finish remaning CFG_ID_EEPROM in CONFIG_ID_EEPROM
start in commit ad8f8687b78c3e917b173f038926695383c55555
There is no need for each OS specific function to call do_reset() we
can just do it once in bootm. This means its feasible on an error for
the OS boot function to return.
Also, remove passing in cmd_tbl_t as its not needed by the OS boot
functions. flag isn't currently used but might be in the future so
we left it alone.
Created a bootm_start() that handles the parsing and detection of all
the images that will be used by the bootm command (OS, ramdisk, fdt).
As part of this we now tract all the relevant image offsets in the
bootm_headers_t struct. This will allow us to have all the needed
state for future sub-commands and lets us reduce a bit of arch
specific code on SPARC.
Created a bootm_load_os() that deals with decompression and loading
the OS image.
To allow for persistent state between future bootm subcommands we
need the lmb to exist in a global state.
Moving it into the bootm_headers_t allows us to do that.
Move determing if we have a ramdisk and where its located into the
common code. Keep track of the ramdisk start and end in the
bootm_headers_t image struct.
Move entry point code out of each arch and into common code.
Keep the entry point in the bootm_headers_t images struct.
The autostart revert caused a bit of duplicated code as well as
code that was using images->autostart that needs to get removed so
we can build again.
This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
