path: root/lib_ppc
2007-07-09Merge with /home/hs/Atronic/u-bootWolfgang Denk
2007-07-03Merge with /home/wd/git/u-boot/custodian/u-boot-testingWolfgang Denk
2007-06-22[PCS440EP] upgrade the PCS440EP board:Heiko Schocher
- Show on the Status LEDs, some States of the board. - Get the MAC addresses from the EEProm - use PREBOOT - use the CF on the board. - check the U-Boot image in the Flash with a SHA1 checksum. - use dynamic TLB entries generation for the SDRAM Signed-off-by: Heiko Schocher <hs@denx.de>
2007-06-08Fix config problems on SC3 board; make ide_reset_timeout work.Wolfgang Denk
2007-05-18Merge with git://www.denx.de/git/u-boot.gitStefan Roese
2007-05-17Merge with /home/git/u-bootWolfgang Denk
2007-05-15Search the exception table with linear algorithmZang Roy-r61911
Search the exception table with linear algorithm instead of bisecting algorithm. Because the exception table might be unsorted. Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
2007-05-11ppc4xx: Set bd->bi_pci_busfreq on 440EPx/GRx tooStefan Roese
2007-05-01mpc83xx: replace elaborate boottime verbosity with 'clocks' commandKim Phillips
and fix CPU: to align with Board: display text. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-04-20Cleanup compiler warnings, update CHANGELOGWolfgang Denk
2007-01-22Merge branch 'master' into hpc2roy zang
Conflicts: drivers/cfi_flash.c The patch by Heiko Schocher <hs@pollux.denx.de> on Jan, 19, 2007 fixes cfi_driver bug for mpc7448hpc2 board. The default cfi_driver can support mpc7448hpc2 board.
2007-01-11 Added support for the SOLIDCARD III board from EurodesignHeiko Schocher
2007-01-04Merge branch 'master' into hpc2roy zang
2006-12-24Merge with /home/hs/TQ/u-boot-devWolfgang Denk
2006-12-21Added support for the TQM8272 board from TQHeiko Schocher
2006-12-04Slight code clean up.roy zang
Add comments, delete duplicate define and remove spaces. Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
2006-12-01Fix the exception occuring in RAM table search issue.roy zang
The original search_one_table() function code can only processes the search for the exception occurring in FLASH/ROM, because the exception and fixup table usually locate in FLASH. If the exception address is also in FLASH, it will be OK. If the exception occurs in RAM, after the u-boot relocation, a relocation offset should be added. clean up the code in cpu/74xx_7xx/cpu.c Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
2006-12-01Fix the confilcts when merging 'master' into hpc2.roy zang
The conflicts due to a new mpc7448 p3m7448 board is in the main tree. Merge branch 'master' into hpc2 Conflicts: MAKEALL cpu/74xx_7xx/cpu.c cpu/74xx_7xx/cpu_init.c cpu/74xx_7xx/speed.c
2006-11-30Code cleanup.Wolfgang Denk
2006-11-03mpc83xx: Replace CFG_IMMRBAR with CFG_IMMRTimur Tabi
Replace all instances of CFG_IMMRBAR with CFG_IMMR, so that the 83xx tree matches the other 8xxx trees. Signed-off-by: Timur Tabi <timur@freescale.com>
2006-11-02General code modification for mpc7448hpc2 board support.roy zang
1. Add 7447A and 7448 processor support. 2. Add the following flags. CFG_CONFIG_BUS_CLK : If the 74xx bus frequency can be configured dynamically (such as by switch on board), this flag should be set. CFG_EXCEPTION_AFTER_RELOCATE: If an exception occurs after the u-boot relocates to RAM, this flag should be set. CFG_SERIAL_HANG_IN_EXCEPTION: If the print out function will cause the system hang in exception, this flag should be set. There is a design issue for tsi108/109 pci configure read. When pci scan the slots, if there is no pci card, the tsi108/9 will cause a machine check exception for mpc7448 processor. Signed-off-by: Alexandre Bounine <alexandreb@tundra.com> Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
2006-10-19Merge branch 'master' of http://www.denx.de/git/u-bootJon Loeliger
2006-10-18Merge with /home/tur/proj/051_uboot_linux_v38b/u-bootWolfgang Denk
2006-10-13Preliminary patch adding support for the MarelV38B board.Bartlomiej Sieka
2006-10-10Merge branch 'master' of http://www.denx.de/git/u-bootJon Loeliger
2006-09-19Merge branch 'master' of http://www.denx.de/git/u-bootJon Loeliger
Conflicts: board/stxxtc/Makefile
2006-09-07Add support for AMCC Sequoia PPC440EPx eval boardStefan Roese
- Add support for PPC440EPx & PPC440GRx - Add support for PPC440EP(x)/GR(x) NAND controller in cpu/ppc4xx directory - Add NAND boot functionality for Sequoia board, please see doc/README.nand-boot-ppc440 for details - This Sequoia NAND image doesn't support environment in NAND for now. This will be added in a short while. Patch by Stefan Roese, 07 Sep 2006
2006-08-17Unlock cache before kernel starts up for MPC86xxHaiying Wang
2006-08-09Merge branch 'wd'Jon Loeliger
2006-07-13Add support for reading and writing mac addresses to or from ID EEPROM.Haiying Wang
Added code for reading and writing Mac addresses to/from ID EEPROM(0x57). With attached patch, we can use command "mac/mac read/mac save/" to read and write EEPROM under u-boot prompt. U-boot will calculate the checksum of EEPROM while bootup, if it is right, then u-boot will check whether the mac address of eTSEC0/1/2/3 is availalbe (non-zero). If there is mac address availabe in EEPROM, u-boot will use it, otherewise, u-boot will use the mac address defined in MPC8641HPCN.h. This matches the requirement to set unique mac address for each TSEC port. Signed-off-by: Haiying Wang <haiying.wang@freescale.com> Signed-off-by: York Sun <yorksun@freescale.com>
2006-07-12Add support for TQM885D board.Markus Klotzbuecher
Patch by Martin Krause, 20 Mar 2006 Signed-off-by: Martin Krause <martin.krause@tqs.de>
2006-06-30Merge: Add support for AMCC 440SPe CPU based eval board (Yucca).Marian Balakowicz
2006-06-30Call serial_initialize() before first debug() is used.Marian Balakowicz
2006-05-10Remove unneeded INIT_RAM_LOCK cache twiddling.Haiying Wang
Correctly tracks r29 as global data pointer now. Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
2006-04-26Initial support for MPC8641 HPCN board.Jon Loeliger
2006-02-10Enable address translation on MPC83xxKumar Gala
Patch by Kumar Gala, 10 Feb 2006
2005-12-04Code cleanup, especially MIPS for GCC 4.xWolfgang Denk
2005-11-30Add support for TQM8541/8555 boards, TQM85xx support reworked:Stefan Roese
- Support for TQM8541/8555 boards added. - Complete rework of TQM8540/8560 support. - Common TQM85xx code now supports all current TQM85xx platforms (TQM8540/8541/8555/8560). - DDR SDRAM size detection added. - CAS latency default values can be overwritten by setting "serial#" to e.g. "ABC0001 casl=25" -> CAS latency 2.5 will be used. If problems are detected with this non default CAS latency, the defualt values will be used instead. - FLASH size detection added. - Moved FCC ethernet driver initialization behind TSEC driver init -> TSEC is first device. Patch by Stefan Roese, 30 Nov 2005
2005-10-28Add support for multiple PHYs.Marian Balakowicz
2005-10-05E500 update: repoint IVPR to RAM when code is relocatedWolfgang Denk
Patch by Kylo Ginsberg, 13 Apr 2005
2005-08-30Prepare U-Boot for gcc-4.x: fix global data pointer initializationWolfgang Denk
The global data pointer, stored in r29 before relocation to RAM, was not initialized to a correct value. This happened because the pointer declaration was done locally in the scope of the board_init_f() function. What follows is a cite from gcc.info, 5.37, "Variables in Specified Registers": ... The compiler's data flow analysis is capable of determining where the specified registers contain live values, and where they are available for other uses. Stores into local register variables may be deleted when they appear to be dead according to dataflow analysis. References to local register variables may be deleted or moved or simplified. ... Moving the global data declaration to global scope solved the problem.
2005-08-26Prepare U-Boot for gcc-4.xWolfgang Denk
2005-08-15Add Sandburst Metrobox and Sandburst Karef board support packages.Stefan Roese
Second serial port on 440GX now defined as a system device. Add 'Short Etch' code for Cicada PHY within 440gx_enet.c Patch by Travis B. Sawyer, 12 Jul 2005 Check return value of malloc in 440gx_enet.c Patch by Travis B. Sawyer, 18 Jul 2005
2005-08-08Changed CONFIG_440_xx to CONFIG_440xx for a consistent design (405 and linux)Stefan Roese
Patch by Stefan Roese, 08 Aug 2005
2005-08-02Merge with rsync://git-user@source.denx.net/git/u-boot.gitJon Loeliger
2005-08-01Add support for AMCC PPC440EP/GR eval boards Yosemite and Yellowstone.Stefan Roese
Patch by Steven Blakeslee, 27 Jul 2005
