path: root/lib_microblaze
2008-09-10bootm arm/avr32/blackfin/microblaze/nios2/sh: remove no more need 'error' labelJean-Christophe PLAGNIOL-VILLARD
2008-08-26bootm: refactor do_reset and os boot function argsKumar Gala
There is no need for each OS specific function to call do_reset() we can just do it once in bootm. This means its feasible on an error for the OS boot function to return. Also, remove passing in cmd_tbl_t as its not needed by the OS boot functions. flag isn't currently used but might be in the future so we left it alone. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-08-26bootm: refactor entry point codeKumar Gala
Move entry point code out of each arch and into common code. Keep the entry point in the bootm_headers_t images struct. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-08-12Fix fallout from autostart revertKumar Gala
The autostart revert caused a bit of duplicated code as well as code that was using images->autostart that needs to get removed so we can build again. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-04-17Restore the ability to continue booting after legacy image overwriteMarian Balakowicz
Before new uImage code was merged, bootm code allowed for the kernel image to get overwritten during decompresion. new uImage introduced a check for image overwrites and refused to boot the image that got overwritten. This patch restores the old behavior. It also adds a warning when the image overwriten is a multi-image file, because in such case accessing componentes other than the first one will fail. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-03-12[new uImage] Add new uImage format support to arch specific do_bootm_linux() ↵Marian Balakowicz
routines This patch updates architecture specific implementations of do_bootm_linux() adding new uImage format handling for operations like get kernel entry point address, get kernel image data start address. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-29[new uImage] Respect autostart setting in linux bootmKumar Gala
Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Marian Balakowicz <m8@semihalf.com>
2008-02-27[new uImage] Move image verify flag to bootm_headers structureMarian Balakowicz
Do not pass image verification flag directly to related routines. Simplify argument passing and move it to the bootm_header structure which contains curently processed image specific data and is already being passed on the argument list. Signed-off-by: Marian Balakowicz <m8@semihalf.com> Acked-by: Kumar Gala <galak@kernel.crashing.org>
2008-02-27[Makefile] Sort COBJS in lib_<arch> MakefilesMarian Balakowicz
2008-02-25[new uImage] Add dual format uImage support frameworkMarian Balakowicz
This patch adds framework for dual format images. Format detection is added and the bootm controll flow is updated to include cases for new FIT format uImages. When the legacy (image_header based) format is detected appropriate legacy specific handling is invoked. For the new (FIT based) format uImages dual boot framework has a minial support, that will only print out a corresponding debug messages. Implementation of the FIT specific handling will be added in following patches. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-07[new uImage] Removed dead ramdisk code on microblaze architecturesMarian Balakowicz
Microblaze do_bootm_linux() includes ramdisk processing code but the ramdisk does not get used anywhere later on. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-07[new uImage] Factor out common image_get_ramdisk() routineMarian Balakowicz
Architecture specific do_bootm_linux() routines share common ramdisk image processing code. Move this code to a common helper routine. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-07[new uImage] Rename architecture specific bootm code filesMarian Balakowicz
Implementation of the do_bootm_linux() and other bootm helper routines is architecture specific code. As such it resides in lib_<arch> directories in files named <arch>_linux.c This patch renames those files to a more clear and accurate lib_<arch>/bootm.c form. List of the renamed files: lib_arm/armlinux.c -> lib_arm/bootm.c lib_avr32/avr32_linux.c -> lib_avr32/bootm.c lib_blackfin/bf533_linux.c -> lib_blackfin/bootm.c lib_i386/i386_linux.c -> lib_i386/bootm.c lib_m68k/m68k_linux.c -> lib_m68k/bootm.c lib_microblaze/microblaze_linux.c -> lib_microblaze/bootm.c lib_mips/mips_linux.c -> lib_mips/bootm.c lib_nios/nios_linux.c -> lib_nios/bootm.c lib_nios2/nios_linux.c -> lib_nios2/bootm.c lib_ppc/ppc_linux.c -> lib_ppc/bootm.c lib_sh/sh_linux.c -> lib_sh/bootm.c Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-07[new uImage] Cleanup image header pointer use in bootm codeMarian Balakowicz
- use single image header pointer instead of a set of auxilliary variables. - add multi component image helper routines: get component size/data address Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-07[new uImage] Define a API for image handling operationsMarian Balakowicz
- Add inline helper macros for basic header processing - Move common non inline code common/image.c - Replace direct header access with the API routines - Rename IH_CPU_* to IH_ARCH_* Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2007-09-24[PATCH] Add support for design without interrupt controllerMichal Simek
Polling timer
2007-09-24synchronizition with mainlineMichal Simek
2007-08-07Merge git://www.denx.de/git/u-bootMichal Simek
2007-08-06Merge with /home/wd/git/u-boot/custodian/u-boot-testingWolfgang Denk
2007-08-05Merge git://www.denx.de/git/u-bootMichal Simek
2007-07-14[PATCH] Support time without timerMichal Simek
2007-07-13make show_boot_progress () weak.Heiko Schocher
2007-07-09lib_{m68k,microblaze,mips,ppc}/: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04lib_*/: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2007-03-26Support for XUPV2P boardMichal Simek
Reset support BSP autoconfig support
2007-03-11[Microblaze][PATCH] part 2Michal Simek
timer support interrupt controller support flash support ethernet support cache support board information support env support booting image support adding support for Xilinx ML401
2004-07-10Patches by Yasushi Shoji, 29 Jun 2004:wdenk
- add empty include/asm-microblaze/processor.h - add to CREDITS and MAINTAINERS - add gd initialization - add MicroBlaze and SUZAKU board to MAKEALL script - add reset support for SUZAKU - add flush_cache() for MicroBlaze - add CFG_FLASH_SIZE to include/configs/suzaku.h since we have fixed size flash memory on SUZAKU
2004-04-18* Patch by Dan Malek, 07 Apr 2004:wdenk
- Add support for RPC/STx GP3, Motorola 8560 board - Update 85xx TSEC driver so it searches MII for first available PHY and uses that one. - Add functions to support console MII commands. * Patch by Tolunay Orkun, 07 Apr 2004: Move initialization of bi_iic_fast[] from board_init_f() to board_init_r() * Patch by Yasushi Shoji, 07 Apr 2004: Cleanup microblaze port * Patch by Sangmoon Kim, 07 Apr 2004: Add auto SDRAM module detection for Debris board
2004-04-18* Patch by Yasushi Shoji, 07 Apr 2004:wdenk
- add support for microblaze processors - add support for AtmarkTechno "suzaku" board
