path: root/lib_ppc/Makefile
2008-02-14ppc: Refactor cache routines, so there is only one common set.Rafal Jaworowski
Signed-off-by: Rafal Jaworowski <raj@semihalf.com>
2003-12-06* Patch by Gleb Natapov, 19 Sep 2003:wdenk
Move most of the timer interrupt related PPC code to ppc_lib/interrupts.c * Patch by Anders Larsen, 17 Sep 2003: Bring ARM memory layout in sync with the documentation: stack and malloc-heap are now located _below_ the U-Boot code
2002-08-14Initial revisionwdenk
