path: root/lib_m68k
2010-03-24ColdFire: Cache update for all platformsTsiChung Liew
The CF will call cache functions in lib_m68/cache.c and the cache settings are defined in platform configuration file. Signed-off-by: TsiChung Liew <tsicliew@gmail.com>
2010-03-21mod change 755 => 644 for multiple filesThomas Weber
I executed 'find . -name "*.[chS]" -perm 755 -exec chmod 644 {} \;' Signed-off-by: Thomas Weber <swirl@gmx.li> Add some more: neither Makefile nor config.mk need execute permissions. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-12-05Generic udelay() with watchdog supportIngo van Lil
According to the PPC reference implementation the udelay() function is responsible for resetting the watchdog timer as frequently as needed. Most other architectures do not meet that requirement, so long-running operations might result in a watchdog reset. This patch adds a generic udelay() function which takes care of resetting the watchdog before calling an architecture-specific __udelay(). Signed-off-by: Ingo van Lil <inguin@gmx.de>
2009-10-10Add bb_miiphy_init call before any ethernet bring-up code.Luigi 'Comio' Mantellini
Signed-off-by: Luigi 'Comio' Mantellini <luigi.mantellini@idf-hit.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-09-04push LOAD_ADDR out to arch mk filesMike Frysinger
Rather than maintain/extend the current ifeq($(ARCH)) mess that exists in the standalone Makefile, push the setting up of LOAD_ADDR out to the arch config.mk (and rename to STANDALONE_LOAD_ADDR in the process). This keeps the common code clean and lets the arch do whatever crazy crap it wants in its own area. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-09-04Consolidate arch-specific mem_malloc_init() implementationsPeter Tyser
2009-09-04Standardize mem_malloc_init() implementationPeter Tyser
This lays the groundwork to allow architectures to share a common mem_malloc_init(). Note that the x86 implementation was not modified as it did not fit the mold of all other architectures. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-09-04Consolidate arch-specific sbrk() implementationsPeter Tyser
2009-08-04Merge branch 'next' of git://git.denx.de/u-boot-coldfireWolfgang Denk
2009-07-21Move architecture specific config.mk files into subdirsPeter Tyser
This cleans up U-Boot's toplevel directory a bit and makes the architecture 'config.mk' file naming and location similar to board and cpu 'config.mk' files Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-07-18stdio/device: rework function naming conventionJean-Christophe PLAGNIOL-VILLARD
So far the console API uses the following naming convention: ======Extract====== typedef struct device_t; int device_register (device_t * dev); int devices_init (void); int device_deregister(char *devname); struct list_head* device_get_list(void); device_t* device_get_by_name(char* name); device_t* device_clone(device_t *dev); ======= which is too generic and confusing. Instead of using device_XX and device_t we change this into stdio_XX and stdio_dev This will also allow to add later a generic device mechanism in order to have support for multiple devices and driver instances. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Edited commit message. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-14ColdFire: Remove compiler warning messagesTsiChung Liew
Remove unused variables and printf type mismatch in lib_m68k/board.c Signed-off-by: TsiChung Liew <tsicliew@gmail.com>
2009-06-12Compier warning cleanupRichard Retanubun
Follow up to git commit: 19b5b533ccd522abeb501d510750693c35e20456 Cleanup on compiler warnings on unused variables now that bd->bi_enetaddr is no longer used. Signed-off-by: Richard Retanubun <RichardRetanubun@RuggedCom.com>
2009-06-12Adds WATCHDOG_RESET() function call to lib_m68k dtimer_interrupt.Richard Retanubun
Ported from lib_ppc/interrupts.c, this adds the ability for the coldfire system timer to auto-reset the watchdog when dtimer_interrupts is called. Signed-off-by: Richard Retanubun <RichardRetanubun@RuggedCom.com>
2009-06-12lib_arch/board.c: Move malloc initialization before flash_init()Stefan Roese
This patch moves the malloc initialization before calling flash_init(). Upcoming changes to the NOR FLASH common CFI driver with optional MTD infrastructure and MTD concatenation support will call malloc(). And nothing really speaks against enabling malloc just a little earlier in the boot stage. Some architectures already enable malloc before calling flash_init() so they don't need any changes here. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Scott McNutt <smcnutt@psyent.com> Cc: Shinya Kuribayashi <shinya.kuribayashi@necel.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Cc: Daniel Hellstrom <daniel@gaisler.com> Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: John Rigby <jcrigby@gmail.com>
2009-04-04rename include/zlib.h to include/u-boot/zlib.hJean-Christophe PLAGNIOL-VILLARD
Some systems have zlib.h installed in /usr/include/. This isn't the desired file for u-boot code - we want the one in include/zlib.h. This rename will avoid the conflict. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-03-20lib_*/board.c: do not initialize bi_enet*addr in global dataMike Frysinger
Since everyone is using the environment for mac address storage, there is no point in seeding the global data. The arches that are converted here: i386 m68k microblaze mips nios nios2 sh sparc Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com> CC: Daniel Hellstrom <daniel@gaisler.com> CC: Michal Simek <monstr@seznam.cz> CC: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp> CC: Scott McNutt <smcnutt@psyent.com> CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2009-02-21Cleanup the comment for m68k linux boot argument passing.Richard Retanubun
This patch clarifies the way m68k passes linux boot argument. The one gotcha here is that the assembly instruction that the compiler uses to jump to the kernel is 'jsr' which pushes the program counter for the instruction after the jsr into the stack pointer. Signed-off-by: Richard Retanubun <RichardRetanubun@RuggedCom.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-01-24Fixed off-by-one errors in lib_m68k/interrupts.cGraeme Russ
Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2008-10-29bootm: Add subcommandsKumar Gala
Add the ability to break the steps of the bootm command into several subcommands: start, loados, ramdisk, fdt, bdt, cmdline, prep, go. This allows us to do things like manipulate device trees before they are passed to a booting kernel or setup memory for a secondary core in multicore situations. Not all OS types support all subcommands (currently only start, loados, ramdisk, fdt, and go are supported). Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-10-18Added arch_lmb_reserve to allow arch specific memory regions protectionKumar Gala
Each architecture has different ways of determine what regions of memory might not be valid to get overwritten when we boot. This provides a hook to allow them to reserve any regions they care about. Currently only ppc, m68k and sparc need/use this. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-09-10rename CFG_ENV_IS_NOWHERE in CONFIG_ENV_IS_NOWHEREJean-Christophe PLAGNIOL-VILLARD
2008-09-10rename CFG_ENV_IS_IN_NVRAM in CONFIG_ENV_IS_IN_NVRAMJean-Christophe PLAGNIOL-VILLARD
2008-08-28ColdFire: Fix board.c warning messageTsiChung Liew
Implicit declaration of nand_init() warning message Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-08-26bootm: refactor do_reset and os boot function argsKumar Gala
There is no need for each OS specific function to call do_reset() we can just do it once in bootm. This means its feasible on an error for the OS boot function to return. Also, remove passing in cmd_tbl_t as its not needed by the OS boot functions. flag isn't currently used but might be in the future so we left it alone. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-08-26bootm: move lmb into the bootm_headers_t structureKumar Gala
To allow for persistent state between future bootm subcommands we need the lmb to exist in a global state. Moving it into the bootm_headers_t allows us to do that. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-08-26bootm: refactor ramdisk locating codeKumar Gala
Move determing if we have a ramdisk and where its located into the common code. Keep track of the ramdisk start and end in the bootm_headers_t image struct. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-08-26bootm: refactor entry point codeKumar Gala
Move entry point code out of each arch and into common code. Keep the entry point in the bootm_headers_t images struct. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-08-21Consolidate strmhz() implementationHaavard Skinnemoen
ARM, i386, m68k and ppc all have identical implementations of strmhz(). Other architectures don't provide this function at all. This patch moves strmhz() into lib_generic, reducing code duplication and providing a more unified API across architectures. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2008-08-14ColdFire: Add SSPI feature for MCF5445xTsiChung Liew
2008-08-12Fix fallout from autostart revertKumar Gala
The autostart revert caused a bit of duplicated code as well as code that was using images->autostart that needs to get removed so we can build again. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-08-01ColdFire: Fix compilation issue caused by a missing functionTsiChung Liew
Implement usec2ticks() which is used by fsl_i2c.c in lib_m68k/time.c Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-07-14Fix printf() format issues with sizeof_t types by using %zuWolfgang Denk
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-07-11ColdFire: Fix warning messages by passing correct data type in board.cTsiChung Liew
2008-05-03Fix implicit declaration build warningsMarcel Ziswiler
- warning: implicit declaration of function ‘serial_initialize’ Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
2008-04-17Restore the ability to continue booting after legacy image overwriteMarian Balakowicz
Before new uImage code was merged, bootm code allowed for the kernel image to get overwritten during decompresion. new uImage introduced a check for image overwrites and refused to boot the image that got overwritten. This patch restores the old behavior. It also adds a warning when the image overwriten is a multi-image file, because in such case accessing componentes other than the first one will fail. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-03-12[new uImage] Add new uImage format support to arch specific do_bootm_linux() ↵Marian Balakowicz
routines This patch updates architecture specific implementations of do_bootm_linux() adding new uImage format handling for operations like get kernel entry point address, get kernel image data start address. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-03-12[new uImage] Remove unnecessary arguments passed to ramdisk routinesMarian Balakowicz
boot_get_ramdisk() and image_get_ramdisk() do not need all cmdtp, flag, argc and argv arguments. Simplify routines definition. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-29[new uImage] Update naming convention for bootm/uImage related codeMarian Balakowicz
This patch introduces the following prefix convention for the image format handling and bootm related code: genimg_ - dual format shared code image_ - legacy uImage format specific code fit_ - new uImage format specific code boot_ - booting process related code Related routines are renamed and a few pieces of code are moved around and re-grouped. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-29[new uImage] Respect autostart setting in linux bootmKumar Gala
Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Marian Balakowicz <m8@semihalf.com>
2008-02-29[new uImage] Provide ability to restrict region used for boot imagesKumar Gala
Allow the user to set 'bootm_low' and 'bootm_size' env vars as a way to restrict what memory range is used for bootm. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Marian Balakowicz <m8@semihalf.com>
2008-02-29[new uImage] Use lmb for bootm allocationsKumar Gala
Convert generic ramdisk_high(), get_boot_cmdline(), get_boot_kbd() functions over to using lmb for allocation of the ramdisk, command line and kernel bd info. Convert PPC specific fdt_relocate() to use lmb for allocation of the device tree. Provided a weak function that board code can call to do additional lmb reserves if needed. Also introduce the concept of bootmap_base to specify the offset in physical memory that the bootmap is located at. This is used for allocations of the cmdline, kernel bd, and device tree as they should be contained within bootmap_base and bootmap_base + CFG_BOOTMAPSZ. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-02-29[new uImage] rework error handling so common functions don't resetKumar Gala
Changed image_get_ramdisk() to just return NULL on error and have get_ramdisk() propogate that error to the caller. It's left to the caller to call do_reset() if it wants to. Also moved calling do_reset() in get_fdt() and fdt_relocate() on ppc to a common location. In the future we will change get_fdt() and fdt_relocate() to return success/failure and not call do_reset() at all. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Marian Balakowicz <m8@semihalf.com>
2008-02-29[new uImage] Don't pass kdb to ramdisk_high since we may not have oneKumar Gala
We don't actually need the kdb param as we are just using it to get bd->bi_memsize which we can get from gd->bd->bi_memsize. Also, if we boot via OF we might not actually fill out a kdb. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Marian Balakowicz <m8@semihalf.com>
2008-02-27[new uImage] Move image verify flag to bootm_headers structureMarian Balakowicz
Do not pass image verification flag directly to related routines. Simplify argument passing and move it to the bootm_header structure which contains curently processed image specific data and is already being passed on the argument list. Signed-off-by: Marian Balakowicz <m8@semihalf.com> Acked-by: Kumar Gala <galak@kernel.crashing.org>
2008-02-27[Makefile] Sort COBJS in lib_<arch> MakefilesMarian Balakowicz
