups to parameter checking of
libfdt functions.
- In several functions which take a node offset, we use an
idiom involving fdt_next_tag() first to check that we have indeed been
given a node offset. This patch adds a helper function
_fdt_check_node_offset() to encapsulate this usage of fdt_next_tag().
- In fdt_rw.c in several places we have the expanded version
of the RW_CHECK_HEADER() macro for no particular reason. This patch
replaces those instances with an invocation of the macro; that's what
it's for.
- In fdt_sw.c we rename the check_header_sw() function to
sw_check_header() to match the analgous function in fdt_rw.c, and we
provide an SW_CHECK_HEADER() wrapper macro as RW_CHECK_HEADER()
functions in fdt_rw.c
common/cmd_bootm.c
cpu/mpc8xx/cpu.c
Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
Currently the CHECK_HEADER() macro is defined local to fdt_ro.c.
However, there are a handful of functions (fdt_move, rw_check_header,
fdt_open_into) from other files which could also use it (currently
they open-code something more-or-less identical). Therefore, this
patch moves CHECK_HEADER() to libfdt_internal.h and uses it in those
places.
This patch adds an fdt_next_node() function which can be used to
iterate through nodes of the tree while keeping track of depth. This
function is used to simplify the iteration code in a lot of other
functions, and is also exported for use by library users.
Update libfdt to commit 8eaf5e358366017aa2e846c5038d1aa19958314e from
the device tree compiler (dtc) project.
Modify libfdt/Makefile to conditionally compile the *.c files based
on the board config.
This is the way u-boot reduces configured-out code. At Wolfgang
Grandegger and Wolfgang Denk's request, make libfdt conform.
Changed _fdt_check_header() to fdt_check_header() and made it part of
the interface - it is a useful routine.
Also did some asthetics cleanup to the include files (headers).
Enhanced the formerly private function _fdt_next_tag() to allow stepping
through the tree, used to produce a human-readable dump, and made
it part of the published interface.
Also added some comments.
This adds the applicable libfdt source files (unmodified) and a README
to explain where the source came from.
