path: root/lib_sparc
2008-09-10cmd_mac: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
finish remaning CFG_ID_EEPROM in CONFIG_ID_EEPROM start in commit ad8f8687b78c3e917b173f038926695383c55555 Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-08-26bootm: refactor do_reset and os boot function argsKumar Gala
There is no need for each OS specific function to call do_reset() we can just do it once in bootm. This means its feasible on an error for the OS boot function to return. Also, remove passing in cmd_tbl_t as its not needed by the OS boot functions. flag isn't currently used but might be in the future so we left it alone. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-08-26bootm: refactor image detection and os load stepsKumar Gala
Created a bootm_start() that handles the parsing and detection of all the images that will be used by the bootm command (OS, ramdisk, fdt). As part of this we now tract all the relevant image offsets in the bootm_headers_t struct. This will allow us to have all the needed state for future sub-commands and lets us reduce a bit of arch specific code on SPARC. Created a bootm_load_os() that deals with decompression and loading the OS image. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-08-26bootm: move lmb into the bootm_headers_t structureKumar Gala
To allow for persistent state between future bootm subcommands we need the lmb to exist in a global state. Moving it into the bootm_headers_t allows us to do that. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-08-26bootm: refactor ramdisk locating codeKumar Gala
Move determing if we have a ramdisk and where its located into the common code. Keep track of the ramdisk start and end in the bootm_headers_t image struct. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-08-26bootm: refactor entry point codeKumar Gala
Move entry point code out of each arch and into common code. Keep the entry point in the bootm_headers_t images struct. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-08-12Fix fallout from autostart revertKumar Gala
The autostart revert caused a bit of duplicated code as well as code that was using images->autostart that needs to get removed so we can build again. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-07-30Fix remaining CFG_CMD_ define, ifdef and commentsJean-Christophe PLAGNIOL-VILLARD
2008-04-08SPARC: Added generic support for SPARC architecture.Daniel Hellstrom
Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
