Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk
This change is intended to clean up the top-level directory structure
and more closely mimic Linux's directory organization.
board/esd/plu405/plu405.c
drivers/rtc/ftrtc010.c
According to the PPC reference implementation the udelay() function is
responsible for resetting the watchdog timer as frequently as needed.
Most other architectures do not meet that requirement, so long-running
operations might result in a watchdog reset.
This patch adds a generic udelay() function which takes care of
resetting the watchdog before calling an architecture-specific
__udelay().
Signed-off-by: Ingo van Lil <inguin@gmx.de>
the standalone examples.
Signed-off-by: Scott McNutt <smcnutt@psyent.com>
By "arm/microblaze/nios/nios2/sh: Remove relocation fixups"
(commit: 0630535e2d062dd73c1ceca5c6125c86d1127a49", doesn't need
malloc_bin_reloc function. This commit remove this.
Rather than maintain/extend the current ifeq($(ARCH)) mess that exists in
the standalone Makefile, push the setting up of LOAD_ADDR out to the arch
config.mk (and rename to STANDALONE_LOAD_ADDR in the process). This keeps
the common code clean and lets the arch do whatever crazy crap it wants in
its own area.
This lays the groundwork to allow architectures to share a common
mem_malloc_init().
Note that the x86 implementation was not modified as it did not fit the
mold of all other architectures.
This cleans up U-Boot's toplevel directory a bit and makes the
architecture 'config.mk' file naming and location similar to board
and cpu 'config.mk' files
So far the console API uses the following naming convention:
======Extract======
typedef struct device_t;
int device_register (device_t * dev);
int devices_init (void);
int device_deregister(char *devname);
struct list_head* device_get_list(void);
device_t* device_get_by_name(char* name);
device_t* device_clone(device_t *dev);
which is too generic and confusing.
Instead of using device_XX and device_t we change this
into stdio_XX and stdio_dev
This will also allow to add later a generic device mechanism in order
to have support for multiple devices and driver instances.
Edited commit message.
This patch moves the malloc initialization before calling flash_init().
Upcoming changes to the NOR FLASH common CFI driver with optional
MTD infrastructure and MTD concatenation support will call malloc().
And nothing really speaks against enabling malloc just a little earlier
in the boot stage. Some architectures already enable malloc before
calling flash_init() so they don't need any changes here.
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: Scott McNutt <smcnutt@psyent.com>
Cc: Shinya Kuribayashi <shinya.kuribayashi@necel.com>
Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
Cc: Daniel Hellstrom <daniel@gaisler.com>
Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Cc: John Rigby <jcrigby@gmail.com>
Since everyone is using the environment for mac address storage, there is
no point in seeding the global data.
The arches that are converted here:
i386
m68k
microblaze
mips
nios
nios2
sh
sparc
CC: Ben Warren <biggerbadderben@gmail.com>
CC: Daniel Hellstrom <daniel@gaisler.com>
CC: Michal Simek <monstr@seznam.cz>
CC: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
CC: Scott McNutt <smcnutt@psyent.com>
CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
There is no need for each OS specific function to call do_reset() we
can just do it once in bootm. This means its feasible on an error for
the OS boot function to return.
Also, remove passing in cmd_tbl_t as its not needed by the OS boot
functions. flag isn't currently used but might be in the future so
we left it alone.
This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
Split the arch-specific logic out of the common go code and into a dedicated
weak function called do_go_exec() that lives in cpu directories. This will
need review from i386/nios people to make sure I didn't break them.
Do not pass image verification flag directly to related routines.
Simplify argument passing and move it to the bootm_header structure which
contains curently processed image specific data and is already being passed
on the argument list.
Signed-off-by: Marian Balakowicz <m8@semihalf.com>
Acked-by: Kumar Gala <galak@kernel.crashing.org>
This patch adds framework for dual format images. Format detection is added
and the bootm controll flow is updated to include cases for new FIT format
uImages.
When the legacy (image_header based) format is detected appropriate
legacy specific handling is invoked. For the new (FIT based) format uImages
dual boot framework has a minial support, that will only print out a
corresponding debug messages. Implementation of the FIT specific handling will
be added in following patches.
Implementation of the do_bootm_linux() and other bootm helper routines is
architecture specific code. As such it resides in lib_<arch> directories
in files named <arch>_linux.c
This patch renames those files to a more clear and accurate
lib_<arch>/bootm.c form.
List of the renamed files:
lib_arm/armlinux.c -> lib_arm/bootm.c
lib_avr32/avr32_linux.c -> lib_avr32/bootm.c
lib_blackfin/bf533_linux.c -> lib_blackfin/bootm.c
lib_i386/i386_linux.c -> lib_i386/bootm.c
lib_m68k/m68k_linux.c -> lib_m68k/bootm.c
lib_microblaze/microblaze_linux.c -> lib_microblaze/bootm.c
lib_mips/mips_linux.c -> lib_mips/bootm.c
lib_nios/nios_linux.c -> lib_nios/bootm.c
lib_nios2/nios_linux.c -> lib_nios2/bootm.c
lib_ppc/ppc_linux.c -> lib_ppc/bootm.c
lib_sh/sh_linux.c -> lib_sh/bootm.c
- use single image header pointer instead of a set of auxilliary variables.
- add multi component image helper routines: get component size/data address
Modifications are based on the linux kernel approach and
support two use cases:
1) Add O= to the make command line
'make O=/tmp/build all'
2) Set environement variable BUILD_DIR to point to the desired location
'export BUILD_DIR=/tmp/build'
'make'
The second approach can also be used with a MAKEALL script
'./MAKEALL'
Command line 'O=' setting overrides BUILD_DIR environent variable.
When none of the above methods is used the local build is performed and
the object files are placed in the source directory.
- fix problems with examples/stubs.c for GCC >= 3.4
- fix problems with gd initialization
* Enable FAT filesystem support for HMI10 board
Add Nios GDB/JTAG Console support:
- Add stubs to support gdb via JTAG.
- Add support for console over JTAG.
- Minor cleanup.
Add support for the Xilinx ML300 platform
* Patch by Stephan Linz, 17 Feb 2004:
Fix watchdog support for NIOS
* Patch by Josh Fryman, 16 Feb 2004:
Fix byte-swapping for cfi_flash.c for different bus widths
* Patch by Jon Diekema, 14 Jeb 2004:
Remove duplicate "FPGA Support" notes from the README file
1: - board/altera/common/flash.c:flash_erase():
o allow interrupts befor get_timer() call
o check-up each erased sector and avoid unexpected timeouts
- board/altera/dk1c20/dk1s10.c:board_early_init_f():
o enclose sevenseg_set() in cpp condition
- remove the ASMI configuration for DK1S10_standard_32 (never present)
- fix some typed in mistakes in the NIOS documentation
2: - split DK1C20 configuration into several header files:
o two new files for each NIOS CPU description
o U-Boot related part is remaining in DK1C20.h
3: - split DK1S10 configuration into several header files:
o U-Boot related part is remaining in DK1S10.h
4: - Add support for the Microtronix Linux Development Kit
NIOS CPU configuration at the Altera Nios Development Kit,
Stratix Edition (DK-1S10)
5: - Add documentation for the Altera Nios Development Kit,
6: - Add support for the Nios Serial Peripharel Interface (SPI)
(master only)
7: - Add support for the common U-Boot SPI framework at
RTC driver DS1306
before we can access it; add delay in case we are faster (with no
CF card inserted)
* Cleanup of some init functions
* Make sure SCC Ethernet is always stopped by the time we boot Linux
to avoid Linux crashes by early packets coming in.
* Accelerate flash accesses on LWMON board by using buffered writes
- more documentation for NIOS port
- new struct nios_pio_t, struct nios_spi_t
- Reconfiguration for NIOS Development Kit DK1C20:
o move board related code from board/dk1c20
to board/altera/dk1c20
o create a new common source path board/altera/common
and move generic flash access stuff into it
o change/expand configuration file DK1C20.h
- Add support for NIOS Development Kit DK1S10
- Add status LED support for NIOS systems
- Add dual 7-segment LED support for Altera NIOS DevKits
* Minor code cleanup (coding style)
* Patch by Reinhard Meyer, 30 Dec 2003:
- cpu/mpc5xxx/fec.c: added CONFIG_PHY_ADDR, added CONFIG_PHY_TYPE,
- added CONFIG_PHY_ADDR to include/configs/IceCube.h,
- turned debug print of PHY registers into a function (called in two places)
- added support for EMK MPC5200 based modules
* Fix MPC8xx PLPRCR_MFD_SHIFT typo
* Add support for TQM866M modules
* Fixes for TQM855M with 4 MB flash (Am29DL163 = _no_ mirror bit flash)
* Fix a few compiler warnings
fix init sequence error for NIOS port
* Allow lowercase spelling for IceCube_5200; support MPC5200LITE name
* Add CONFIG_VERSION_VARIABLE to TRAB configuration
Fix AT91RM9200 ethernet driver
* Patch by Nye Liu, 17 Oct 2003:
Fix typo in include/mpc8xx.h
* Patch by Richard Woodruff, 16 Oct 03:
Fixes for cpu/arm925/interrupt.c
- Initialize timestamp & lastdec vars.
- fix timestamp overflows.
- fix lastdec overflow.
- smarter normalization to allow udelay() below 1ms to work.
* Patch by Scott McNutt, 16 Oct
add networking support for the Altera Nios Development Kit,
Cyclone Edition (DK-1C20)
* Patch by Jon Diekema, 14 Oct 2003:
add hint about doc/README.silent to README file
- add support for Altera Nios-32 CPU
- add support for Nios Cyclone Development Kit (DK-1C20)
* Patch by Steven Scholz, 29 Sep 2003:
- A second parameter for bootm overwrites the load address for
"Standalone Application" images.
- bootm sets environment variable "filesize" to the resulting
(uncompressed) data length for "Standalone Application" images
when autostart is set to "no". Now you can do something like
if bootm $fpgadata $some_free_ram ; then
fpga load 0 $some_free_ram $filesize
fi
* Patch by Denis Peter, 25 Sept 2003:
add support for the MIP405 Rev. C board
