- Add support for PPC440EPx & PPC440GRx
- Add support for PPC440EP(x)/GR(x) NAND controller
in cpu/ppc4xx directory
- Add NAND boot functionality for Sequoia board,
please see doc/README.nand-boot-ppc440 for details
- This Sequoia NAND image doesn't support environment
in NAND for now. This will be added in a short while.
Patch by Stefan Roese, 07 Sep 2006
Patch by Martin Krause, 20 Mar 2006
Signed-off-by: Martin Krause <martin.krause@tqs.de>
Patch by Kumar Gala, 10 Feb 2006
- Support for TQM8541/8555 boards added.
- Complete rework of TQM8540/8560 support.
- Common TQM85xx code now supports all current TQM85xx platforms
(TQM8540/8541/8555/8560).
- DDR SDRAM size detection added.
- CAS latency default values can be overwritten by setting "serial#"
to e.g. "ABC0001 casl=25" -> CAS latency 2.5 will be used.
If problems are detected with this non default CAS latency,
the defualt values will be used instead.
- FLASH size detection added.
- Moved FCC ethernet driver initialization behind TSEC driver init
-> TSEC is first device.
Patch by Stefan Roese, 30 Nov 2005
Patch by Kylo Ginsberg, 13 Apr 2005
The global data pointer, stored in r29 before relocation to RAM, was
not initialized to a correct value. This happened because the pointer
declaration was done locally in the scope of the board_init_f()
function. What follows is a cite from gcc.info, 5.37, "Variables in
Specified Registers":
The compiler's data flow analysis is capable of determining where
the specified registers contain live values, and where they are
available for other uses. Stores into local register variables
may be deleted when they appear to be dead according to dataflow
analysis. References to local register variables may be deleted
or moved or simplified.
Moving the global data declaration to global scope solved the
problem.
Second serial port on 440GX now defined as a system device.
Add 'Short Etch' code for Cicada PHY within 440gx_enet.c
Patch by Travis B. Sawyer, 12 Jul 2005
Check return value of malloc in 440gx_enet.c
Patch by Travis B. Sawyer, 18 Jul 2005
Patch by Stefan Roese, 08 Aug 2005
Patch by Steven Blakeslee, 27 Jul 2005
Add support for the Freescale MPC8349ADS board.
- Convert the CPM2 based functionality to use new CONFIG_CPM2
option rather than a myriad of CONFIG_MPC8560-like variants.
Applies to MPC85xx and MPC8260 boards, includes stxgp3 and sbc8560.
Eliminates the CONFIG_MPC8560 option entirely. Distributes the
new CONFIG_CPM2 option to each 8260 board.
Add support for Funkwerk VoVPN gateway module.
* Cleanup confusing use of CONFIG_ETH*ADDR - ust his only to
pre-define a MAC address; use CONFIG_HAS_ETH* to enable support for
additional ethernet addresses.
* Cleanup drivers/i82365.c - avoid duplication of code
* Fix bogus "cannot span across banks" flash error message
* Add support for CompactFlash for the CPC45 Board.
- Enable booting directly from flash
- fix CMC_PU2 flash driver
* Fix mkimage usage message
- add support for MPC8220 CPU
- Add support for Alaska and Yukon boards
- Add support for the MPC8541 and MPC8555 CDS boards
- Cleanup eth?addr handling: make dependent on CONFIG_ETH?ADDR
Allow clock setting on MPC866/MPC885 series chips according to
environment variable `cpuclk'
* Patch by Yuli Barcohen, 20 Apr 2004:
Remove unnecessary redefine of CPM_DATAONLY_SIZE for MPC826x
* Patch by Sascha Hauer, 28 Jun:
- add generic support for Motorola i.MX architecture
- add support for mx1ads, mx1fs2 and scb9328 boards
* Patches by Marc Leeman, 23 Jul 2004:
- Add define for the PCI/Memory Buffer Configuration Register
- corrected comments in cpu/mpc824x/cpu_init.c
* Add support for multiple serial interfaces
(for example to allow modem dial-in / dial-out)
Completion of the 8540ADS/8560ADS updates:
Fix some PCI and Rapid I/O memory maps,
Initialize both TSEC 1 and 2,
Initialize SDRAM
Update MAINTAINER for 85xx boards and README.mpc85xxads
- fix problems with examples/stubs.c for GCC >= 3.4
- fix problems with gd initialization
* Enable FAT filesystem support for HMI10 board
Using external watchdog for KUP4 boards in mpc8xx/cpu.c;
load_sernum_ethaddr() for KUP4 boards in lib_ppc/board.c;
various changes to KUP4 board specific files
binary image for all clock frequencies. Implement run-time
optimization of flash access timing based on the actual bus
frequency.
- Add support for RPC/STx GP3, Motorola 8560 board
- Update 85xx TSEC driver so it searches MII for first available PHY
and uses that one.
- Add functions to support console MII commands.
* Patch by Tolunay Orkun, 07 Apr 2004:
Move initialization of bi_iic_fast[]
from board_init_f() to board_init_r()
* Patch by Yasushi Shoji, 07 Apr 2004:
Cleanup microblaze port
* Patch by Sangmoon Kim, 07 Apr 2004:
Add auto SDRAM module detection for Debris board
- add auto-complete support to the U-Boot CLI
- add support for NETTA and NETPHONE boards; fix NETVIA board
* Patch by Yuli Barcohen, 28 Mar 2004:
- Add support for MPC8272 family including MPC8247/8248/8271/8272
- Add support for MPC8272ADS evaluation board (another flavour of MPC8260ADS)
- Change configuration method for MPC8260ADS family
unconfiguring the board
* Adapt RMU board for bigger flash memory
* Test fix for ethernet problems on MPC5200
Add support for KUP4X Board
- Unify video mode handling for Chips & Technologies 69000 Video
chip and Silicon Motion SMI 712/710/810 Video chip
- Add selection of the video output (CRT or LCD) via 'videoout'
environment variable for the Silicon Motion
- README update
* Patch by Pierre Aubert, 18 Mar 2004:
include/common.h typo fix
* Patches by Tolunay Orkun, 17 Mar 2004:
- Add support for bd->bi_iic_fast[] initialization via environment
variable "i2cfast" (CONFIG_I2CFAST)
- Add "i2cfast" u-boot environment variable support for csb272
avoid dereferencing NULL pointer in lib_arm/armlinux.c
* Patch by Stephen Williams, 15 Mar 2004:
Fix CONFIG_SERIAL_SOFTWARE_FIFO documentation
* Patch by Tolunay Orkun, 15 Mar 2004:
Initialize bi_opbfreq to real OPB frequency via get_OPB_freq()
* Patch by Travis Sawyer, 15 Mar 2004:
Update CREDITS & MAINTAINERS files for PPC440GX & Ocotea port
add IDE support for MPC5200
* Patch by Masami Komiya, 26 Feb 2004:
add autoload via NFS
Use of CONFIG_SERIAL_SOFTWARE_FIFO in board.c consistent with uses
elsewhere in the source.
Add support for NFS for file download
* Minor code cleanup
Add support for the Xilinx ML300 platform
* Patch by Stephan Linz, 17 Feb 2004:
Fix watchdog support for NIOS
* Patch by Josh Fryman, 16 Feb 2004:
Fix byte-swapping for cfi_flash.c for different bus widths
* Patch by Jon Diekema, 14 Jeb 2004:
Remove duplicate "FPGA Support" notes from the README file
- update board/emk tree; use common flash driver
- Corrected tested bits in machine check exception in cpu/mpc5xxx/traps.c
[adapted for other PPC CPUs -- wd]
- Added support for the M48T08 on the EVAL5200 board in rtc/mk48t59.c
* Patch by Jon Diekema, 13 Feb 2004:
Call show_boot_progress() whenever POST "FAILED" is printed.
* Patch by Nishant Kamat, 13 Feb 2004:
Add support for TI OMAP1610 H2 Board
Fixes for cpu/arm926ejs/interrupt.c
(based on Richard Woodruff's patch for arm925, 16 Oct 03)
Fix for a timer bug in OMAP1610 Innovator
Add support for CS0 (ROM)/CS3 (Flash) boot in OMAP1610 Innovator and H2
* Patches by Stephan Linz, 12 Feb 2004:
- add support for NIOS timer with variable period preload counter value
- prepare POST framework support for NIOS targets
* Patch by Denis Peter, 11 Feb 2004:
add POST support for the MIP405 board
Add support for IBM PPC440GX. Multiple EMAC Ethernet devices,
select MDI port based on enabled EMAC device.
Add support for XES Inc <http://www.xes-inc.com> XPedite1000 440GX
base PrPMC board.
see doc/README.MPC866 for details;
implement workaround for "SIU4" and "SIU9" silicon bugs on MPC866;
calculate CPU clock frequency from PLL register values.
* Add support for 128 MB RAM on TQM8xxL/M modules
before we can access it; add delay in case we are faster (with no
CF card inserted)
* Cleanup of some init functions
* Make sure SCC Ethernet is always stopped by the time we boot Linux
to avoid Linux crashes by early packets coming in.
* Accelerate flash accesses on LWMON board by using buffered writes
version of the repository???]
* Patch by Reinhard Meyer, 09 Jan 2004:
- add RTC support for MPC5200 based boards (requires RTC_XTAL)
* Add support for IDE LED on BMS2003 board
(exclusive with status LED!)
* Add support for PS/2 keyboard (used with PS/2 multiplexor on
BMS2003 board)
* Patches by Reinhard Meyer, 4 Jan 2004 + 7 Jan 2004:
Add common files for "emk" boards
* Minor code cleanup (coding style)
* Patch by Reinhard Meyer, 30 Dec 2003:
- cpu/mpc5xxx/fec.c: added CONFIG_PHY_ADDR, added CONFIG_PHY_TYPE,
- added CONFIG_PHY_ADDR to include/configs/IceCube.h,
- turned debug print of PHY registers into a function (called in two places)
- added support for EMK MPC5200 based modules
* Fix MPC8xx PLPRCR_MFD_SHIFT typo
* Add support for TQM866M modules
* Fixes for TQM855M with 4 MB flash (Am29DL163 = _no_ mirror bit flash)
* Fix a few compiler warnings
