path: root/lib_nios2/bootm.c
2010-04-13Move lib_$ARCH directories to arch/$ARCH/libPeter Tyser
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk This change is intended to clean up the top-level directory structure and more closely mimic Linux's directory organization. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-04-02nios2: pass command line and initrd to linux in bootm.cThomas Chou
This patch adds bootargs passing to nios2 linux. The args passing is enabled with, r4 : 'NIOS' magic r5 : pointer to initrd start r6 : pointer to initrd end r7 : pointer to command line Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Scott McNutt <smcnutt@psyent.com>
2009-11-23Nios2: do_boom_linux(): kernel gunzip input data integrity problem due toRenato Andreola
missing cache flush. Added instruction and data caches flush. Signed-off-by: Scott McNutt <smcnutt@psyent.com>
2008-10-29bootm: Add subcommandsKumar Gala
Add the ability to break the steps of the bootm command into several subcommands: start, loados, ramdisk, fdt, bdt, cmdline, prep, go. This allows us to do things like manipulate device trees before they are passed to a booting kernel or setup memory for a secondary core in multicore situations. Not all OS types support all subcommands (currently only start, loados, ramdisk, fdt, and go are supported). Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-09-10bootm arm/avr32/blackfin/microblaze/nios2/sh: remove no more need 'error' labelJean-Christophe PLAGNIOL-VILLARD
2008-08-26bootm: refactor do_reset and os boot function argsKumar Gala
There is no need for each OS specific function to call do_reset() we can just do it once in bootm. This means its feasible on an error for the OS boot function to return. Also, remove passing in cmd_tbl_t as its not needed by the OS boot functions. flag isn't currently used but might be in the future so we left it alone. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-08-26bootm: refactor entry point codeKumar Gala
Move entry point code out of each arch and into common code. Keep the entry point in the bootm_headers_t images struct. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-08-12Fix fallout from autostart revertKumar Gala
The autostart revert caused a bit of duplicated code as well as code that was using images->autostart that needs to get removed so we can build again. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-04-17Restore the ability to continue booting after legacy image overwriteMarian Balakowicz
Before new uImage code was merged, bootm code allowed for the kernel image to get overwritten during decompresion. new uImage introduced a check for image overwrites and refused to boot the image that got overwritten. This patch restores the old behavior. It also adds a warning when the image overwriten is a multi-image file, because in such case accessing componentes other than the first one will fail. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-03-12[new uImage] Add new uImage format support to arch specific do_bootm_linux() ↵Marian Balakowicz
routines This patch updates architecture specific implementations of do_bootm_linux() adding new uImage format handling for operations like get kernel entry point address, get kernel image data start address. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-29[new uImage] Respect autostart setting in linux bootmKumar Gala
Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Marian Balakowicz <m8@semihalf.com>
2008-02-27[new uImage] Move image verify flag to bootm_headers structureMarian Balakowicz
Do not pass image verification flag directly to related routines. Simplify argument passing and move it to the bootm_header structure which contains curently processed image specific data and is already being passed on the argument list. Signed-off-by: Marian Balakowicz <m8@semihalf.com> Acked-by: Kumar Gala <galak@kernel.crashing.org>
2008-02-25[new uImage] Add dual format uImage support frameworkMarian Balakowicz
This patch adds framework for dual format images. Format detection is added and the bootm controll flow is updated to include cases for new FIT format uImages. When the legacy (image_header based) format is detected appropriate legacy specific handling is invoked. For the new (FIT based) format uImages dual boot framework has a minial support, that will only print out a corresponding debug messages. Implementation of the FIT specific handling will be added in following patches. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-07[new uImage] Rename architecture specific bootm code filesMarian Balakowicz
Implementation of the do_bootm_linux() and other bootm helper routines is architecture specific code. As such it resides in lib_<arch> directories in files named <arch>_linux.c This patch renames those files to a more clear and accurate lib_<arch>/bootm.c form. List of the renamed files: lib_arm/armlinux.c -> lib_arm/bootm.c lib_avr32/avr32_linux.c -> lib_avr32/bootm.c lib_blackfin/bf533_linux.c -> lib_blackfin/bootm.c lib_i386/i386_linux.c -> lib_i386/bootm.c lib_m68k/m68k_linux.c -> lib_m68k/bootm.c lib_microblaze/microblaze_linux.c -> lib_microblaze/bootm.c lib_mips/mips_linux.c -> lib_mips/bootm.c lib_nios/nios_linux.c -> lib_nios/bootm.c lib_nios2/nios_linux.c -> lib_nios2/bootm.c lib_ppc/ppc_linux.c -> lib_ppc/bootm.c lib_sh/sh_linux.c -> lib_sh/bootm.c Signed-off-by: Marian Balakowicz <m8@semihalf.com>
