Add the ability to break the steps of the bootm command into several
subcommands: start, loados, ramdisk, fdt, bdt, cmdline, prep, go.
This allows us to do things like manipulate device trees before
they are passed to a booting kernel or setup memory for a secondary
core in multicore situations.
Not all OS types support all subcommands (currently only start, loados,
ramdisk, fdt, and go are supported).
There is no need for each OS specific function to call do_reset() we
can just do it once in bootm. This means its feasible on an error for
the OS boot function to return.
Also, remove passing in cmd_tbl_t as its not needed by the OS boot
functions. flag isn't currently used but might be in the future so
we left it alone.
Move entry point code out of each arch and into common code.
Keep the entry point in the bootm_headers_t images struct.
The autostart revert caused a bit of duplicated code as well as
code that was using images->autostart that needs to get removed so
we can build again.
This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
Before new uImage code was merged, bootm code allowed for the kernel image to
get overwritten during decompresion. new uImage introduced a check for image
overwrites and refused to boot the image that got overwritten. This patch
restores the old behavior. It also adds a warning when the image overwriten is
a multi-image file, because in such case accessing componentes other than the
first one will fail.
Signed-off-by: Marian Balakowicz <m8@semihalf.com>
routines
This patch updates architecture specific implementations of
do_bootm_linux() adding new uImage format handling for
operations like get kernel entry point address, get kernel
image data start address.
Acked-by: Marian Balakowicz <m8@semihalf.com>
Do not pass image verification flag directly to related routines.
Simplify argument passing and move it to the bootm_header structure which
contains curently processed image specific data and is already being passed
on the argument list.
Acked-by: Kumar Gala <galak@kernel.crashing.org>
This patch adds framework for dual format images. Format detection is added
and the bootm controll flow is updated to include cases for new FIT format
uImages.
When the legacy (image_header based) format is detected appropriate
legacy specific handling is invoked. For the new (FIT based) format uImages
dual boot framework has a minial support, that will only print out a
corresponding debug messages. Implementation of the FIT specific handling will
be added in following patches.
Implementation of the do_bootm_linux() and other bootm helper routines is
architecture specific code. As such it resides in lib_<arch> directories
in files named <arch>_linux.c
This patch renames those files to a more clear and accurate
lib_<arch>/bootm.c form.
List of the renamed files:
lib_arm/armlinux.c -> lib_arm/bootm.c
lib_avr32/avr32_linux.c -> lib_avr32/bootm.c
lib_blackfin/bf533_linux.c -> lib_blackfin/bootm.c
lib_i386/i386_linux.c -> lib_i386/bootm.c
lib_m68k/m68k_linux.c -> lib_m68k/bootm.c
lib_microblaze/microblaze_linux.c -> lib_microblaze/bootm.c
lib_mips/mips_linux.c -> lib_mips/bootm.c
lib_nios/nios_linux.c -> lib_nios/bootm.c
lib_nios2/nios_linux.c -> lib_nios2/bootm.c
lib_ppc/ppc_linux.c -> lib_ppc/bootm.c
lib_sh/sh_linux.c -> lib_sh/bootm.c
- use single image header pointer instead of a set of auxilliary variables.
- add multi component image helper routines: get component size/data address
- Add inline helper macros for basic header processing
- Move common non inline code common/image.c
- Replace direct header access with the API routines
- Rename IH_CPU_* to IH_ARCH_*
Modifications are based on the linux kernel approach and
support two use cases:
1) Add O= to the make command line
'make O=/tmp/build all'
2) Set environement variable BUILD_DIR to point to the desired location
'export BUILD_DIR=/tmp/build'
'make'
The second approach can also be used with a MAKEALL script
'./MAKEALL'
Command line 'O=' setting overrides BUILD_DIR environent variable.
When none of the above methods is used the local build is performed and
the object files are placed in the source directory.
-When booting from an epcs controller, the epcs bootrom may leave the
slave select in an asserted state causing soft reset hang. This
patch ensures slave select is negated at reset.
Patch by Scott McNutt, 08 Jun 2006
Add support for Nios-II EPCS Controller core.
* Patch by Scott McNutt, 20 Oct 2004:
Nios-II cleanups:
- Add sysid command (Nios-II only).
- Locate default exception trampoline at proper offset.
- Implement I/O routines (readb, writeb, etc)
- Implement do_bootm_linux
- Add support for Altera Nios-II processors.
- Add support for Psyent PCI-5441 board.
- Add support for Psyent PK1C20 board.
