path: root/lib_m68k/time.c
2009-06-12Adds WATCHDOG_RESET() function call to lib_m68k dtimer_interrupt.Richard Retanubun
Ported from lib_ppc/interrupts.c, this adds the ability for the coldfire system timer to auto-reset the watchdog when dtimer_interrupts is called. Signed-off-by: Richard Retanubun <RichardRetanubun@RuggedCom.com>
2008-08-06Fix merge problemsStefan Roese
2007-08-16ColdFire: MCF52x2 updateTsiChungLiew
Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
2007-08-16ColdFire: MCF5329 Update and cleanupTsiChungLiew
2007-08-08Changed CFG_CLK to gd->bus_clk for CFG_TIMER_PRESCALER. Added ↵TsiChungLiew
DECLARE_GLOBAL_DATA_PTR for time.c Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
2007-07-10Update header file. Include dtimer_intr_setup(). Changed timer divider to ↵TsiChungLiew
global define. Include immap.h and timer.h. Moved dtimer interrupt setup to dtimer_intr_setup() from cpu/mcf532x/interrupts.c. Changed (CFG_CLK /1000000) -1 << 8 to CFG_TIMER_PRESCALER Signed-off-by: TsiChungLiew <Tsi-Chung.Liew@freescale.com>
2007-06-18Added M5329AFEE and M5329BFEE PlatformsTsiChung Liew
Added board/freescale/m5329evb, cpu/mcf532x, drivers/net, drivers/serial, immap_5329.h, m5329.h, mcfrtc.h, include/configs/M5329EVB.h, lib_m68k/interrupts.c, and rtc/mcfrtc.c Modified CREDITS, MAKEFILE, Makefile, README, common/cmd_bdinfo.c, common/cmd_mii.c, include/asm-m68k/byteorder.h, include/asm-m68k/fec.h, include/asm-m68k/io.h, include/asm-m68k/mcftimer.h, include/asm-m68k/mcfuart.h, include/asm-m68k/ptrace.h, include/asm-m68k/u-boot.h, lib_m68k/Makefile, lib_m68k/board.c, lib_m68k/time.c, net/eth.c and rtc/Makefile Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2006-12-20Preliminary support for the iDMR board (ColdFire).Bartlomiej Sieka
2006-01-26Add support for Freescale M5271 processorZachary P. Landau
2005-04-05* Patch by Ladislav Michl, 05 Apr 2005:wdenk
Add support for VoiceBlue board. * Patch by Ladislav Michl, 05 Apr 2005: Fix netboot_common() prototypes. * Cleanup.
2005-04-03* Patch by Mathias Küster, 23 Nov 2004:wdenk
add udelay support for the mcf5282 cpu * Patch by Tolunay Orkun, 16 November 2004: fix incorrect onboard Xilinx CPLD base address
2004-12-16Coldfire MCF5249 support addedstroese
2004-06-09* Patch by Josef Baumgartner, 25 May 2004:wdenk
Add missing functions get_ticks() and get_tbclk() in lib_m68k/time.c * Patch by Paul Ruhland, 24 May 2004: fix SDRAM initialization for LPD7A400 board.
2004-02-12* Some code cleanupwdenk
* Patch by Josef Baumgartner, 10 Feb 2004: Fixes for Coldfire port * Patch by Brad Kemp, 11 Feb 2004: Fix CFI flash driver problems
2003-12-08* Patch by Bernhard Kuhn, 28 Nov 2003:wdenk
add support for Coldfire CPU add support for Motorola M5272C3 and M5282EVB boards
