path: root/lib_i386
2008-04-18allow ports to override go behaviorMike Frysinger
Split the arch-specific logic out of the common go code and into a dedicated weak function called do_go_exec() that lives in cpu directories. This will need review from i386/nios people to make sure I didn't break them.
2008-03-12[new uImage] Add new uImage format support to arch specific do_bootm_linux() ↵Marian Balakowicz
routines This patch updates architecture specific implementations of do_bootm_linux() adding new uImage format handling for operations like get kernel entry point address, get kernel image data start address. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-03-12[new uImage] Remove unnecessary arguments passed to ramdisk routinesMarian Balakowicz
boot_get_ramdisk() and image_get_ramdisk() do not need all cmdtp, flag, argc and argv arguments. Simplify routines definition. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-29[new uImage] Update naming convention for bootm/uImage related codeMarian Balakowicz
This patch introduces the following prefix convention for the image format handling and bootm related code: genimg_ - dual format shared code image_ - legacy uImage format specific code fit_ - new uImage format specific code boot_ - booting process related code Related routines are renamed and a few pieces of code are moved around and re-grouped. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-29[new uImage] Respect autostart setting in linux bootmKumar Gala
Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Marian Balakowicz <m8@semihalf.com>
2008-02-27[new uImage] Move image verify flag to bootm_headers structureMarian Balakowicz
Do not pass image verification flag directly to related routines. Simplify argument passing and move it to the bootm_header structure which contains curently processed image specific data and is already being passed on the argument list. Signed-off-by: Marian Balakowicz <m8@semihalf.com> Acked-by: Kumar Gala <galak@kernel.crashing.org>
2008-02-27[Makefile] Sort COBJS in lib_<arch> MakefilesMarian Balakowicz
2008-02-25[new uImage] Add dual format uImage support frameworkMarian Balakowicz
This patch adds framework for dual format images. Format detection is added and the bootm controll flow is updated to include cases for new FIT format uImages. When the legacy (image_header based) format is detected appropriate legacy specific handling is invoked. For the new (FIT based) format uImages dual boot framework has a minial support, that will only print out a corresponding debug messages. Implementation of the FIT specific handling will be added in following patches. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-07[new uImage] Factor out common image_get_ramdisk() routineMarian Balakowicz
Architecture specific do_bootm_linux() routines share common ramdisk image processing code. Move this code to a common helper routine. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-07[new uImage] Rename architecture specific bootm code filesMarian Balakowicz
Implementation of the do_bootm_linux() and other bootm helper routines is architecture specific code. As such it resides in lib_<arch> directories in files named <arch>_linux.c This patch renames those files to a more clear and accurate lib_<arch>/bootm.c form. List of the renamed files: lib_arm/armlinux.c -> lib_arm/bootm.c lib_avr32/avr32_linux.c -> lib_avr32/bootm.c lib_blackfin/bf533_linux.c -> lib_blackfin/bootm.c lib_i386/i386_linux.c -> lib_i386/bootm.c lib_m68k/m68k_linux.c -> lib_m68k/bootm.c lib_microblaze/microblaze_linux.c -> lib_microblaze/bootm.c lib_mips/mips_linux.c -> lib_mips/bootm.c lib_nios/nios_linux.c -> lib_nios/bootm.c lib_nios2/nios_linux.c -> lib_nios2/bootm.c lib_ppc/ppc_linux.c -> lib_ppc/bootm.c lib_sh/sh_linux.c -> lib_sh/bootm.c Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-07[new uImage] Cleanup image header pointer use in bootm codeMarian Balakowicz
- use single image header pointer instead of a set of auxilliary variables. - add multi component image helper routines: get component size/data address Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-07[new uImage] Fix uImage header pointer use in i386 do_bootm_linux()Marian Balakowicz
Use image header copy instead of a (possibly corrupted) pointer to a initial image location. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-07[new uImage] Remove I386 uImage fake_header() routineMarian Balakowicz
I386 targets are not using a uImage format, instead fake header is added to ram image before it is further processed by bootm. Remove this fixup and force proper uImage use for I386. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-07[new uImage] Define a API for image handling operationsMarian Balakowicz
- Add inline helper macros for basic header processing - Move common non inline code common/image.c - Replace direct header access with the API routines - Rename IH_CPU_* to IH_ARCH_* Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2007-07-10disk/ doc/ lib_*/ and tools/: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-09lib_{arm,avr32,blackfin,generic,i386}/: Remove obsolete references to ↵Jon Loeliger
CONFIG_COMMANDS Signed-off-by: Jon Loeliger <jdl@freescale.com>
2007-07-04lib_*/: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2006-07-21Fix multi-part image support on i386 platform.Wolfgang Denk
Patch by David Updegraff, 19 Aug 2005
2005-10-28Add support for multiple PHYs.Marian Balakowicz
2004-07-01* Patches by Richard Woodruff, 10 Jun 2004:wdenk
- fix problems with examples/stubs.c for GCC >= 3.4 - fix problems with gd initialization * Enable FAT filesystem support for HMI10 board
2004-03-14Code cleanup; make several boards compile & link.LABEL_2004_03_14_2340wdenk
2004-02-27* Patch by Pierre Aubert, 26 Feb 2004wdenk
add IDE support for MPC5200 * Patch by Masami Komiya, 26 Feb 2004: add autoload via NFS * Patch by Stephen Williams Use of CONFIG_SERIAL_SOFTWARE_FIFO in board.c consistent with uses elsewhere in the source.
2003-07-24* Implement new mechanism to export U-Boot's functions to standalonewdenk
applications: instead of using (PPC-specific) system calls we now use a jump table; please see doc/README.standalone for details * Patch by Dave Westwood, 24 Jul 2003: added support for Unity OS (a proprietary OS)
2003-07-15* Patches by Martin Krause, 14 Jul 2003:wdenk
- add I2C support for s3c2400 systems (trab board) - (re-) add "ping" to command table * Fix handling of "slow" POST routines
2003-07-14* Patches by Yuli Barcohen, 13 Jul 2003:wdenk
- Correct flash and JFFS2 support for MPC8260ADS - fix PVR values and clock generation for PowerQUICC II family (8270/8275/8280) * Patch by Bernhard Kuhn, 08 Jul 2003: - add support for M68K targets * Patch by Ken Chou, 3 Jul: - Fix PCI config table for A3000 - Fix iobase for natsemi.c (PCI_BASE_ADDRESS_0 is the IO base register for DP83815) * Allow to enable "slow" POST routines by key press on power-on * Fix temperature dependend switching of LCD backlight on LWMON * Tweak output format for LWMON
2003-05-31* Patch by Marc Singer, 29 May 2003:LABEL_2003_05_31_2115wdenk
Fixed rarp boot method for IA32 and other little-endian CPUs. * Patch by Marc Singer, 28 May 2003: Added port I/O commands. * Patch by Matthew McClintock, 28 May 2003 - cpu/mpc824x/start.S: fix relocation code when booting from RAM - minor patches for utx8245 * Patch by Daniel Engström, 28 May 2003: x86 update * Patch by Dave Ellis, 9 May 2003 + 27 May 2003: add nand flash support to SXNI855T configuration fix/extend nand flash support: - fix 'nand erase' command so does not erase bad blocks - fix 'nand write' command so does not write to bad blocks - fix nand_probe() so handles no flash detected properly - add doc/README.nand - add .jffs2 and .oob options to nand read/write - add 'nand bad' command to list bad blocks - add 'clean' option to 'nand erase' to write JFFS2 clean markers - make NAND read/write faster * Patch by Rune Torgersen, 23 May 2003: Update for MPC8266ADS board
2002-11-21* Added support for both PCMCIA slots (at the same time!) on MPC8xxLABEL_2002_11_22_0015wdenk
* Patch by Rod Boyce, 21 Nov 2002: fix PCMCIA on MBX8xx board * Patch by Pierre Aubert , 21 Nov 2002 Add CFG_CPM_POST_WORD_ADDR to make the offset of the bootmode word in DPRAM configurable
2002-11-19* Patch by Daniel Engström, 18 Nov 2002:wdenk
Fixes for x86 port (mostly strings issues) * Patch by Ken Chou, 18 Nov 2002: Fix for natsemi NIC cards (DP83815) * Patch by Pierre Aubert, 19 Nov 2002: fix a bug for the MII configuration, and some warnings
2002-11-18* Patch by Daniel Engström, 13 Nov 2002:LABEL_2002_11_18_0115wdenk
Add support for i386 architecture and AMD SC520 board * Patch by Pierre Aubert, 12 Nov 2002: Add support for DOS filesystem and booting from DOS floppy disk
