Using external watchdog for KUP4 boards in mpc8xx/cpu.c;
load_sernum_ethaddr() for KUP4 boards in lib_ppc/board.c;
various changes to KUP4 board specific files
binary image for all clock frequencies. Implement run-time
optimization of flash access timing based on the actual bus
frequency.
- Add support for RPC/STx GP3, Motorola 8560 board
- Update 85xx TSEC driver so it searches MII for first available PHY
and uses that one.
- Add functions to support console MII commands.
* Patch by Tolunay Orkun, 07 Apr 2004:
Move initialization of bi_iic_fast[]
from board_init_f() to board_init_r()
* Patch by Yasushi Shoji, 07 Apr 2004:
Cleanup microblaze port
* Patch by Sangmoon Kim, 07 Apr 2004:
Add auto SDRAM module detection for Debris board
- add auto-complete support to the U-Boot CLI
- add support for NETTA and NETPHONE boards; fix NETVIA board
* Patch by Yuli Barcohen, 28 Mar 2004:
- Add support for MPC8272 family including MPC8247/8248/8271/8272
- Add support for MPC8272ADS evaluation board (another flavour of MPC8260ADS)
- Change configuration method for MPC8260ADS family
unconfiguring the board
* Adapt RMU board for bigger flash memory
* Test fix for ethernet problems on MPC5200
Add support for KUP4X Board
- Unify video mode handling for Chips & Technologies 69000 Video
chip and Silicon Motion SMI 712/710/810 Video chip
- Add selection of the video output (CRT or LCD) via 'videoout'
environment variable for the Silicon Motion
- README update
* Patch by Pierre Aubert, 18 Mar 2004:
include/common.h typo fix
* Patches by Tolunay Orkun, 17 Mar 2004:
- Add support for bd->bi_iic_fast[] initialization via environment
variable "i2cfast" (CONFIG_I2CFAST)
- Add "i2cfast" u-boot environment variable support for csb272
avoid dereferencing NULL pointer in lib_arm/armlinux.c
* Patch by Stephen Williams, 15 Mar 2004:
Fix CONFIG_SERIAL_SOFTWARE_FIFO documentation
* Patch by Tolunay Orkun, 15 Mar 2004:
Initialize bi_opbfreq to real OPB frequency via get_OPB_freq()
* Patch by Travis Sawyer, 15 Mar 2004:
Update CREDITS & MAINTAINERS files for PPC440GX & Ocotea port
add IDE support for MPC5200
* Patch by Masami Komiya, 26 Feb 2004:
add autoload via NFS
Use of CONFIG_SERIAL_SOFTWARE_FIFO in board.c consistent with uses
elsewhere in the source.
Add support for NFS for file download
* Minor code cleanup
Add support for the Xilinx ML300 platform
* Patch by Stephan Linz, 17 Feb 2004:
Fix watchdog support for NIOS
* Patch by Josh Fryman, 16 Feb 2004:
Fix byte-swapping for cfi_flash.c for different bus widths
* Patch by Jon Diekema, 14 Jeb 2004:
Remove duplicate "FPGA Support" notes from the README file
- update board/emk tree; use common flash driver
- Corrected tested bits in machine check exception in cpu/mpc5xxx/traps.c
[adapted for other PPC CPUs -- wd]
- Added support for the M48T08 on the EVAL5200 board in rtc/mk48t59.c
* Patch by Jon Diekema, 13 Feb 2004:
Call show_boot_progress() whenever POST "FAILED" is printed.
* Patch by Nishant Kamat, 13 Feb 2004:
Add support for TI OMAP1610 H2 Board
Fixes for cpu/arm926ejs/interrupt.c
(based on Richard Woodruff's patch for arm925, 16 Oct 03)
Fix for a timer bug in OMAP1610 Innovator
Add support for CS0 (ROM)/CS3 (Flash) boot in OMAP1610 Innovator and H2
* Patches by Stephan Linz, 12 Feb 2004:
- add support for NIOS timer with variable period preload counter value
- prepare POST framework support for NIOS targets
* Patch by Denis Peter, 11 Feb 2004:
add POST support for the MIP405 board
Add support for IBM PPC440GX. Multiple EMAC Ethernet devices,
select MDI port based on enabled EMAC device.
Add support for XES Inc <http://www.xes-inc.com> XPedite1000 440GX
base PrPMC board.
see doc/README.MPC866 for details;
implement workaround for "SIU4" and "SIU9" silicon bugs on MPC866;
calculate CPU clock frequency from PLL register values.
* Add support for 128 MB RAM on TQM8xxL/M modules
before we can access it; add delay in case we are faster (with no
CF card inserted)
* Cleanup of some init functions
* Make sure SCC Ethernet is always stopped by the time we boot Linux
to avoid Linux crashes by early packets coming in.
* Accelerate flash accesses on LWMON board by using buffered writes
version of the repository???]
* Patch by Reinhard Meyer, 09 Jan 2004:
- add RTC support for MPC5200 based boards (requires RTC_XTAL)
* Add support for IDE LED on BMS2003 board
(exclusive with status LED!)
* Add support for PS/2 keyboard (used with PS/2 multiplexor on
BMS2003 board)
* Patches by Reinhard Meyer, 4 Jan 2004 + 7 Jan 2004:
Add common files for "emk" boards
* Minor code cleanup (coding style)
* Patch by Reinhard Meyer, 30 Dec 2003:
- cpu/mpc5xxx/fec.c: added CONFIG_PHY_ADDR, added CONFIG_PHY_TYPE,
- added CONFIG_PHY_ADDR to include/configs/IceCube.h,
- turned debug print of PHY registers into a function (called in two places)
- added support for EMK MPC5200 based modules
* Fix MPC8xx PLPRCR_MFD_SHIFT typo
* Add support for TQM866M modules
* Fixes for TQM855M with 4 MB flash (Am29DL163 = _no_ mirror bit flash)
* Fix a few compiler warnings
Move most of the timer interrupt related PPC code to ppc_lib/interrupts.c
* Patch by Anders Larsen, 17 Sep 2003:
Bring ARM memory layout in sync with the documentation:
stack and malloc-heap are now located _below_ the U-Boot code
recent tools
* Add checksum verification to 'imls' command
* Add bd_info fields needed for 4xx Linux I2C driver
* Patch by Martin Krause, 4 Nov. 2003:
Fix error in cmd_vfd.c (TRAB board: "vfd /1" shows now only one Bitmap)
* Print used network interface when CONFIG_NET_MULTI is set
- Added Motorola CPU 8540/8560 support (cpu/85xx)
- Added Motorola MPC8540ADS board support (board/mpc8540ads)
- Added Motorola MPC8560ADS board support (board/mpc8560ads)
- allow for longer timeouts for USB mass storage devices
* Patch by Denis Peter, 11 Sep 2003:
- fix USB data pointer assignment for bulk only transfer.
- prevent to display erased directories in FAT filesystem.
* Change output format for NAND flash - make it look like for other
memory, too
* Add support for P3G4 board
* Fix problem with MGT5100 FEC driver: add "early" MAC address
initialization
add support for Adder II MPC852T module
applications: instead of using (PPC-specific) system calls we now
use a jump table; please see doc/README.standalone for details
* Patch by Dave Westwood, 24 Jul 2003:
added support for Unity OS (a proprietary OS)
- add I2C support for s3c2400 systems (trab board)
- (re-) add "ping" to command table
* Fix handling of "slow" POST routines
- Correct flash and JFFS2 support for MPC8260ADS
- fix PVR values and clock generation for PowerQUICC II family
(8270/8275/8280)
* Patch by Bernhard Kuhn, 08 Jul 2003:
- add support for M68K targets
* Patch by Ken Chou, 3 Jul:
- Fix PCI config table for A3000
- Fix iobase for natsemi.c
(PCI_BASE_ADDRESS_0 is the IO base register for DP83815)
* Allow to enable "slow" POST routines by key press on power-on
* Fix temperature dependend switching of LCD backlight on LWMON
* Tweak output format for LWMON
sort when sorting command name list). Minor cleanup here and there.
- remove trailing white space, trailing empty lines, C++ comments, etc.
- split cmd_boot.c (separate cmd_bdinfo.c and cmd_load.c)
* Patches by Kenneth Johansson, 25 Jun 2003:
- major rework of command structure
(work done mostly by Michal Cendrowski and Joakim Kristiansen)
- Hymod board database mods: add "who" field and new xilinx chip types
- provide new "init_cmd_timeout()" function so code external to
"common/main.c" can use the "reset_cmd_timeout()" function before
entering the main loop
- add DTT support for adm1021 (new file dtt/adm1021.c; config
slightly different. see include/configs/hymod.h for an example
(requires CONFIG_DTT_ADM1021, CONFIG_DTT_SENSORS, and
CFG_DTT_ADM1021 defined)
- add new "eeprom_probe()" function which has similar args and
behaves in a similar way to "eeprom_read()" etc.
- add 8260 FCC ethernet loopback code (new "eth_loopback_test()"
function which is enabled by defining CONFIG_ETHER_LOOPBACK_TEST)
- gdbtools copyright update
- ensure that set_msr() executes the "sync" and "isync" instructions
after the "mtmsr" instruction in cpu/mpc8260/interrupts.c
- 8260 I/O ports fix: Open Drain should be set last when configuring
- add SIU IRQ defines for 8260
- allow LDSCRIPT override and OBJCFLAGS initialization: change to
config.mk to allow board configurations to override the GNU
linker script, selected via the LDSCRIPT, make variable, and to
give an initial value to the OBJCFLAGS make variable
- 8260 i2c enhancement:
o correctly extends the timeout depending on the size of all
queued messages for both transmit and receive
o will not continue with receive if transmit times out
o ensures that the error callback is done for all queued tx
and rx messages
o correctly detects both tx and rx timeouts, only delivers one to
the callback, and does not overwrite an earlier error
o logic in i2c_probe now correct
- add "vprintf()" function so that "panic()" function can be
technically correct
- many Hymod board changes
- Added support for custom keyboards, initialized by defining a
board-specific drv_keyboard_init as well as defining CONFIG_KEYBOARD .
- Added support for the RBC823 board.
- cpu/mpc8xx/lcd.c now automatically calculates the
Horizontal Pixel Count field.
* Fix alignment problem in BOOTP (dhcp_leasetime option)
[pointed out by Nicolas Lacressonnière, 2 Jun 2003]
* Patch by Mark Rakes, 14 May 2003:
add support for Intel e1000 gig cards.
* Patch by Nye Liu, 3 Jun 2003:
fix critical typo in MAMR definition (include/mpc8xx.h)
* Fix requirement to align U-Boot image on 16 kB boundaries on PPC.
* Patch by Klaus Heydeck, 2 Jun 2003
Minor changes for KUP4K configuration
instead CFG_MONITOR_LEN is now only used to determine _at_compile_
_time_ (!) if the environment is embedded within the U-Boot image,
or in a separate flash sector.
* Cleanup CFG_DER #defines in config files (wd maintained only)
- "nand_init" (NAND FLASH) added.
Fix problem with only partially cleared .bss segment
* Patch by Rune Torgersen, 12 May 2003:
get PCI to work on a MPC8266ADS board; incorporate change to
cpu/mpc8260/pci.c to enable overrides of PCI memory parameters
* Patch by Keith Outwater, 28 Apr 2003:
- Miscellaneous corrections and additions to GEN860T board specific code.
- Added GEN860_SC variant to GEN860T.
- Miscellaneous corrections to GEN860T documentation.
- Correct duplicate entry in U-Boot CREDITS file.
- Add GEN860T_SC entry in MAINTAINERS file.
- Update CREDITS file with GEN860T_SC info.
* Update Smiths Aerospace addresses in MAINTAINERS file
* Fix error handling in hush's version of "run" command
- Splashscreen support
- modem support
- sysmon support
- temperature dependend enabling of LCD
* Allow booting from old "PPCBoot" disk partitions
* Add support for TQM8255 Board / MPC8255 CPU
- Add port to MPC555/556 microcontrollers
- Add support for cmi customer board with
Intel 28F128J3A, 28F320J3A or 28F640J3A flash.
* Patch by Rick Bronson, 28 Mar 2003:
- fix common/cmd_nand.c
- 16/32 MB and 50/80 MHz support with auto-detection for IP860
- ETH05 and BEDBUG support for CU824
- added support for MicroSys CPC45
- new BOOTROM/FLASH0 and DOC base for PM826
* Patch by Robert Schwebel, 12 Mar 2003:
Fix the chpart command on innokom board
* Name cleanup:
mv include/asm-i386/ppcboot-i386.h include/asm-i386/u-boot-i386.h
s/PPCBoot/U-Boot/ in some files
s/pImage/uImage/ in some files
* Patch by Detlev Zundel, 15 Jan 2003:
Fix '' command line quoting
* Patch by The LEOX team, 19 Jan 2003:
- add support for the ELPT860 board
- add support for Dallas ds164x RTC
to log on the console, too (like in Linux); get rid of "logstart"
Fix misc problems with AmigaOne support
* Patch by Chris Hallinan, 3 Dec 2002:
minor cleanup to the MPC8245 EPIC driver
* Patch by Pierre Aubert , 28 Nov 2002
Add support for external (SIU) interrupts on MPC8xx
Fix nested syscalls bug in standalone applications
* Patch by David Müller, 27 Nov 2002:
fix output of "pciinfo" command for CardBus bridge devices.
* Fix bug in TQM8260 board detection - boards got stuck when board ID
was not readable
Add code for AmigaOne board
(preliminary merge to U-Boot, still WIP)
* Patch by Jon Diekema, 12 Nov 2002:
- Adding URL for IEEE OUI lookup
- Making the autoboot #defines dependent on CONFIG_AUTOBOOT_KEYED
being defined.
- In the CONFIG_EXTRA_ENV_SETTINGS #define, the root-on-initrd and
root-on-nfs macros are designed to switch how the default boot
method gets defined.
syslog mechanism; used especially for POST results.
* Patch by Klaus Heydeck, 31 Oct 2002:
Add initial support for kup4k board
