Current code requires that a compiled device tree have space added to the end to
leave room for extra nodes added by board code (and the chosen node). This
requires that device tree creators anticipate how much space U-Boot will add to
the tree, which is absurd. Ideally, the code would resize and/or relocate the
tree when it needed more space, but this would require a systemic change to the
fdt code, which is non-trivial. Instead, we resize the tree inside
boot_relocate_fdt, reserving either the remainder of the bootmap (in the case
where the fdt is inside the bootmap), or adding CFG_FDT_PAD bytes to the size.
Signed-off-by: Andy Fleming <afleming@freescale.com>
This updates the lmb code to use phys_size_t
and phys_addr_t instead of unsigned long. Other code
which interacts with this code, like getenv_bootm_size()
is also updated.
Booted on MPC8641HPCN, build-tested ppc, arm, mips.
Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
Make it so we keep track of which LAWs have allocated and provide
a function (set_next_law) which can allocate a LAW for us if one is
free.
In the future we will move to doing more "dynamic" LAW allocation
since the majority of users dont really care about what LAW number
they are at.
Also, add CONFIG_MPC8540 or CONFIG_MPC8560 to those boards which needed them
differentiate with local variables of the same name by renaming the
global 'fdt' variable 'working_fdt'.
Add logbuffer to reserved LMB areas to prevent initrd allocation
from overlaping with it.
Make sure to use correct logbuffer base address.
Signed-off-by: Marian Balakowicz <m8@semihalf.com>
This function prints the values of all the BAT register
pairs - I needed this for debug earlier this week; adding it to
lib_ppc so others can use it (and add it to reginfo commands
if so desired).
Currently, this code only deals with BATs 0-3, which makes
it useless on systems that support BATs 4-7. Add the
support for these registers.
Signed-off-by: Becky Bruce <Becky.bruce@freescale.com>
Likewise with onenand_init().
This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
This reverts commit 1b5605ca57fbb364f4d78eeee28b974ed875e888
which breaks building on all PPC boards that don't use a log buffer.
This patch enables legacy multi-type images containing only a Linux kernel
and root file system to be loaded, maintaining compatibility with previous
versions of u-boot.
This is required when using old image files such as a Linux 2.4 kernel /
filesystem.
Signed-off-by: Nick Spence <nick.spence@freescale.com>
Acked-by: Bartlomiej Sieka <tur@semihalf.com>
Removed duplicated effective memory size calculation code.
Some boards (e.g. lwmon5) need rather a frequent watch-dog
kicking. Since the time it takes for the flush_cache() function
to complete its job depends on the size of data being flushed, one
may encounter watch-dog resets on such boards when, for example,
download big files over ethernet.
Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
This reverts commit 70431e8a7393b6b793f77957f95b999fc9a269b8 which has
proven problematic getting right from the start at least on 83xx and
4xx.
Before new uImage code was merged, bootm code allowed for the kernel image to
get overwritten during decompresion. new uImage introduced a check for image
overwrites and refused to boot the image that got overwritten. This patch
restores the old behavior. It also adds a warning when the image overwriten is
a multi-image file, because in such case accessing componentes other than the
first one will fail.
Set fdt_blob variable before its value is printed out.
The patch 70431e8a7393b6b793f77957f95b999fc9a269b8 (Make MPC83xx one step
closer to full relocation.) doesn't use CFG_MONITOR_BASE anymore. But
on 4xx systems _start currently cannot be used for this calculation.
So revert back to the original version for now.
lib_ppc/board.c
finish off what commit 43ddd9c820fec44816188f53346b464e20b3142d,
"Remove deprecated CONFIG_OF_HAS_UBOOT_ENV and CONFIG_OF_HAS_BD_T"
started.
Remove a few absolute references to CFG_MONITOR_BASE for ppc/mpc83xx
and use GOT relative reference.
Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
This patch fixes eeprom page size so that you can now write more than
64 bytes at a time.
It also makes the board take MAC addresses, if found, from EEPROM.
User should place up to 4 addresses at offset 0x7f00, for
eth{,1,2,3}addr. Any unused addresses should be zero. This group of
four six-byte values should have it's CRC at the end. crc32 and
eeprom commands can be used to accomplish this.
If CRC fails, MAC addresses come from the environment. If CRC
succeeds, the environment is overwritten at startup.
Signed-off-by: Michael Barkowski <michael.barkowski@freescale.com>
If CFG_MEM_TOP_HIDE is defined in the board config header, this specified
memory area will get subtracted from the top (end) of ram and won't get
"touched" at all by U-Boot. By fixing up gd->ram_size the Linux kernel
should gets passed the now "corrected" memory size and won't touch it
either. This should work for arch/ppc and arch/powerpc. Only Linux board
ports in arch/powerpc with bootwrapper support, which recalculate the
memory size from the SDRAM controller setup, will have to get fixed
in Linux additionally.
This patch enables this config option on some PPC440EPx boards as a workaround
for the CHIP 11 errata. Here the description from the AMCC documentation:
CHIP_11: End of memory range area restricted access.
Category: 3
Overview:
The 440EPx DDR controller does not acknowledge any
transaction which is determined to be crossing over the
end-of-memory-range boundary, even if the starting address is
within valid memory space. Any such transaction from any PLB4
master will result in a PLB time-out on PLB4 bus.
Impact:
In case of such misaligned bursts, PLB4 masters will not
retrieve any data at all, just the available data up to the
end of memory, especially the 440 CPU. For example, if a CPU
instruction required an operand located in memory within the
last 7 words of memory, the DCU master would burst read 8
words to update the data cache and cross over the
end-of-memory-range boundary. Such a DCU read would not be
answered by the DDR controller, resulting in a PLB4 time-out
and ultimately in a Machine Check interrupt. The data would
be inaccessible to the CPU.
Workaround:
Forbid any application to access the last 256 bytes of DDR
memory. For example, make your operating system believe that
the last 256 bytes of DDR memory are absent. AMCC has a patch
that does this, available for Linux.
This patch sets CFG_MEM_TOP_HIDE for the following 440EPx boards:
lwmon5, korat, sequoia
The other remaining 440EPx board were intentionally not included
since it is not clear to me, if they use the end of ram for some
other purpose. This is unclear, since these boards have CONFIG_PRAM
defined and even comments like this:
PMC440.h:
/* esd expects pram at end of physical memory.
* So no logbuffer at the moment.
It is strongly recommended to not use the last 256 bytes on those
boards too. Patches from the board maintainers are welcome.
Signed-off-by: Dave Liu <daveliu@freescale.com>
common/cmd_bootm.c
cpu/mpc8xx/cpu.c
Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
For historical reasons we limited the stack to 256M because some boards
could only map that much via BATS. However newer boards are capable of
mapping more memory (for example 85xx is capble of doing up to 2G).
lwmon5 board: the storage for the log-buffer itself is OCM(on-chip memory), the log-buffer header is moved to six GPT registers (PPC440EPX_GPT0_COMP1, ..., PPC440EPX_GPT0_COMP5).
To enable this, alternative, configuration the U-Boot board configuration
file for lwmon5 includes the definitions of alternative addresses for header
(CONFIG_ALT_LH_ADDR) and buffer (CONFIG_ALT_LB_ADDR).
The Linux shall be configured with the CONFIG_ALT_LB_LOCATION option set,
and has the BOARD_ALT_LH_ADDR and BOARD_ALT_LB_ADDR constants defined in the
lwmon5 board-specific header (arch/ppc/platforms/4xx/lwmon5.h).
Save FIT configuration provied in the first bootm argument and use it
when to get ramdisk/FDT subimages when second and third (ramdisk/FDT)
arguments are not specified.
routines
This patch updates architecture specific implementations of
do_bootm_linux() adding new uImage format handling for
operations like get kernel entry point address, get kernel
image data start address.
This patch adds new node offset fields to struct bootm_headers
and updates bootm_headers processing code to make use of them.
Saved node offsets allow to avoid repeating fit_image_get_node() calls.
Support for new (FIT) format uImages is added to powerpc specific
boot_get_fdt() routine which now recognizes, sanity checks FIT image
and is able to access data sections of the requested component image.
boot_get_ramdisk() and image_get_ramdisk() do not need all
cmdtp, flag, argc and argv arguments. Simplify routines definition.
Do not use global fdt blob pointer, calculate blob size from routine
argument blob pointer.
This patch introduces the following prefix convention for the
image format handling and bootm related code:
genimg_ - dual format shared code
image_ - legacy uImage format specific code
fit_ - new uImage format specific code
boot_ - booting process related code
Related routines are renamed and a few pieces of code are moved around and
re-grouped.
Acked-by: Marian Balakowicz <m8@semihalf.com>
Allow the user to set 'bootm_low' and 'bootm_size' env vars as a way
to restrict what memory range is used for bootm.
Convert generic ramdisk_high(), get_boot_cmdline(), get_boot_kbd()
functions over to using lmb for allocation of the ramdisk, command line
and kernel bd info.
Convert PPC specific fdt_relocate() to use lmb for allocation of the device
tree.
Provided a weak function that board code can call to do additional
lmb reserves if needed.
Also introduce the concept of bootmap_base to specify the offset in
physical memory that the bootmap is located at. This is used for
allocations of the cmdline, kernel bd, and device tree as they should
be contained within bootmap_base and bootmap_base + CFG_BOOTMAPSZ.
mapping more memory (for example 85xx is capable of doing up to 2G).
Changed image_get_ramdisk() to just return NULL on error and have
get_ramdisk() propogate that error to the caller. It's left to the
caller to call do_reset() if it wants to.
Also moved calling do_reset() in get_fdt() and fdt_relocate() on ppc
to a common location. In the future we will change get_fdt() and
fdt_relocate() to return success/failure and not call do_reset() at all.
Doing the fdt before the ramdisk allows us to grow the fdt w/o concern
however it does mean we have to go in and fixup the initrd info since
we don't know where it will be.
If we are bootin OF style than we can skip setting up some things
that are used for the old boot method.
We don't actually need the kdb param as we are just using it to get
bd->bi_memsize which we can get from gd->bd->bi_memsize. Also, if we
boot via OF we might not actually fill out a kdb.
