path: root/lib_nios
2008-08-26bootm: refactor do_reset and os boot function argsKumar Gala
There is no need for each OS specific function to call do_reset() we can just do it once in bootm. This means its feasible on an error for the OS boot function to return. Also, remove passing in cmd_tbl_t as its not needed by the OS boot functions. flag isn't currently used but might be in the future so we left it alone. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-04-18allow ports to override go behaviorMike Frysinger
Split the arch-specific logic out of the common go code and into a dedicated weak function called do_go_exec() that lives in cpu directories. This will need review from i386/nios people to make sure I didn't break them.
2008-02-27[new uImage] Move image verify flag to bootm_headers structureMarian Balakowicz
Do not pass image verification flag directly to related routines. Simplify argument passing and move it to the bootm_header structure which contains curently processed image specific data and is already being passed on the argument list. Signed-off-by: Marian Balakowicz <m8@semihalf.com> Acked-by: Kumar Gala <galak@kernel.crashing.org>
2008-02-27[Makefile] Sort COBJS in lib_<arch> MakefilesMarian Balakowicz
2008-02-25[new uImage] Add dual format uImage support frameworkMarian Balakowicz
This patch adds framework for dual format images. Format detection is added and the bootm controll flow is updated to include cases for new FIT format uImages. When the legacy (image_header based) format is detected appropriate legacy specific handling is invoked. For the new (FIT based) format uImages dual boot framework has a minial support, that will only print out a corresponding debug messages. Implementation of the FIT specific handling will be added in following patches. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-07[new uImage] Rename architecture specific bootm code filesMarian Balakowicz
Implementation of the do_bootm_linux() and other bootm helper routines is architecture specific code. As such it resides in lib_<arch> directories in files named <arch>_linux.c This patch renames those files to a more clear and accurate lib_<arch>/bootm.c form. List of the renamed files: lib_arm/armlinux.c -> lib_arm/bootm.c lib_avr32/avr32_linux.c -> lib_avr32/bootm.c lib_blackfin/bf533_linux.c -> lib_blackfin/bootm.c lib_i386/i386_linux.c -> lib_i386/bootm.c lib_m68k/m68k_linux.c -> lib_m68k/bootm.c lib_microblaze/microblaze_linux.c -> lib_microblaze/bootm.c lib_mips/mips_linux.c -> lib_mips/bootm.c lib_nios/nios_linux.c -> lib_nios/bootm.c lib_nios2/nios_linux.c -> lib_nios2/bootm.c lib_ppc/ppc_linux.c -> lib_ppc/bootm.c lib_sh/sh_linux.c -> lib_sh/bootm.c Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-07[new uImage] Cleanup image header pointer use in bootm codeMarian Balakowicz
- use single image header pointer instead of a set of auxilliary variables. - add multi component image helper routines: get component size/data address Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2004-07-01* Patches by Richard Woodruff, 10 Jun 2004:wdenk
- fix problems with examples/stubs.c for GCC >= 3.4 - fix problems with gd initialization * Enable FAT filesystem support for HMI10 board
2004-05-19Patch by Scott McNutt, 25 Apr 2004:LABEL_2004_05_19_2335wdenk
Add Nios GDB/JTAG Console support: - Add stubs to support gdb via JTAG. - Add support for console over JTAG. - Minor cleanup.
2004-02-23* Patch by Peter Ryser, 20 Feb 2004:wdenk
Add support for the Xilinx ML300 platform * Patch by Stephan Linz, 17 Feb 2004: Fix watchdog support for NIOS * Patch by Josh Fryman, 16 Feb 2004: Fix byte-swapping for cfi_flash.c for different bus widths * Patch by Jon Diekema, 14 Jeb 2004: Remove duplicate "FPGA Support" notes from the README file
2004-02-09Patches by Stephan Linz, 30 Jan 2004:wdenk
1: - board/altera/common/flash.c:flash_erase(): o allow interrupts befor get_timer() call o check-up each erased sector and avoid unexpected timeouts - board/altera/dk1c20/dk1s10.c:board_early_init_f(): o enclose sevenseg_set() in cpp condition - remove the ASMI configuration for DK1S10_standard_32 (never present) - fix some typed in mistakes in the NIOS documentation 2: - split DK1C20 configuration into several header files: o two new files for each NIOS CPU description o U-Boot related part is remaining in DK1C20.h 3: - split DK1S10 configuration into several header files: o two new files for each NIOS CPU description o U-Boot related part is remaining in DK1S10.h 4: - Add support for the Microtronix Linux Development Kit NIOS CPU configuration at the Altera Nios Development Kit, Stratix Edition (DK-1S10) 5: - Add documentation for the Altera Nios Development Kit, Stratix Edition (DK-1S10) 6: - Add support for the Nios Serial Peripharel Interface (SPI) (master only) 7: - Add support for the common U-Boot SPI framework at RTC driver DS1306
2004-01-03Patches by Stephan Linz, 11 Dec 2003:wdenk
- more documentation for NIOS port - new struct nios_pio_t, struct nios_spi_t - Reconfiguration for NIOS Development Kit DK1C20: o move board related code from board/dk1c20 to board/altera/dk1c20 o create a new common source path board/altera/common and move generic flash access stuff into it o change/expand configuration file DK1C20.h - Add support for NIOS Development Kit DK1S10 - Add status LED support for NIOS systems - Add dual 7-segment LED support for Altera NIOS DevKits
2004-01-02* Cleanup lowboot code for MPC5200wdenk
* Minor code cleanup (coding style) * Patch by Reinhard Meyer, 30 Dec 2003: - cpu/mpc5xxx/fec.c: added CONFIG_PHY_ADDR, added CONFIG_PHY_TYPE, - added CONFIG_PHY_ADDR to include/configs/IceCube.h, - turned debug print of PHY registers into a function (called in two places) - added support for EMK MPC5200 based modules * Fix MPC8xx PLPRCR_MFD_SHIFT typo * Add support for TQM866M modules * Fixes for TQM855M with 4 MB flash (Am29DL163 = _no_ mirror bit flash) * Fix a few compiler warnings
2003-10-28* Patch by Stephan Linz, 28 Oct 2003:wdenk
fix init sequence error for NIOS port * Allow lowercase spelling for IceCube_5200; support MPC5200LITE name * Add CONFIG_VERSION_VARIABLE to TRAB configuration
2003-10-19* Patch by Steven Scholz, 18 Oct 2003:wdenk
Fix AT91RM9200 ethernet driver * Patch by Nye Liu, 17 Oct 2003: Fix typo in include/mpc8xx.h * Patch by Richard Woodruff, 16 Oct 03: Fixes for cpu/arm925/interrupt.c - Initialize timestamp & lastdec vars. - fix timestamp overflows. - fix lastdec overflow. - smarter normalization to allow udelay() below 1ms to work. * Patch by Scott McNutt, 16 Oct add networking support for the Altera Nios Development Kit, Cyclone Edition (DK-1C20) * Patch by Jon Diekema, 14 Oct 2003: add hint about doc/README.silent to README file
2003-10-08* Patch by Scott McNutt, 04 Oct 2003:wdenk
- add support for Altera Nios-32 CPU - add support for Nios Cyclone Development Kit (DK-1C20) * Patch by Steven Scholz, 29 Sep 2003: - A second parameter for bootm overwrites the load address for "Standalone Application" images. - bootm sets environment variable "filesize" to the resulting (uncompressed) data length for "Standalone Application" images when autostart is set to "no". Now you can do something like if bootm $fpgadata $some_free_ram ; then fpga load 0 $some_free_ram $filesize fi * Patch by Denis Peter, 25 Sept 2003: add support for the MIP405 Rev. C board
