path: root/lib_nios2
2006-06-08Nios II - Add EPCS Controller bootrom work-aroundScott McNutt
-When booting from an epcs controller, the epcs bootrom may leave the slave select in an asserted state causing soft reset hang. This patch ensures slave select is negated at reset. Patch by Scott McNutt, 08 Jun 2006
2005-03-30* Patch by Scott McNutt, 21 Oct 2004:wdenk
Add support for Nios-II EPCS Controller core. * Patch by Scott McNutt, 20 Oct 2004: Nios-II cleanups: - Add sysid command (Nios-II only). - Locate default exception trampoline at proper offset. - Implement I/O routines (readb, writeb, etc) - Implement do_bootm_linux
2004-10-10Patches by Scott McNutt, 24 Aug 2004:wdenk
- Add support for Altera Nios-II processors. - Add support for Psyent PCI-5441 board. - Add support for Psyent PK1C20 board.
